Question about Logitech Z-5500 Computer Speakers
Steady popping noise.
I have had my Z-5500 THX speakers for over a year, possibly 2. They have been great until recently. There is steady static, [a popping static sound] most of the time I turn sound on [but not always] This happens for my music players, for some e-mail video attachments and not others. Also, if the sound is turned on I get the static for other short sounds that come from the computer. The sound is there for head phones as well. HELP!! pleeezz..... ??
dean.edmundson@telus.net
  • cultureshock Oct 23, 2008
    Thanks, I will wait until my husband gets home to check the things you suggested and to tell me what the configuration is. Then I will get back to you, O.K.? Hopefully this delay will not mean I have to pay again for this problem. I am new to your service - can I assume that a payment is for all correspondence connected to one problem?
    So far I am impressed. - Speedy answer!
    Dean [cultureshock]
    Master:
  • 538 Answers
Hmm..ok..first lets check the wiring, to ensure that there are not gaps or sparking, which is what this can be caused by..then, we will look at perhaps getting new drivers,,then we will look at the sound card...need to know a bit
about your configuration for your computer though
Posted on Oct 23, 2008
  • Logitech Master
  • 13,433 Answers
Clearly seems like a Sound card issue, or issue with the source of the sound, generally if your using it with your computer then its clearly the sound card, are you using a build in sound card? for best results one should buy a pci sound card for example.
... link coming
  • Ekse Oct 23, 2008
    for example here is a quality sound card
    http://www.newegg.com/Product/Product.as...
    Internal motherboard sound cards can cause the things your talking about or it can also be a driver issue, I myself have experienced raining like sound problem.. crackling .. on a diffrent set of drivers and on another set of drivers I don't have any problems.
  • Ekse Oct 23, 2008
    Yes but can I ask which one of us are you prefering to? it would be best if you accept my solution already. I will continue to provide you with assistance later if needed. also my email is nikoht at gmail dot com.
    Sergeant:
    Champion:
  • 200 Answers
Hi
reinstall the sound driver
thank you
  • Thafa Oct 23, 2008
    Hi
    If sound driver software corrupted means these faults will come try to reinstall the driver software
    thank you
    After installing the driver u get the same error means check the sound card..
Why static on motorola CLS 1110?
Are you referring to static (random snapping, crackling, popping) that only occurs when you are handling the radio, or a steady hissing sound when turned on? The first may indicate the radio has a defect or loose internal connection; the second is reduced by adjusting the squelch setting. More information is always helpful.
Aug 01, 2014 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Jan 03, 2008 | Pioneer VSX-54TX Receiver
High pitched noise coming from speakers after installing stereo
check your wires if they are too near some big power wires and move them away from these high powered wires or check your grounds and make sure its a good ground by scrapping the connection until bare metal. Also its a possibility rca's or wires are getting pinched or not fully connected.
Apr 05, 2010 | Boss BV9560 Car Video Player
Worcester Bosch 35CDi II banging & wild pressure (CH only)
Hi try bleeding the pump it sounds like air in the pump , but worcester do have a free tech help line look for there wed page on line hope this helps
Feb 16, 2010 | Heating & Cooling
Pop from speakers when using dolby digital mode, works fine when not using any processing mode
Over 10 years old? Could be bad capacitors... if you have the expertise, you can try taking it apart and checking them with capacitance and ESR (equivalent series resistance) meters. Otherwise, you can try to see if any capacitors are exhibiting any "bowing" or leaking; if the top of the capacitor is bowed or puffed out - even slightly - or if there is a brown or white residue around the base of the capacitor, you can guarantee the capacitor is bad. Note that not all bad capacitors exhibit these physical attributes... but you can be sure a good capacitor won't.
If all of this sounds too complex, your only recourse will be to take it to a reputable electronics service shop.
May 26, 2009 | Yamaha DSP-A1 Receiver
Sony KDS-50A2000 no audio
check you sound option in sound settings menu sound settings region ie i or b or auto mike shure u on i
Mar 28, 2009 | Sony KDS-50A2000 50" HDTV
Speaker static noise
The first thing to try is plugging a set of headphones into the speaker plug and testing, see if the crackling continues, if it doesn't it sounds like a short in your speakers (or the sound card, but my guess would be the speakers).
Post your results here so we can further assist you.
Mar 24, 2009 | Gateway Media Center 610XL PC Desktop
Static
CB radios use a frequency range and technology that is prone to noises both atmospheric, and man made. The height and gain of your new base antenna may produce more static than you may have noticed before. The question is 1) is the antenna close to any power lines to your home, 2) do you notice any increase or decrease of received signals compared to your mobile, 3) is the static steady or does it come and go.
Nov 07, 2008 | Radio Shack TRC-503 CB Radio
Lip Sync issues with Logitech Z-5500 and PS3
hello there
First things First:
1) change the digital opt, cable, for another with cooper conduction. **
2) check connection again on low volume.
good luck
Mar 21, 2008 | Logitech Z-5500 Computer Speakers
Loud steady sound when turned on
If it's a humming noise you are describing, then it may be that one of the power supply filter capacitors has failed. Of course it could be some other sort of power supply problem as well.
Dec 14, 2007 | Wharfedale PowerCube PC-12 Subwoofer
Logitech Z-5500 Computer Speakers Logo
270 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
