Hello
I assumes that you did gorget the code that you have set to Smart lock, and posts this solution.
If you ever forget you smartlock code, enter [ 0,7,1,1 ] code is the factory default, and can be used to enter and create a new acess code. OK.
Tried the code it didn't work. Is there any other codes?
Thie is the code given in its manual to open the smart lock. Try it once more. No othe code is stated with it.
Just need to unlock one channel? Will that code work?
Select the channel you want to unlick, and from the "Menu", hilight 'Unlock' and press OK.
The factory reset option should reset all settings to TV to factory settings, when the TV was shipped out from factory.
The code didn't work.
