Question about Emerson EWF2004 20" TV
Etv20 I purchased this tv in la paz, mexico about four years ago. After the set is on for 30+ minutes, it turns on and off which lasts until I disconnect power to it. After letting it sit for 30 minutes or more, it will work fine for a while and then the problem starts again. Could it be the on/off power switch. Thanks for any help you can give me. Jose Fuentes
  • CHUGALUG_CHI Nov 15, 2008
    I BOUGHT THIS THING FOUR YEARS AGO AND THE SAME THING IS HAPPENING TO ME. ON FOR THIRTY MINUTES AND THEN IT SHUTS IT SELF ON AND THEN COMES BACK ON AND IT GOES ON LIKE THAT. I UNPLUG IT AND LET IT SIT AND IT DOES THE SAME THING.... WTF?
Mabye its haunted oooooohhhhhhh!!!!!
Posted on Oct 31, 2008
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link.. http://www.discount-merchant.com/1069179-HL-N5067W-p/1069179.htm
the price is more or less depends on your TV model... $279.00
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
My TV began with a flash of white light then will turn itself off. It won't turn off every time the screen flashes. It started a month ago then worked trouble free until now and it began again. You can...
I hope you have a service plan for this set. Most likely--the CRT"s are going bad. This was a VERY common problem for Sony sets of this age. the CRT tubes SHOULD last a long time...BUT Sony had a BUNCH of the tubes that had 'contamination" on the cathodes of the guns...and after a few years..this 'flakes off" and shorts out the tubes. There WAS a recall on these a couple of years ago, but I am not sure about it now. You will need ALL 3 tubes to fix this problem. If it was me...I would try and find out if there is any way to get Sony to cover it..., if the set is not more than about 8years old.
Oct 12, 2009 | Sony KP-51HW40 51" Rear Projection...
I swith the tire size of my rodeo and now its no the same on the 4x4 now it sucks it looks cool but now dont feel good thanks im from La Paz Baja California Sur , Mexico
Whn you change the tire size - you change the ratio of the drive train..
Also when you go with bigger tires - the ride will not feel as good because it will be a rougher ride and you will feel the road more..
And the vehickle will handle diferently..
You can allways change e'm back..
Hope this helps !!
Please rate me good ;o)
Jul 10, 2009 | 1999 Isuzu Rodeo
I purchased my tv 2 years ago. Watched it
Try leaving the TV unplugged for 30 minutes so theTV can reset itself.
If that doesn't work, most likely the TV has a power supply board is the problem. Or, it's just a fuse that blown inside the TV.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 05, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Error message on screen "No heading pulse"
Your belt on the inside of the dome has come off. Take a small allen wrench with you when you go to check on it.
Mar 14, 2009 | Furuno 1715 7" Monochrome Lcd 2.2kw Radar...
Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Nov 01, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Protron pltv-26
if your tv is up high try to lower it mine did the same thing but after i set it closer to the ground it stopped and hasnt done it since..
Dec 17, 2007 | Protron PLTV-32 Television
TV shuts off
I would suggest that you guys turn the unit off when this happens, unplug the unit for 30 seconds, plug it back in, and see if this helps. If this does not solve your problem, you should call 1-800-448-2244, so a service center in your local area can be found for further assistance.
Nov 08, 2007 | Televison & Video
Overpoewering red
Every person I know who purchased this very expensive unit has had this problem early in the life of the TV. Sony is no help. Sony will suggest you take it to a repair facility. Sony from years ago is not the Sony of today. It was expensive to purchase and it will gouge you with repairs. Your choice. I eventually discarded my set and purchased a JVC. These rear projection TV's are garbage and Sony knows it and they dont care. Seems like the last for only a few years and then major problems occur. My solution replace it!
May 15, 2007 | Sony KP-57HW40 57" Rear Projection...
Emerson EWF2004 20" TV Logo
119 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
