Lg wd-8090FB manual
7 kg
5 Suggested Answers
  • 136 Answers
SOURCE: LG washing machine intellowasher 7 kg wd-8050f
Please unplug or shut off the power at the fuse box...
The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valve The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valves are blocked or the solenoids do not activate, the symptoms may include no water, low water pressure, the wrong water temperature or water entering the tub even when the machine is off.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.There are two wires connected to each solenoid (aka coil) on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Posted on Jan 19, 2010
  • 5480 Answers
SOURCE: Hi, hope you can help, I have a 4 kg LG Washer /
CL means that the child lock feature is active and the control panel buttons will not respond. For the LG WD1433RD, press and hold the Rinse+ and Pre-Wash buttons together for about 3 seconds to toggle the lock off. For the LG WD14311RD, press and hold Option and Rinse for about 3 seconds. On both washers, there is a small icon between the two buttons needed to toggle the child lock feature on and off. (It's a small face above a padlock.)
The manual as a Djvu file for the LG WD14311RD is available here: http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=WD-14311RD&initialTab=warranty&targetPage=support-product-profile .
The manual for the WD1433RD is available as a PDF here: http://www.manualsonline.com/ex/thread/view/idThread/80183 .
I hope this helps.
Posted on Apr 07, 2011
Testimonial: "Simple explanation , very quick response....fantastic"
FitzOriginal
  • 842 Answers
SOURCE: hi need manual for lg 7.5 kg wd-1049c can you help
You can download this manual from:
http://www.mediafire.com/?x89ux44jkw3qhe7
Posted on Jun 30, 2011
AE ERRORPROBLEM
What is the problem you faces with this device? If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 07, 2015 | LG WD-1070QDP 7 Kg Direct Drive Washer
Wiring diagram for kg80490np washing machine front loader
More details required. i.e kg? np? Brand name enter minimum details in Search box should show up and suggest.
Good Luck
Feb 03, 2015 | LG Washing Machines
How do you operate a lg inverter direct drive washer
it a procedure,read it manual........................or power on nd press the play botton ,,,,everything will operate itself automatically
Sep 04, 2014 | LG WD-1070QDP 7 Kg Direct Drive Washer
LG Direct drive having problems drying clothes
check on the water outlet pump beneath ,,,,,,if there is a sound while drying,,,maybe needs to clean the filter cup,
Apr 13, 2013 | LG WD-1070QDP 7 Kg Direct Drive Washer
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
