Question about Arris SB6121 SURFboard DOCSIS 3.0 eXtreme Broadband Cable Modem (612572180136)
Xbox live lagging
After upgrading to this modem Mot SB6121) from a linksys DOCSIS 2 modem, my son immediately noticed some lags while play COD modern warfare 3. Character seems to freeze for a couple of seconds and then jumps ahead to resume play. Other players can see my son's character freeze then jump to new location.gameplay was fine with the old linksys. Speedtest is great with 17 mbps down and 3.8 mbps up with Comcast cable, and computer internet activity is just fine. The xbox console is connected via ethernet hard wire and the xbox connection test indicates the connection is fine. any ideas?
SOURCE: SB5100 Docsis 2.0 Upgrade from Docsis 1.1
Technical Details
  • Model: SB5100
  • Type: External, platform-independent modem with HTML-based user interface for status troubleshooting
  • Standards: Integrated DOCSIS 2.0 A-TDMA and S-CDMA technology
  • PC interface: USB for Windows 98/2000/XP
  • Cable interface: F-Connector, female, 75 ohms
  • CPE network interface: USB, Ethernet 10/100BaseT (auto sensing)
  • LED indicators: Yes (front panel)
  • Users: Supports up to 32 users (1 via USB and up to 31 via Ethernet or 32 users on Ethernet)
  • Power: Internal power supply: 9 Watts (nominal)
  • Input power: 100-240 VAC, 50-60 Hz
  • Excite@Home Level 2 Approved: Yes
  • Bridging: Ethernet and USB connections are bridged allowing LAN traffic between USB device and Ethernet LAN
  • Networking: 10/100BaseT Ethernet (auto sensing)
  • Remote management: Yes (via SNMP)
  • Software upgradeable: Yes (over the network)
  • Top-mounted stand-by button: Yes (enhances network security to end-user)
  • Troubleshooting: HTML-based diagnostic user interface
  • Global safety approval and certificates: CB scheme (EN60950/IEC950), CE-Evaluation test report (EN55022/EN55024), FCC Part 15, UL 1950
  • Downstream demodulation: 64 or 256 QAM
  • Downstream maximum data rate: 38 Mbps
  • Downstream bandwidth: 6 MHz
  • Downstream symbol rate: 64 QAM 5.069 Msym/s
  • Downstream symbol rate: 256 QAM 5.361 Msym/s
  • Downstream operating level range: -15 to +15 dBmV
  • Downstream input impedance: 75 ohms (nominal)
  • Downstream frequency range: 88 to 860 MHz
  • Upstream modulation: 8, 16, 32, 64, 128 QAM or QPSK (with A-TDMA or S-CDMA enabled CMTS)
  • Upstream maximum data rate: Up to 30 Mbps
  • Upstream bandwidth: 200 kHz, 400 kHz, 800 kHz, 1.6 MHz, 3.2 MHz, 6.4 MHz (with A-TDMA or S-CDMA enabled CMTS)
  • Upstream symbol rates: 160, 320, 640, 1280, 2560 and 5120 ksym/s (with A-TDMA or S-CDMA enabled CMTS)
  • Upstream operating level range: A-TDMA: +8 to+54 dBmV (32QAM, 64QAM), +8 to+55 dBmV (8QAM, 16QAM), +8 to+58 dBmV (QPSK), S-CDMA: +8 to+53 dBmV (all modulations)
  • Upstream output impedance: 75 ohms (nominal)
  • Upstream frequency range: 5 to 42 MHz (edge to edge)
  • Data protocol: TCP/IP
  • Operating temperature: 0 degrees to 40 degrees C
  • Storage temperature: -30 degrees to 80 degrees C
  • Operating humidity: 0 to 95 percent R.H. non-condensing
  • System requirements: Windows 95/98/2000/NT/Millennium, Macintosh, UNIX
  • Width: 2.3 inches
  • Height: 6.2 inches
  • Depth: 6 inches
  • Warranty, parts: 1 year
  • Warranty, labor: 1 1year
Posted on Dec 24, 2007
  • 86 Answers
SOURCE: cable modem + dlink router
Your modem needs to be rebooted in order for your router to pull an IP from the modem. To do this, look for a little hole in the back of your modem and use a pen to push the button. Wait for the reboot to finish and then try again in about 20 seconds.
Posted on Jan 20, 2008
SOURCE: MY LINKSYS WRT54G WONT READ MY COMPUTERS INTERNET CONNECTION
Ok to start the yellow ethernet port should be connected straight to the Linksys router in the ethernet in port. Then you connect the cmputer to one of the other the 4 ports on the back of the wireless router. wala you shouldn't have any more trouble after that.
Posted on Jan 11, 2009
  • 31 Answers
SOURCE: Linksys router and modem problems
Most cable company's will not allow you to use the USB and the ethernet connection at the same time. You will need to only use ethernet to your PC and your XBOX. Once you have the ethernet cord connected from your modem to the WAN/Internet port on your router you will need to press the reset button on the back of the arris to authorise the router for access. After that is done you will plug you XBOX into 1 of the 4 numbered ports on the router. Then you will need an additional ethernet cord for your PC.
Hope this helps
Posted on Apr 09, 2009
zazonker
  • 68 Answers
SOURCE: Unable to set up wireless router
Shut down your computer, unplug the cable modem and the switch. Connect all three - computer to switch, switch to modem. Make sure that the ethernet cable between the router and the modem is in the router uplink port and that the computer is plugged into one of the four ports that look alike. Wait 30 seconds - plug in the modem. Wait another 30 seconds, plug in the router, wait another 30 seconds and boot the computer. Open a browser and see if you have internet access. If you still don't, then try to check the browser by typing 192.168.1.1 into the address bar of the browser. That should give you the browser sign in screen. The Linksys default is to leave the user name blank and type admin for the password. That should give you access to the router so you can check the settings. If this doesn't work, document carefully what happens and post again with your results and we'll try to go from there.
Posted on Jun 08, 2009
Why dose my profile keep signing me out when putting on games and when trying to play some games
Sometimes it may depend on the connectivity of the level your internet. A while ago I had a lot of problems with internet and like you, my games often crashed.
The easiest thing is to check your connection and make sure you are getting a strong signal.
On Xbox 360 to check your connection just follow this link:
Troubleshoot Xbox 360 connection to Xbox Live
While it's a lot to read it will help you in the long run.
To check your speed on Xbox Live go here
Slow experience on Xbox Live (for Xbox One)
You can also check out to see if Xbox Live may be the problem. By going to this link.
Xbox Live Status
The next thing, try replacing your router, when I bought my new router my problems stopped. You can also upgrade to a newer modem to DOCSIS 3.0. This of course depends on your internet speed. If you are below 20mbs I wouldn't worry about upgrading just yet. But upgrading never hurts. However, if you are trying to get 50mbs or more DOCSIS 2.0 bottlenecks. While I am no expert on modems. I think the DOCSIS 2.0 modem bottlenecks around 38mbs.
To Check your speed on the internet, this is the site most people go to.
Speedtest net by Ookla The Global Broadband Speed Test
Use whichever server you wish. I usually do multiple ones to see how it differs.
Jan 13, 2015 | Microsoft (X-Box) P5F-00001 Xbox 360...
SURFboard DOCSIS 3.0 boosting the wifi signal
The SB6121 doesn't have WiFi, but I used a wifi extender (~$40-$80) to boost the wifi signal of my current wireless router that's attached to the SB6121.
Sep 20, 2013 | Arris SB6121 SURFboard DOCSIS 3.0 eXtreme...
Xbox is lagging hooked up with at&t gateway 2wire
Get rid of AT&T and get a new provider that works. AT&T and LIVE don't go together.
Jan 05, 2013 | Microsoft Xbox 360 Console
Xbox live lag
This could happen for many reasons. It could be other people using up all you internet. If possible connect your xbox directly to your router or modem and see if that fixes the problem. If not use speedtest.net and see if the speed you are getting is what you are paying for.
Oct 12, 2012 | Microsoft Xbox 360 Console
I have frontier services with a net gear modem/router i was told by xbox live to get a d-link router an it would help my problem with running 2 xbox 360 with no lag whats so ever but dont know what im...
well, unless the D-link is also a modem/router, I don't see how ADDING the D-link router to a lagging network will reduce said lag. They probably wanted you to REPLACE the current router with that one.....
will "frontier service" allow that router to be set in a "modem-only" setting ? You'll have to get with them on that. as for the D-link, there are manuals as well as an Online Emulator that simulates the Router interface so you can see how to set it up....BEFORE you set it up !
[PS: tracking-down lag problems can be tricky....you should be experiencing bad lag with all sites for it to be your hardware....
Tallon41
Sep 05, 2012 | D-Link DIR-665 Xtreme N 450 Gigabit Router...
When i play my xbox 360 im getting a lag...my friend said i should have a setting to prevent this but im not sure which one it is or how to do it..
Everyone experiences lag from time to time. Lag is often the Xbox (Microsoft) servers themselves, however if you are always the lag source, then there are several potential issues and/or solutions:
1) Open/Closed NAT (Network Address Translation): Your NAT should be set to open or not restricted. This is not a console setting. You must log into your router to change this setting. Typically this will fix your issue (especially if game chat or joining is impacted).
Additional changes: Note: If you do not know how to make changes within your router, then get help from someone who does (parent, or write back with your router brand and model number and ask for assistance).
2) Within your Router ENABLE the UPNP setting.
3) Another option: Within your router, assign your console a static IP address. Then set up port forwarding for the following ports: 88 UDP and 3074 UDP & TCP. This way you can keep NAT closed, but allow unrestricted internet traffic to xBox.
4) If using wireless network adapter, unplug it and run a CAT5 cable from the Xbox directly to the router. If your lag issue goes away, then there could be interference with the wireless traffic. If interference, then log into router and change the broadcast channel.
5) High speed internet and traffic: You really need high speed internet (cable or DSL), close proximity to the router and bandwidth to fully enjoy online gaming. If there is a housefull of net users (Youtube, movies, music, gaming, etc..) then you can expect lag issues.
Upgrade to a higher speed package. 3 or 8 Mbps download is fine if you are by yourself, but with lots of activity, then you need 16 to 30 speed (which is really volumetric capacity and not speed). Check your download/upload speed at www.speedtest.net
6) Make sure your Modem (not router) is DOCSIS 3 and not the older DOCSIS 2 versions. Ask your ISP to check your connection for any potential problems. They can typically read this from their end.
7) Check all cable connections coming into the house, all the way to the Modem. If DSL, then check phone lines and filters.
8) Finally, and I am sure this never happens, if surfing off of a neighbors system, then stop mooching and buy your own! ;-)
Hope this helps!
Apr 22, 2012 | Video Game Consoles & Games
Xbox live lagging
try to config your new modem properly........or contact u r isp
Apr 20, 2017 | Arris SB6121 SURFboard DOCSIS 3.0 eXtreme...
I want to connect my xbox 360 to xbox live through my dsl-200 modem but it only has 2 ports, what do I do?
D-Link routers empower gamers to easily connect their Microsoft xbox to network and experience lag-free online gaming. All you need is a D-Link router to go along with your broadband connection and xbox Live subscription and you can go head to head with friends and adversaries from around the world.
The D-Link DI-624 Wireless Broadband Router, DI-614+ Wireless Broadband Router, and the D-Link DI-604 Broadband Router have all passed the tests for compatibility with Microsoft xbox Live with specific firmware. Just download the specific compatible firmware listed below to your D-Link router before connecting to xbox Live.
  • Click here to upgrade your firmware.
  • Click here for xbox Live setup instructions with a router.
  • For xbox Live support, please visit www.xbox.com.
  • Thumbs back!
    Nov 07, 2010 | D-Link DSL 200 (DSL-200) Modem
    Lagging Problem
    if your playing on seperate xboxes,then its probably because your internet is doing too much at one time
    Jan 27, 2009 | Microsoft Xbox 360 Console
    Xbox 360 live on wireless router
    In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
    Nov 09, 2008 | Microsoft Xbox 360 Console
    Arris SB6121 SURFboard DOCSIS 3.0 eXtreme Broadband Cable Modem (612572180136) Logo
    242 people viewed this question
    Top Arris Computers & Internet Experts
    Jerry
    Jerry
    bobkoure
    Level 1 Expert
    Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
