Question about Dryers
My Estate Dryer has never been hooked up until now, it comes on but does not get hot or dry the clothes at all, also it has never been used, Please tell me how to fix this problem!
It is an Estate Brand Dryer, here are the numbers i got off the Dryer.....W10136495, D433-ELD-240626-FM54,
  • epitts3823
    epitts3823 Feb 10, 2012
    Well, are you guys gonna help me or not, I'm still waiting on a solution to my problem
If the dryer comes on but does not dry, you have a voltage problem at the plug or the pig tail is hooked up wrong on the back of the dryer, get a volt meter and check the voltage coming in, you should have 240v....if for shore the dryer hasn't been hooked up or ever used. it could also be a bad heating element. but considering its a new dryer, i'd check the voltage at the plug and check the plug hook up
Posted on Feb 10, 2012
  • 66 Answers
SOURCE: wont dry
WHAT BRAND IS ( LG WP KENMOOR OR MAY TAG) I NEED TO KNOW THANKS
Posted on Apr 04, 2008
  • 1122 Answers
SOURCE: MY KENMORE DRYER WON'T DRY MY CLOTHES
you need to clean out the dryer vent hole and the wall vent hole,that is your problem it's not letting the wet hot air out-mike
Posted on Apr 01, 2009
  • 385 Answers
SOURCE: I have a whirlpool Dryer
You may have a clogged vent pipe. I would take it apart and clean it all out.If that doesn't help then you may have other problems.Could be thermostat or one bad element. Hope this helped.
Posted on May 05, 2011
TheMobilian
  • 8220 Answers
SOURCE: We have an estate by whirlpool dryer that quit
The fuse is tied into the door switch circuit and looks like this:
Unplug the dryer and remove the rear cover. All the heater components is back there.
Service manual and more info are HERE at my FixYa tip.
Posted on Jul 17, 2011
heatman101
  • 43501 Answers
SOURCE: i have a whilpool electric
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101,,.';'
Posted on Aug 10, 2011
Drier dries too slowly. it does heat up but i always have to turn on again for 40 more minutes to complete drying. it does get hot. and i am not overloading.
You do not state if you are using a machine with an automatic drying sensor. If so the calibration of the sensor is off. Try setting the control to a dryer setting. If you are using it by time only, it would appear there may be a blockage in the air outlet. Check the damper flapper at the output of the air vent. It might be partially stuck closed thus reducing the air flow around the clothes. Just a thought that your washer spin dry may not be sufficiently spin drying the clothes and so that the clothes are overly wet when put into the dryer..
Oct 05, 2011 | Estate TEDS840JQ Electric Dryer
Whirlpool Estate Eelctric Dryer Serial #MS1013289. Dryer wa working got really really hot, clothes were so hot I could not even touch them...then went to use again and it would not turn on at al. They...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Jun 16, 2011 | Estate TEDS740JQ Electric Dryer
My dryer is getting really hot in the back. when it is turned on it turns bright red in the back. The automatic setting also turns off before all of the clothes are dry. Do you know what this could be? I...
heatman101
May 14, 2011 | Estate EED4400WQ Dryer
Clothes not dryin
clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Jun 06, 2010 | Estate EED4100SQ Electric Dryer
Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Jul 30, 2009 | Estate Dryers
Dryer not drying clothes
An easy way to check dryer function is to check the airflow on the outside of your home at the exhaust the vent. While the dryer is running, and hot, put your hand near the outlet. The air coming out should be hot and forceful. If not, there is most likely an obstruction, and the whole airway should be cleaned. Keeping the airway clean and clear can dry clothes faster and save you money.
Another possibility is the blower,(fan) which can become encrusted with lint, preventing it from moving air. This is much less likely, but still a possibility.
Dec 09, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
WHERE DO I FIND THE HEATING ELEMENT ON A ESTATE DRYER
i have a estate dryer it blows hot air and drum turns but does not dry the clothes so it takes 3-4 rounds to dry the clothes what cold be the promblem
Nov 05, 2008 | Kenmore 63942 Dryer
Make sure that the flex hose going out from the dryer is not blocked. You should check it from both the back of the dryer and all the way to wear it vents outside. It could also be the thermostat, which is cheaper to replace than buying a new dryer.
Sep 08, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Dryers Logo
63 people viewed this question
Top Dryers Experts
