Question about Nady Systems SPA 2400 Amplifier
NADY SPA 2400 power amp clipping now
It's begun to clip while doing the same thing we've always done at high volumes
3 Suggested Answers
  • 417 Answers
SOURCE: Nady Subwoofer have power amp?
No.
Posted on Apr 19, 2010
  • 61 Answers
SOURCE: no sound from my 2 year old Nady MPM 4130 pa system
Very likely source of this problem is the "mixer out/amp in" jack on the back. Anything plugged in there breaks the signal path so, obviously any off board equipment plugged in there needs to be checked...but that jack itself could be faulty or even just dirty. If there is nothing plugged into it....you can get a phone plug (power off) and plug in and remove it a few times. This is a switching type jack so if the "switch" part of it isn't connecting with nothing plugged into it, the signal path would be broken and give you the results you've been having.
Posted on Aug 19, 2012
How to get sound from a nady audio 4130 mpm 4 channel power mixer
First, plug it in. Next connect the speakers. Center all eq controls both master and channel. Turn off any reverb or effects. Turn the master volume 1/2 way up. Plug a sound source into channel 1 wiyj the channel volume all the way off. Turn on the amp. Slowly raise the channel volume until you heat output. If you get nothing, it's broken.
Nov 10, 2016 | Nady Systems Music
Im running my pc through amp but tweeters start to pop at hight volume .. is there a fault with amp or pc ??
It sounds like you are over driving the speakers. Recommend reducing PC audio output, as it is amplified for the computer speakers. Use the amplifier for volume - not the PC.
Mar 18, 2015 | Audio Players & Recorders
No sound from my 2 year old Nady MPM 4130 pa system
Aug 17, 2012 | Nady Systems Nady MPM-4130 PA System
How to know the serial number of output of nady pmixer 420
Serial #s are usually on the rear or bottom of the device. # of outputs- 2 subs & Mains L&R= 4
you can find the manual below.
http://nady.com/manuals/audio/pmx420.pdf
Good Luck mixing the Next Big Hit!!
Aug 31, 2011 | Nady Systems SPA 2400 Amplifier
MY amp is going into clip mode. what is clip mode on an infinity car audio amp?
either your pushing your subs to hard and its creating a backsurge of resistance, or the spider wires are touching the frame causing them to foul out. It honestly sounds like you are trying to run too low of an impedance subwoofer, and your amp infinitys clip to keep from distorting, distortion played through a subwoofer at high volumes is damaging to the subwoofer and the amplifier. reduce your gain, and check your wires, the clipping should stop, a good rule of thumb always have an amplifer that will do rms what your speakers can do peak, so that way you can keep the amp turned up only 1/4 of the way and be pushing your subs at a decent rms volume with 0 distortion.
Aug 09, 2010 | Car Audio & Video
How to turn off the clip light is on red it does not turn off?
You can't, the clip light is just that...the signal is being clipped/distorted and the clip light comes on to protect the amp/speakers from blowing. You need to check your signal and then cables and wiring to see where the problem lies, chances are your volume is too high and your over working your amp....(turning the volume too high when the amp doesn't put out enough power for your speakers and this distorts the signal causing it to clip)...Try turnig the amp down, should not be any higher then 1/2-3/4 of the way never max. And if that doesn't work check your signal from the radio as well. If it works fine with the volume down and doesn't clip then your amp is too small for your needs and your need to invest in a larger amp for more power...Look for RMS watt ratings at 12-14 volts not max watts at like 16-18volts (those are fictious #'s and those amps should be avoided)
Nov 02, 2009 | Crest Audio CA9 Car Audio Amplifier
Excess clipping on nad 372 amp
อิอิ ขอบคุณคับ
May 24, 2009 | NAD C272 Amplifier
Subwoofer clip/distort problem
It's probably the amp in the subwoofer. Bad cable don't cause clipping. Nor, is an amp output likely to overdrive the subwoofer.
On second thought, why are you using an amp with it turned off? Have you tried turning on the amp whcih provides the signal to the subwoofer? That could well be your problem.
May 05, 2009 | Audio Players & Recorders
Nady Systems SPA 2400 Amplifier Logo
32 people viewed this question
Top Nady Systems Audio Players & Recorders Experts
Michial Gueffroy
Corey Bartlett
Level 1 Expert
Robert Graf
Are you a Nady Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
