Question about Sony BM-840T Desktop Cassette Transcriber / Recorder
No sound from the external speaker.
When I listen to my tapes, I can only hear the dictation by using a headphone set. When I unplug the headphone set, there is no external sound. I generally don't like using the headphones since I listen to 10 hrs of transcription. Anybody, please advise??? Thanks so much.
0 characters
1 Points
Can't hear recordings on micro cassette,plays cassette & speaker works.
Has the tape been erased by being placed on or near a magnetic field such as a speaker or TV?
Did you plug the mic into the mic input?
Apr 16, 2014 | GE 35375 Handheld Cassette Voice Recorder
Philips dictation
This is normal. You need to disconnect the recorder or Select Settings, then Sounds and device audio properties to change the playback device.
Nov 20, 2013 | Voice Recorders
While dictating on the Lanier VW-260, the machine suddenly starts beeping - a rapid series of beeps, as if the tape is at the end. We thought maybe it was a bad tape. But that is not the case. It keeps...
Hello the alarm that you are listen is the end of the tape alarm the reason it detect a fast motion and is warning you that the tape is almost to the end but if you don't agreed that the tape is almost to the end your unit needs service you can Send an email to or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Apr 14, 2011 | Lanier 260T Desktop Cassette Voice...
When i put a tape in to transcribe it sounds garbled. Do you think it could use a cleaning?
1. Try to change the tape speed on your machine. Sometimes that will fix it.
2. Maybe the tape is just old (has been dictated on too many times) and in that case, have the person dictate on new tapes and discard the old ones. They dont last forever.
Hope I could help!
Feb 05, 2011 | Sony BM-147 Desktop Cassette Transcriber /...
We have 6 month old Philips LFH9380s where the quality of recording has deteriorated - words are merging together and becoming unintelligble.
Hello if you are using your unit for dictate you probably need to change the mini tape but if you are using your unit for transcribe just clean the head with Alcohol you can purchase mini tapes for your unit at
Nov 09, 2010 | Philips LFH-720
Unable to understand how to dictate and play back
It may seem too obvious, but make sure the volume control is turned up fully. If you do not hear a click through the loudspeaker when pressing the record button then either the 'speaker wire has broken or the 'speaker itself is dead. Parts are still available.
Mar 19, 2009 | Philips Pocket Memo 381 Handheld Cassette...
When boss dictates a letter I can barely hear any sound!
The tape might be getting old, replace it and see what happens.  If it is still acting up, It might be he is not recording properly or the recorder is bad.  Try talking directly into the mic and see if it is better.  If it is, he needs to talk louder or needs to hold it close.
Mar 04, 2009 | Dictaphone 3225 Handheld Cassette Voice...
Lanier tape dictation machine
are the Best
Jul 01, 2008 | Voice Recorders
Sony BM-840T Desktop Cassette Transcriber / Recorder Logo
14 people viewed this question
Top Sony Voice Recorders Experts
Mike McWhinney
Are you a Sony Voice Recorder Expert? Answer questions, earn points and help others
