Question about Kingston Electronics - Others
How to fix an undiscover thumb drive(Kingston 4gb)
When i insert the THumbdrive, the windows sounds that the Thumbdrive is inserted and do installation, but when i opened up My Computer, the Thubdrive icons won't shows up. Ihad tried it so many times, and the results is same. Please Help me....
  • Kingston Master
  • 27,725 Answers
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Posted on Feb 17, 2012
4 Suggested Answers
SOURCE: Thumbdrive not working
I received no response from you, so I contacted another organization. They have communicated with me letting me know they are working the problem. I have no inclination to either ask for your assistance or refer you to others in the future.
Posted on Sep 11, 2008
SOURCE: Computer reboots when i connect my Thumbdrive
More then likely you have a defective thumbdrive,buy a new one and see if you still have the problem, you can all ways take it back if you still have the problem, Remember new ones can also be defective.
Posted on Mar 03, 2009
  • 10 Answers
SOURCE: lexar jumpdrive firefly 16GB I've deleted
First of all try a data recovery program such as Wondershare Data Recovery to get the deleted files back. Get the program here,
Data Recovery Windows (for Windows OS)
Data Recovery Mac (for Apple Mac OS)
Then format the pen drive from Disk Management if you are running Windows.
Remember - Do NOT try & write anything back to your pen drive until you can recover your data safely!
Posted on Feb 11, 2011
Hi there, I have just installed 7.10 and I would like to upgrade to the Ubuntu latest version... How can I do that? Can I dowload it or should I order the install CD? Many thanx,*
11.04 is the most stable and current version. You can upgrade from 7 to it with a thumb drive, and an installed program.
Go to the Ubuntu Website and download 11.04 iso.
Download and install UNetBootin.
Insert your thumbdrive, format it.
Open UNetBootin.
Select "Disk Image" then locate the location of the 11.04 iso you downloaded.
Then at the bottom, select your thumbdrive, and click OK
This will then get your thumbdrive bootable, and install 11.04 too it.
Once that's done. Shut down your computer, boot from the thumbdrive, and follow the upgrade instructions.
Best part, about "Upgrade". It'll 99% of the time keep your documents intact and just update the software.
Sep 25, 2011 | Canonical Ltd. Ubuntu
Windows xp cannot detect kingston datatraveler II
Hello there,
Try plugging your kingston usb thumbdrive to a different usb port and see if the system detects it. If it does not, try restarting your computer then try it again. You can further isolate the problem by plugging the kingston to another computer's usb. If all did not work, then your usb thumbdrive is fried due to not being able to properly disconnecting it from the computer (doing a "safely remove").
Thank you for using FixYa. Merry Christmas.
Dec 25, 2010 | Computers & Internet
Where on the kingston usb data traveler 4gb circuit can I find the write protection switch. Can you send me a schematic diagram of its position and how to switch it. thank you
plug the drive into your computer
open computer..i.e. where is shows your drives
right click on your thumbdrive
select properties
uncheck the box for read only
Dec 16, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have uninstall the URDRIVE software and deleted it from my thumbdrive. But now, i want install it back into my thumbdrive and i don't know how and where to get the urdrive software.
If you format your drive you will lose the urDrive software.
Get another copy here: http://www.kingston.com/support/urdrive/urDrive_1.1.(124)_GA.zip
Installation Instructions:
Once WinZip opens (or an alternate compression tool), highlight all of the urDrive files and extract them directly to the Kingston drive.
Oct 06, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Mi portatil thoshiba no lee mi sd 4g despues que le puse w7
Hablas ingles? Yo intiendo que usted tienes problemas con su 4gb SanDisk Thumbdrive y su Toshiba laptop despues que puses Windows 7.
Usted tienes dos alternativos. 1. Reforma su SD 4gb Thumbdrive con Windows 7 2. Retorna su Toshiba a Windows XP
------------------------------------------------------------------------------------------- Traducion en ingles:
I understand that your SD 4gb Thumbdrive isn't working with your Toshiba laptop after you upgraded to Windows 7. You have two possible alternatives: 1. reformat your SD 4gb Thumbdrive using Windows 7 to format. 2. Go back to Windows XP, or whatever operating system you were using before the upgrade.
Aug 03, 2010 | SanDisk 4GB microSDHC Memory Card
Pen drive not been detected by laptop.
try connecting it to a diff. usb port.
most likely problemis that the drife may have malfunctioned.
Mar 15, 2009 | Kingston 4GB Secure Digital High Capacity...
How to format unreadable usb to use it again?
go to control panel in windows xp and go to administrative tools, then click on computer management
then click on disk management and find your thumbdrive on there then you want to re partition it then
format it
Mar 03, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Unable to access thumbdrive
It is possible that windows is trying to assign a drive letter to the thumb drive that is already assigned to another drive. You will need to go to Disk Management to see if the thumbdrive is showing up there and then try to assign it a drive letter.
Feb 07, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Usb device not recognized
If your laptop is running Windows ME, 2000, XP or above, it should automatically do the New Hardware thing, and mount the drive. If using Windows 98se, you can probably get the drivers from the vendors web site.
Sometimes a usb port will not provide enough power for a specific device. Does the thumbdrive work in other computers? And do other USB devices work when connected to the laptop?
Feb 06, 2008 | Toshiba Satellite A135-S2276 Notebook
Electronics - Others Logo
51 people viewed this question
Top Kingston Electronics - Others Experts
Jerry Umali
Tony
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
