Question about Amana Refrigerators
I have an Amana Model TC 22 refrigerator, with frost-free freezer on top. It's about 18 years old. Inside the refrigerator, top left (the underside of the freezer floor), there is an opening with a few slats. Lately, ice cold water has been dripping from that opening into the refrigerator. It's as though the water that should be channeled from the freezer to the catch basin near the floor is emptying into the refrigerator instead. What do I need to do?
aborcass
  • 2651 Answers
SOURCE: Kenmore Model 78185891 type C21TFA95, water leakage problem
you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Feb 25, 2008
  • 1073 Answers
SOURCE: Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Posted on Apr 12, 2008
aborcass
  • 2651 Answers
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Posted on Jan 11, 2009
Bat1956
  • 585 Answers
SOURCE: drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
Posted on May 20, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
I have a three year old Amana bottom freezer double doors 25 cu ft. The freezer is working fine but the fridge is not cooling at all. I tried defrosting had it unplugged for two days. Tried cleaning the...
There is an evaporator fan locateed inside top of the freezer compartment. It is normally hidden behind a plastic cover. It should be running whenever the Fridge is calling for cooling. Check to see if this fan is running. My suspicion is that it is not running. Replace this and you should be back in business.
You will see the fan assembly at the bottom right corner of the picture.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174550&diagram_id=28601573#d28601573
Apr 24, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
My amana upright gets cool but not cold enough to freeze probably not even as cold as a fidge. the problem started when we moved and stored it out in a shop that was partially heated. since then we have...
Good day,
Somewhat handicapped not knowing if it's a conventional freezer or frost free.
1. If it's frost free check to see if the fan motor is running in the freezer compartment.
2. As well if it has a fan motor in the compressor compartment, see if it is running as well.
3. If it is a conventional model, make sure it is turned on and make sure it is running. If running, then it has lost it's refrigerant charge or the compressor has lost it's pumping capacity.
4. If it is item 3, then unless it's less then 5 years old, the sealed
system/compressor problem is so pricey that it's not a practical repair. If under 5 years Amana will pay for these repairs, whether it's conventional or frost free.
Nov 04, 2009 | Amana 15.0 cu. ft. / 425 liter Upright...
Freezer building up with frost
Sounds like the defrosting system has a faulty timer/board, faulty heating element or bad electrical connections to these components.
More info, let me know...
Charlie
Aug 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Is there a way to disable the frost-free feature on amana freezer
If you disable the frost free feature you will have to defrost every 10 days.
But, yes,it can be done.
Aug 05, 2009 | Kenmore 53542 / 53544 Side by Side...
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
Mar 16, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer frost
An upright freezer that is not frost free will have the coils in the shelves (shelves are non-removeable) and that is where the frost will buildup.  If your model is like this then it will have to be defrosted periodically.  If your not sure then give me the entire model # from the sticker inside the freezer and I will look it up for you.
Oct 16, 2007 | Amana 19.7 cu. ft. / 558 liter Upright...
Refrigerators Logo
80 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
