Question about Vacuums
Retractable cord on the Intuition 28014700
How to make repair the retractable cord so it will stay out when pulled.
4 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: retractable cord
Replace the cord reel
Posted on Jun 02, 2008
  • 694 Answers
SOURCE: How do I repair my
First, try standing vacuum on it's back end. Gently pull on cord and release. Try this a few times.
If this doesn't work, you'll need to take it to an authorized Aerus Electrolux store and let the service tech repair it. Although it's relatively easy to disassemble, reassembling correctly is trickier. I've had several machines come into the shop disassembled because the owner couldn't figure out how to put it together again.
Also, when taking the cord rewinder apart, there's a risk of breaking tabs that hold it together.
http://www.aerushome.com/storelocator/
Posted on Dec 19, 2010
Daniel S
  • 4323 Answers
SOURCE: Kenmore Model 116 28014700 intuition
Hi
To remove the broken part from the latch use a small screwdriver to release the tabs on the latch on the connector. When latches are released the latch assembly and the plate will slide out of the connector. When the plate is removed the adapter and hose will slide off the connector. Release the tabs that hold the hose to the adapter and put the hose on the new adapter.
You need to position the terminal plate inside the adapter before sliding the adapter and hose on the new connector. The latch and terminal plate have to slide under the small guides on the connector. Its reverse of removal. Please check the pictures in the below link, it may help---
Link 1
Link 2
Link 3
Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 06, 2011
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Sep 17, 2016 | Bissell Vacuums
Simplicity mode l8526L pull cord wont retract
The retractor has failed. You will have to disassemble the machine, find the retractor and repair/replace it.
Jul 12, 2016 | Simplicity Vacuums
VC248. Why won't the cord retract?
Vacuums today are most all plastic parts, and you have likely accidentally broken the retractor. Very highly likely you will be wrapping the cord around the machine from now on, as the repair parts are probably not available.
God bless your efforts.
Sep 07, 2015 | Cirrus Vacuums
Repair retractable cord
Depending on which model of Electrolux you have and how far out you have pulled out the cord (most of the Electrolux canisters have a yellow tape around the machine end of the cord to alert you not to pull it out any further), you might have to take it apart to fix it. However, the first thing that I would try would be to stand it on the end (the hose end at the top), and pull short jerks on the cord to see if it will correct itself and retract. If that does not fix it, I would stick a screwdriver in the hole where the cord comes out of the machine and attempt to wind the cord reel back up which will slowly wind the cord back up on the cordwinder. This usually cause the cord to wind back up. If that does not work, then the only option is to take the machine apart to fix it.
Dec 11, 2013 | Electrolux Vacuums
The power cord does not retract or rewind when the button is pushed. How can I repair this?
Sometimes you can help get the springs working again, by gently pulling the cord out a little further and then let it slowly in while pushing the cord retract button.
Nov 08, 2012 | Kenmore 25512/ 25513 Progressive Canister...
How do I repair my Electrolux Lux 9000 cannister electrical cord retraction? It was pulled out as far as it would go and now it doesn't retract.
Dec 19, 2010 | Electrolux Lux 5500 Canister Vacuum
Hoover UH70120 WindTunnel TSeries problems with the cord. im a tech savy guy and have been trying to fix a cord after it was pulled to far out and now wont auto retract, but just cant find a way to pull...
You will probably have to replace the cord winding mechanism. I have never had any luck trying to repair one. Cord retracters are great when they work but it seems like they always go bad before too long. On many units you can't even replace the cord if you get a bad spot in it, you have to buy a new cord reel which can get expensive.
Jul 21, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
Cord has been hyper extended, will not retract
try pulling the cord a little, while holding down the cord release button. if nothing happends and it doesn't retract, suggest taking to a service center or your local vac shop for repairs.
Jul 16, 2009 | Electrolux Epic 6500 Vacuum
Electric cord won't retract
Depends on the machine. If its a Sebo K model then usually pulling on the cord will re-automatically retract the cord anyway. Any other brand and it will need to be replaced by a qualified repair.
May 06, 2009 | Vacuums
Vacuums Logo
47 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
