Question about Eforcity Video Game Consoles & Games
Adequate Silicone Cover for BigBen Interactive Balance Board for the Nintendo Wii console
I have BigBen Balance Board and I can not find adequate silicone skin. The problem is that all skin I have found are designed for Nintendo Balance board which is little lower than Big Ben and it is little curved on all four sides. When I put such silicone cover it does not fit easily and pins on corners part do not go in the holes around weight buttons. Does anyone know where can I find fully compatible silicone skin for my BigBen Wii Balance Board. Thanks in advance.
3 Suggested Answers
SOURCE: US Wii Console with Wii Fit (PAL)
Go to a Game store, bring your Wii, ask him/her to put a modchip or WiiKey in it so it works any Wii games (Japan, Europe Wii games) even Burned Wii games...
Posted on Nov 29, 2009
  • 19 Answers
SOURCE: communications with the wii balance board interrupted
dont push your feet hard or the batteries might come off of the cap isnt put on or the batteries are fully used
Posted on Feb 13, 2010
How to configure gameon balance board with wii console
1. You need to put Balance Board compatible game disk in the console.
2. Select Disk Chanell and press Start
3. Remove SD Card slot cover on the console and the battery cover on the Balance Board
4. Press and hold for 2-5 sec the SYNC button on the Balance board. You will see a blinking light.
5. Press the Sync button on the Wii console and after a while you will get non-blinking light.
This will mean that your device is synchronized and you are able to use your Balance Board.
Good Luck!
Don't forget to close back the covers you've removed earlier.
May 23, 2012 | Nintendo Wii Fit - Balance Board + Game...
How to connect wii fit board to the wii
Important Note!
Do Not use "One-Time Mode" sync.
Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off.
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.
7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
Nov 16, 2011 | Nintendo Wii Fit for Wii
How can i re connect the wii fit balance board to my wii ?
Synching can be completed only if a compatible game disc is running in the console. Compatible game discs (such as Wii Fit) will display the Wii Balance Board icon on their packaging.
The Wii Balance Board must be synced to each compatible game individually.
Follow these directions to sync the Wii Balance Board (so that it is recognized by the Wii console):
Insert a Wii Balance Board compatible game disc (such as Wii Fit) in the Wii console.
Mar 16, 2011 | Nintendo Wii Console
How do you sync the wii console and wii fit board
Put the Wii Fit game disc in the Wii and start the game. Then open the small SD Card slot cover on the front of the Wii console then remove the battery cover on the bottom of the Wii Balance Board. Press and release the SYNC button on the Wii Balance Board. The light on the board should start blinking. Afterwards press and release the red SYNC button on the Wii console while the light on the board is still blinking. The light on the balance board will stop blinking and stay on steady once the syncronization is successful.
Mar 03, 2011 | Nintendo Wii Console
How do you sync the wii fit board and wii console
  • Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
  • Insert a Wii Balance Board compatible game into the Wii system.
  • Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
  • Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
  • Turn the Wii Balance Board upside down.
  • Remove the battery cover under the balance board to reveal another sync button.
  • Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
  • Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
  • Mar 03, 2011 | Nintendo Wii Console
    When sychronizing the wii balance board we held the sychronize button down to long and now the wii remote control won't work how do we fix this
    2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
    3. Open the small SD Card slot cover on the front of the Wii console.
    5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
    6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
    7. The blue light will stop blinking and stay on steady once the synchronization is complete
    Click here to download repair guide
    Jan 05, 2011 | Nintendo Wii Console
    I can not re start my nintendo balance board,
    7. The blue light will stop blinking and stay on steady once the syncronization is complete
    Dec 20, 2010 | Nintendo Wii Fit - Balance Board + Game...
    I have a wii balance board, the batteries ran out so i changed them -now the board will not work. Ive tried pressing the red buttons together but still no joy. my neighbour is having the same issuses. Why...
      Try these steps!
    click here to download repair guide if u need
    Dec 17, 2010 | Nintendo Wii Fit - Balance Board + Game...
    MY WII BALANCE BOARD IS CHARGED BUT THE BLUE LIGHT WONT STAY ON.
    7. The blue light will stop blinking and stay on steady once the syncronization is complete.
    click here to download repair guide if u want
    Dec 15, 2010 | Nintendo Wii Fit - Balance Board + Game...
    My wii fit balance board keeps blinking but will not stay on. batteries are good. cant find my instruction book. what could be my problem????
    follow this
    Jul 20, 2010 | Nintendo Video Game Consoles & Games
    Video Game Consoles & Games Logo
    67 people viewed this question
    Top Eforcity Video Game Consoles & Games Experts
    James Wishart
    Are you an Eforcity Video Game Console and Game Expert? Answer questions, earn points and help others
