Question about Thetford Norcold RV Cooler/Freezer
Norcold fridge model 982 wont get cold, and throws a code A6 and A8
My fridge wont get cold, keeps throwing a code A6 and A8, i went out to check the power supply...i got 120 in to the 2-way power board and nothing coming out to the ac heater wires, the 5 amp fuse is good! , then i checked the 12v incoming and i have 13.4v there but nothing coming to the gas valve and the ignighter is'nt working on auto gas or gas so the fridge doesn't work at all......STUMPED!!!!! thank you
5 Suggested Answers
  • 68 Answers
SOURCE: fridge wont get cold with gas
This is worth a try. Disconect the gas and power make sure the pilot light is out. Turn the fidge unside down overnight then unright again. Try it on gas agian. This worth a couple of goes before giving up.
Posted on Aug 30, 2009
  • 332 Answers
SOURCE: My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Posted on Mar 15, 2010
SOURCE: Norcold model 1200LRIM. Unable to
Try to unplug it from the battery a few hours and then plug it back in and see if you are now able to select the AC or LP mode. There has been a recall on the 1200LRIM, The defect is a potential cooling unit leak caused during AC electric mode operation. Click on the link below to read more:
http://www.texastriallawyer.com/norcold/index.html
Posted on Nov 21, 2010
tunde007
  • 2382 Answers
SOURCE: Model 12110 IM Norcold-not cooling
Hi, if the burner lights in the 'gas' mode, the control board is OK. You most likely have a leak in the sealed refrigerant system, and you need to have the leak located and repaired. This is a job for a RV refrigeration technician. If you need to find the nearest Norcold authorized service dealer, go to www.thetford.com, and use their dealer locator menu.
Posted on Apr 13, 2011
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
Why does my Norcold fridge on Jayco 2014 come on but does not get cold?
if chimney cold check heater element and LP for flame if chimney hot unplug thermistor from control board let run if gets cold replace if not either bad board or cooling unit
May 16, 2014 | Thetford Norcold RV Cooler/Freezer
My jeep keeps throwing a 1281 code I have changed thermostst twice 195 deg I put a new coolant temp sensor in also but still keeps throwing this code
CODE PO1281 ENGINE IS COLD TOO LONG.INSPECT FOR LOW COOLANT LEVEL OR AN INCORRECT MIXTURE.USE CODE SCANNER TO ERASE CODE.AFTER YOU MAKE A REPAIR ON ENGINE YOU NEED TO ERASE CODE OR IT WILL KEEP TURNING ON.
Apr 25, 2011 | 2003 Jeep Wrangler
I have a Norcold 611 and the freezer works fine, but the refridgerator wont get cold. Any answers?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | Thetford Norcold RV Cooler/Freezer
Norcold N1095 model stopped working during very cold weather spell. No defaults codes at all showing--just will not cool down. AC and LP both work fine. Refrig just stopped cooling. Contacted norcold...
I have the same problem with my extra fridge in the garage. It has to do with the oil used as a refrigerant in newer models. The cold temprature thickens the oil and it stops cooling. Nothing you can do about it other than opening the door to the fridge to warm the insides up. It works for me. And thank god it's only when it gets very cold outside that this happens. Ps...my garage is insulated and drywalled and it still occors during cold spells.
Dec 17, 2009 | Refrigerators
RV model norcold n811rt not cooling
I have a norcold fridge model #N811RT and the flash code blinks 5 times then stops then repeats. both fridge and freezer are not cold were are currently living in are 5th wheel and it was currently -30c for 3 days any help would be of assistence.
Colin
Aug 03, 2009 | Migali Refrigerators
Norcold model number N621 won't power on
its difficult to explain the dc are going to the thermostat and from the thermostat to a element that warms the outside to make cold in the inside does it have a pc board or not be free to ask questions
May 26, 2009 | Refrigerators
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Refer Norcold DE 0051 not getting cold
Your cooling unit is shot, I suggest. Most likely, you've lost the R341 refrigerant. Norcold, so they can sell you another cooling unit at $500+, does not make these little fridges with a service port so you can recharge the system. Same with Dometic. Solution is to spend, again, $500+ for a new sealed unit that will fail in relatively short order (I'm on my second in five years) or buy a better refrigerator. I'm opting for a new fridge this go around (Vitrifrigo). Vitrifrigo has the needed service port.
Dec 28, 2007 | Thetford Norcold DE0051 Refrigerator
Thetford Norcold RV Cooler/Freezer Logo
300 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
