Question about Primavera SureTrak Project Manager 3.0 for PC
While installing suretrak on windows 7 I get following message: Unable to find a Serial number Please make sure that files in the program or work directory as specified in the registry are not mark read only
3 Suggested Answers
SOURCE: When installing I receive an
To all that run into this problem like I have, here is the solution:
To install Suretrak 3.0 if you get “unable to find serial#” error:
  1. Temporarily Stop the Pervasive Sql Server Workgroup engine
  2. Install Suretrak
  3. After installation, copy wbtrcall.dll and wbtrv32.dll from the c:\pvsw\bin folder and paste to c:\windows\system and c:\windows\system32
Restart computer; all should be working now
Adrian (byrdadrian@yahoo.com)
Posted on Oct 19, 2009
  • 197 Answers
SOURCE: When I try to log
go to the security up dates web site and update the updates it shald fix part of the problem as well you mite have to close the old file as it mite not have done that
Posted on Mar 19, 2011
"idm has been registered with
The problem seems to be with the serial key you provided for IDM. IDM blocks every pirated serial key and it is the reason you are getting the above message.
The solution this problem has been given by techforum4u.com
The solution for this problem is not easily available and the only step the user left with is uninstalling the software completely. Even after several installation and uninstallation the problem exists unless you format your computer.If you want a permanent and exact solution for this problem follow these steps:-
1. Exit IDM from the taskbar before entering the serial.
2. Disconnect active connections to the internet.
3. Then go to the directory C:\Windows\system32\drivers\etc and locate the file 'hosts'
4. Open the "hosts" file with "notepad".
5. on the last line enter the following address as shown and save.
127.0.0.1 www.internetdownloadmanager.com
6. Now, again enter the "fake serial" and wait for few seconds.
7. your IDM is registered again.
8. No wonder you would be facing this problem again but without panic use a "new fake key" ( this time steps 3,4 and 5 are not required, the only thing required is "a keygen" for generating a new key. For IDM 5.14 Dr.Carbon Keygen is used ).
Mar 22, 2011 | Computers & Internet
When I try to log in to open suretrak I get the message "?Unable to find a serial number. Please make sure that the files in the Program or Work directory, as specified in the registry, are not marked...
Mar 17, 2011 | Primavera SureTrak Project Manager 3.0 for...
Unable to use Micrografx Picture Publisher 10.0 with Win 7
Make sure that Micrografx Picture Publisher 10 pro installs into the X66 Program files folder.By default it will always install into the 64 bit program file if you have a 64bit installed.
If you have the 32 bit Windows 7 installed then right click with your mouse on the program before opening it up and select compatibility mode.Select XP SP3 compatibility mode.This works fine on my Windows 7 32bit. Use the first paragraph method if you have the 64bit Windows 7.
Regards Brian
Feb 14, 2011 | Micrografx Picture Publisher 10
I originally ran my Suretrak on Windows xp. I have now loaded it onto my new computer running Windows 7 Home at 64bit. The program is not completely functional. Is there an upgrade or fix that resolves...
Suretrak is not fully compatible with Windows 7. We have talked to Primavera on this issue and they say they will continue to support Suretrak for at least another year but have no plans to upgrade Suretrak to the Windows 7 platform.
Aug 11, 2010 | Primavera SureTrak Project Manager 3.0 for...
Serial key for idm not having
Internet Download Manager Registration serial nomber 6.12
May 13, 2010 | Computers & Internet
After clicking print to PDF a schedule, Suretrak shows error message that says Suretrak Application Manager has encountered an error and needs to close. No other info.
I would try reinstalling the software. Sounds like a file got corrupted. If that does not fix it:
Have installed the latest patches for SureTrack?
Have you updated Windows?
If so, did the problem start after one of the updates?
Mar 11, 2010 | Primavera SureTrak Project Manager 3.0 for...
When installing I receive an error message "Unable to open serial number file". After the install, if I try to open the application I receive the error "Unable to find serial number. Please make sure the...
  2. Install Suretrak
Jul 24, 2009 | Primavera SureTrak Project Manager 3.0 for...
Nero 7 essentials disc but when i try to install it it comes up with message this version dose not support vista
Windows Vista is supported by Nero 7 since the version Nero 7.5.7.0.. Older versions of Nero 7 do not support Windows Vista. If you are trying to install Nero 7 from your original disc it is likely that there is an older version included on this disc. If you want to install Nero 7 on Windows Vista please be sure that you will only use latest Nero 7 version, you can download from the below website. Also please be sure that there won't be any rests of old Nero 7 versions on your system by performing the following steps:
1.
Start uninstalling all old Nero 7 applications and files from your computer using the Nero 7 CleanTool
Download the Nero 7 CleanTool using the following link:
Click here.
Save this file to your desktop.
Unzip the ZIP-file with WinZip or WinRAR and save the content to your hard drive.
Double-click on the unzipped EXE-file to start the CleanTool.
The window “Nero General Clean Tool” will open. The installed Nero version will be displayed.
Activate the checkboxes in the displayed Nero version.
Then click the “Clean” button.
A status window will open.
The execution of the tool may take several minutes.
Please wait until the progress bar has moved completely to the right.
In the window “Nero General Clean Tool” click the “Exit” button as soon as the erasing procedure is completed.
Reboot your computer.
The Nero 7 CleanTool has removed all Nero entries from your computer.
2.
To install the latest Nero 7 version, please proceed as follows:
(Note: do not install a previous Nero 7 version from an installation CD now, but download and install the latest version of Nero 7 from our website. All Nero 7 download versions have the full range of functions as an original Nero 7 installation CD. There is no need to install a previous version of Nero first.)
Download and install the latest Nero 7 version from website using the following link:
Click here.
Double-click the downloaded Nero 7 installation file to start the installation.
Enter your Nero 7 serial number during the installation to make your Nero into a permanent version. (The download without a serial number is a trial version only).
You now have a newly installed version of Nero 7 on your computer.
Jul 17, 2008 | Computers & Internet
Open Questions:
See all Primavera SureTrak Project Manager 3.0 for PC Questions
Primavera SureTrak Project Manager 3.0 for PC Logo
55 people viewed this question
Top Primavera Computers & Internet Experts
Tom Chichester
JEfromCanada
john smith
Are you a Primavera Computer and Internet Expert? Answer questions, earn points and help others
