WHAT MEANS F-43 ON THE SCREEN
POWER ON, MACHINE DOES NOT START, INTERMITTENT BEEPER, SCREEN SHOWS F-43
    Problem Solver:
  • 29 Answers
According to the service manual, F-43 flashes if the motor control detects a low voltage condition. This error code could also be caused by poor air flow, loose wiring harness or a malfunction of the electronic control board.
You can disconnect the vent hose from the back of the dryer & compare that airflow to the airflow at the outside damper, they should be almost the same.
For the other checks I would recommend calling a service technician to diagnose & repair.
Posted on Feb 10, 2012
My machine shows F:43 . What is the problem?
try to run test program if it won't help - service. F:43 is a fatal error. it could be short-circuit rotor broken engine etc...
it won't dissapear on it's own.
Oct 20, 2015 | Washing Machines
My toaster oven started beeping and showed a flashing error message. Anyone have any clue what may be wrong?
I suspect that the Logic Control Board is shot. If the unit is 1 year old or less try:
In the U.S.A., warranty is offered by Sunbeam Products, Inc., located in Boca Raton,Florida 33431. 1.800.334.0759
In Canada, this warranty is offered by Sunbeam Corporation (Canada) Limited,located at 5975 Falbourne Street, Mississauga, Ontario L5R 3V8
To refresh, the beeper should sound once. The definition of the Beeper from the manual follows:
BEEPERFUNCTION
(1) When you plug the unit in, the beeper sounds once and " - - - "appears in the LCD.
(2) When you press one of the four menu buttons the beeper will sound one time.
(3) When you press the adjustable button, every time you press the button, the beeper
will sound once. If you press the button continually, the beeper only sounds one time.
(4) When you press the start button the beeper will sound once, and ":" will flash, that means
the unit is in operation. Once the unit has begun the cooking cycle, the menu selection,
time or temperature cannot be changed. The unit must be stopped and reset.
(5) When the unit is in operation, press the stop button, the beeper will sound once and the unit
will stop operation.
(6) At the end of pre-set time, the unit will sound a long beep to remind you the work is done.
Jan 03, 2015 | Oster 6239 Toaster Oven with Convection...
Reversing beeper has constant beep
The easiest possibility is that the proximity sensor thinks something is constantly very close to your bumper. Assuming you don't have any weird stuff hanging off your car that could confuse it, the sensor is likely damaged.
Oct 20, 2014 | 2008 Toyota Camry
Windows error code 43
known problem, that might be fixed by a cold start. switch off your PC or laptop completely. even pull the power lead from the wall, (in laptop remove power supply and battery once switched off) wait a few minutes and power up and start your machine.
I hope this was helpful
Oct 31, 2013 | Computers & Internet
Switch on it shows "test" and cannot programme
It depends on what date the machine was manufactured. The date should be on the plate which is probably in an awkward position on the back ;-0(
Date code 39 March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39 March 2005 to date code 42 June 2005
Press the cancel button and the machine should return to normal
Date code 43 July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
John C
Mar 22, 2011 | Hotpoint Aquarius WD640 Front Load...
Spin Led stays on and beeper beeps
this spin light that is on is a fault code no:1 which means the electronic motor control has a memory problem solution replace motor control module ... hope this helps..:0)
May 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
GW9200L Keypad / Diagnostic test shows code 06
troubleshoot whirlpool duet dryer GW9200 Press the start button and the beeper sounds once and you hear a relay trip but nothing happens. Did a diagnostic / keypad tes and the code was 06
Feb 07, 2009 | Whirlpool GGW9200L Gas Dryer
Fisher and paykel intuitive washer what is a code 43 please
code for out of balance oob switch probably needs replacing if load wasn't off to one side.
Jun 20, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
