Question about Troy Bilt Backpack Blower, 25cc, 160 Mph, 500 Cfm, Model No. Tb25bp
Tb25bp owners manual - Troy Bilt Backpack Blower, 25cc, 160 Mph, 500 Cfm, Model No. Tb25bp
Bignition modual gap spec
The gap is to be set at 0.10, usually a business card works well for this.
Have fun.
Nov 12, 2010 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
I need the ignition coil gap. Got a new one and it almost started. I have a feeling that the business card may not have been the right one. Please help
The gap is set about .010-.014" The closer you can get it, the better it normally is...just don't set it so close that it is almost rubbing.
Aug 13, 2010 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
TB BLOWER 25CC WHATS THE OIL/FUEL RATIO MIX???
Try 40:1. Better to have too much oil than too little. If you find the exact ratio then use that. ...Lee
Mar 12, 2010 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Trigger broke
Go to
www.mtdproducts.com
1) 'find parts now'
and enter your model number
you can locate the part you need, and buy it directly from MTD
Nov 21, 2009 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
25cc TB25BP new plug, new Gas, Clean Carb.. will not start
Check Make sure its the right plug.- Check for stuck choke-Check.Air/fuel mixture screws out of adjustment.
Sep 22, 2009 | Troy-Bilt 25cc 2-Cycle Backpack Blower...
Replacement suspension for the troy-bilt back pack leaf blower
http://www.troybilt.com/webapp/wcs/stores/servlet/topcategory_10001_14102_-1
Jul 30, 2009 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Leaf blower will not achieve full RPM's
try removing the muffler and scraping out any carbon build up in the exhaust mouth of the block. if that doesnt help you will probably need to replace the carb.
Nov 15, 2008 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Troy Bilt Backpack Blower, 25cc, 160 Mph, 500 Cfm, Model No. Tb25bp Logo
206 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
