Question about Whirlpool Ovens
My whirlpool stove RF365PXMQ0 will not heat up the top burners or the oven. What could be wrong?
Need to get a volt meter and check the incoming power( at the plug ) and make sure you have 240 volts!! it only takes 110 volts to run the top burners, and takes 240 volts to run the oven!!
Posted on Feb 10, 2012
SOURCE: GE P7 Oven 2 burners out on stove top
Purchased a new stove.
Posted on Dec 27, 2008
  • 22 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
johnrodgers1
  • 73 Answers
SOURCE: my oven wont heat up at all. gets no gas. the top
your glow coil is wron out , need to replace it, you may see it glowing in there but it isnt getting hot enough, usually you can switch out the broil one for a quick fix to get you outta truoble. easy do it yourself problem
Posted on Feb 05, 2010
SOURCE: The oven will not light on my Whirlpool gas oven
Our whirpool glass top range elements all stopped working.The indicator lights on the back panel light up but the elements will not heat.We were using all four range top heating spots and the oven when the range top stopped working.Checked the circuit breaer and it was fine. I tried to locate a fuse for the range top but had no luck,range is about 7 years old
DAW983
Posted on Feb 15, 2010
  • 99 Answers
SOURCE: DCS 5 burner 30" oven makes loud noises as if starved for fuel
Hi; Is the oven run with LP or NAT gas. Sounds like a regulator problem not letting enough gas through. Also is this a comercial unit. If so when was the last time all burners and pilot orafices were cleaned out. The burner tubes have a air vent cut into the burner at the orafice. Make sure no debris have covered these airways.And lastly how old are the thermocouples and are they secure to the gas valves and have a good pilot flame on them...
alpharome416
Posted on Feb 23, 2010
I have a whirlpool 465 super capacity stove. the top burners seem to have a mind of their own. 1 in the back doesnt come on at all and the other go to high heat even if i set them on low settings
No solution, just that you are not alone. We have had our Whirlpool super capacity 465 for 10 years, and about a year ago that large burner started to randomly go to high, even though the control is set to simmer. Ruined a few meals by not being right there watching.
Apr 21, 2011 | Whirlpool RBS305PDS Electric Single Oven
Oven won't heat, display out, gas burners on stove
Hello, you will probably need to pull it out and put it on something. Make sure the breaker is off to it before you test it. There is a thermostat in the very back that could be bad,check for continuity on that. Also check for continuity on the bake and broil element terminals itself,even though you have checked it to ground. If those check good,then the problems is in the control board.
Thanks
May 31, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Whirlpool super capacity 465 cracked ceramic element
You are looking at approx. $450.
Jan 01, 2010 | Ovens
Montgomery ward gas stove. top burners work fine. oven barely gets warm
I have a whirlpool gas stove oven fire will not go off when in off position. Is the fire suppose to go off completely?
Aug 21, 2009 | GE JGRS14 Gas Single Oven
My oven made a buzzing sound,and and smoke came out form the oven. Now it wont heat up, but the top stove still works...Any ideas? Thanks
fryed switch or fryed burner
if smoke came from inside stove likely the burner is fryed
try setting oven to broil and see if it heats up
if it does replace lower burner
Jul 31, 2009 | Ovens
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
51 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
