Question about Pentair MasterTemp High Performance Gas Heater 250 BTU Propane ()
I have a Pentair Mastertemp 250 pool heater. Installed three years ago and there have not been any problems. About 3 months ago it started igniting on its own and heating the pool. I turned heat o
The order of the read out on the display screen is "Ad0, SF1, 888, R=8"
    Top Expert:
  • Pentair Master
  • 5,056 Answers
If not on controller or on maintain heat bad control board
Posted on Oct 07, 2017
4 Suggested Answers
  • 990 Answers
SOURCE: I have a Pentair Mastertemp 250 pool heater with
This is an ignition flame falure code. Could be you don't have gas getting to the pilot, no spark to ignite the pilot or your ignition is not reading the flame. Sorry to say but it's probally time to get the pool guy out to look at it. Good luck.
Posted on Apr 15, 2010
  • 368 Answers
SOURCE: pentair pool heater has error
When I look at a Pentair manual that may or may not be the same model as yours it says in the Setup section that on power up "888" is displayed and then "---" is displayed. I assume this is to test all the segments of the display.
If you are seeing this symptom some other time than when powering up then there is probably something wrong with the power being supplied to you heater of something in the heater causing it to think it is powering up.
Please let me know is this answers the question. Thank you.
Posted on Sep 03, 2011
  • 368 Answers
SOURCE: I have a mastertemp pentair
Since I don't know exactly what model you have I can only suggest you call the Pentair technical support at 800-693-0971 andthey should be able to help you figure this issue out.
I hope this helps.
Posted on Sep 14, 2011
Pentair mastertemp 250 NA. heater will not fire, no error codes. starts fine, gas flows, igniter heating but still will not fire. It has a new valve, gas pressure entering valve from new regulator is 8.35...
All appearances - No fuel to ignite!
evrything else looks good, proper gas pressure, proper volts at igniter, etc - it should ignite! If fuel present, heater should Fire!
make sure all valves are open.
Gas valve is ON
AND purge any air from gas line.
IMPORTANT ****. If you bled gas line, don't try to ignite for a few minutes. Allow gas to dissipate first, use a fan to help.
Mar 05, 2015 | Pentair Mastertemp 250 Natural Gas Pool...
MasterTemp 250 blowing breaker...
Could have a soft breaker.
Have a technician check the amperage draw at breaker pane.
May 21, 2014 | Pentair Mastertemp Heater
MasterTemp 200 cycles every 30 seconds
since you already replaced the thermisto next would be the control board
Apr 18, 2014 | Pentair Pool & Spa
Pentair MasterTemp 250 Natural Gas Heater with "Service System" issue
this heater will display 2 red light related problem 1-service the system mean you need to clean you filter, and service the heater mean it may be a problem with the heater this 2 you will be able to see it in key pad control the heater ,now reset the board and see what happens (CUT THE POWER ON/OFF UNCE )
Jun 09, 2013 | Pentair Pool & Spa
I have a mastertemp pentair heater. No error codes. Pool heater works fine-- spa heater button will not light or operate. Any sugestions?
I hope this helps.
Sep 11, 2011 | Pentair Mastertemp Pool & Spa Heater Dual...
Heater will not come on. flashes code 125 &
These codes indicate that you have a bad temperature sensor. Once replaced, the error codes will go away.
This is an easy do it your self project, or it may still be under warranty. Check with your install date; if you have installed the heater 1 year or less (single piece of Pentair Equipment) or if you recently built the pool and installed 3 seperate pieces of Pentair Equipment, your warranty is extended to coverage for three years.
Dec 06, 2010 | Pentair 460734 MasterTemp Heater Natural...
I have a Pentair Mastertemp 250 pool heater with an error message E05. What does this mean?
Apr 15, 2010 | Pentair Mastertemp Heater
No power at the control panel - MasterTemp 250
check for 24 vac at the transformer if 24 check for fuses
Aug 16, 2009 | Pentair Mastertemp Pool & Spa Heater Dual...
Pentair MasterTemp High Performance Gas Heater 250 BTU  Propane () Logo
214 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
