Canon PIXMA MP150 All-In-One InkJet Printer
Problem for Canon PIXMA MP150 All-In-One InkJet Printer
Canon MP150
By Jayc on Aug 07, 2006
I have just refilled my two cartridges and the low ink warning stays on.I have trawled a lot of websites for correct reset procedure ,but the MP150 seems unique in its button layout and I have'nt found it anywhere.Any help would be appreciated.
Clarification Request
Posted by Petertiger on Sep 22, 2009
error 8 cannot print screen appears 8 why
Same Problem
Feb 26, 2009
-   my MP150 has the code of E5.........i.e. can't detect the ink.......
I have this problem suddenly together with having the difficulties of scanning problem.
But I can still use the printer or scanner a week before.
I have followed the steps above. But still.........the printer can't be detected. -   Guest
Feb 21, 2009
-   error 27 -   www_exxa8888
Best Solution
posted on Apr 02, 2007
Helpful)
cccccccc
Rank: Apprentice
Rating: 86%, 83 votes
Here's the solution to reset the MP 150
1) First power off the printer. Next, while holding STOP/RESET button, power on the printer.
2) While holding POWER button, release STOP/RESET button. Then push STOP/RESET button twice.
3) Wait about 20-30 second until the LED shows "0". The push STOP/RESET button four times.
4) Finally push POWER button twice. Last step is to turn off the printer by pressing the POWER button one last time.
Was this helpful?
Yes
No
10 people thought this was helpful
Solution #2
posted on Sep 10, 2006
Helpful)
ESummary
Rank: Apprentice
Rating: 84%, 15 votes
If you have refilled your old cartridges, rather than replacig them with new ones, then the printer reads the chip on the old cartridge as empty. It can't tell how much ink is in there. SO you just have to keep an eye out for when the ink seems to be running low due to the quality and refill them again.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on May 01, 2007
Somewhat Helpful)
lovebird
Rank: Apprentice
Rating: 80%, 4 votes
there's no solution for this. i asked diffrent people that are proffesional and all of them told my the same that it will not show that the cartriage is full
Comments:
May 01, 2007
- URGENT!
hey ppl i cant find my setup to reinstall my printer (canon mp150). can anyone suggest something what i can do pls?
Was this helpful?
Yes
No
Solution #4
posted on Aug 13, 2006
Somewhat Helpful)
zaak
Rank: Guide
Rating: 78%, 108 votes
Try removing cart. reset printer. reinsert cart, power cycle printer.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Jan 09, 2009
Helpful)
maynard7
Rank: Apprentice
Rating: 95%, 89 votes
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if this page doesn't print by itself, press the "color" button once and the test page will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Was this helpful?
Yes
No
Solution #6
posted on Dec 13, 2008
Helpful)
garasz
Rank: Apprentice
Rating: 92%, 3 votes
Hi everybody!
I found an working procedure (METHOD1) to reset ink level for Canon MP150!
Jump here, and use METHOD1 !!!
http://digitalgraphy.wordpress.com/2008/11/19/refill-and-reset-the-canon-mp150-printer/
This is an SAFE procedure, do not harm your printer.
And working Canon MP140 too!
(sorry my bad english)
garasz from Hungary
Was this helpful?
Yes
No
Solution #7
posted on Oct 24, 2009
Not Rated)
Dennis Tay
Rank: Apprentice
Rating: 0%, 0 votes
u must do your toot!
Was this helpful?
Yes
No
Solution #8
posted on Aug 23, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If this doesn't work at resetting ink level, go to this page and do as directed: http://forums.majorgeeks.com/showthread.php?t=164622
Works fine.
Solution #9
posted on Jun 14, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This also fixed the error E, 2, 7 on my Canon Pixma 145. This solution works!
Popular Solutions for Canon PIXMA MP150 All-In-One
Questions and Unsolved Problems for Canon PIXMA MP150 All-In-One
Do you recommend Canon PIXMA MP150 All-In-One InkJet Printer?
Answer
Answer
When I try to print, the paper in the tray is pulled to the right and gets jammed...there doesn't... (More)
Answer
I got some paper stuck and now it says my ink is full, call service technician. It worked fine until... (More)
Answer
The printer states that it can not read the ink cartridge, i have tried replacing the cartridge and... (More)
Answer
How do I scan a document so that it will come up on my computer as one whole piece? It will scan it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PIXMA MP150 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 801
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
