Question about Whirlpool Dishwashers
Error code E4
Model ADG 175. Do not fully understand the solution, where is the base pan?
2 Suggested Answers
SOURCE: idw604 error code e4
had same problem. Tilt dishwasher to the left and drain all the water (it will come out on the side). That's E4 solved. Now turn it on, E4 should not light up. If it does, turn it on and as soon as u do this, close the door. This won't activate the Trip Switch but will automatically turn the pump on. Good luck!
Posted on Aug 22, 2009
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 | Dishwashers
Error code e4 frigidaire front load washing machine
Hello Minfaz, thank you for your post!
Based off what you have described your Frigidaire washer is displaying an error code of "E4". I am showing that this is an invalid error code. This might be a miscommunication within the control panel. I would recommend performing a reset on your washer and you can do that by disconnecting the power cord for roughly ten minutes. If your washer continues to display that error code please provide me with the model number. You can locate that information on the door frame of the washer on a silver or white tag. With that information I can research your washer further. -Matt
Jan 14, 2016 | Frigidaire Washing Machines
Phone flashing 88 8 now flashing e4 cannot get dial tone.
Your manual may have the E4 code, but Uniden certainly will, if you contact their support site. This symptom often indicates a power or function issue with the base unit, and so make sure the base has charging voltage, and the terminals are clean (use a qtip and alcohol). When you contact Uniden Support, have your model number ready, since different units can have the same or different error codes programmed into them.
Good luck, and hope this helps.
May 19, 2011 | Uniden Cordless Phone
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
Shuts off, error code e4
i THINK e4 CODE ON SOME MODELS means that the water drain pan need to be emptied.
Jul 10, 2009 | Heating & Cooling
Error code on iron man cycle
There are two black plastic covers on the front of the base of the machine, it is easy enough to get a sponge in and mop out the sump when it happens. The covers are hard to flip out, but a simple modification with a file has made them more readily removable for mopping out. That's nearly as easy as emptying a drip dray.
The level sensor that causes the E4 error. Its at the middle front of the sump pan, and consists of a polystyrene foam float that trips a micro switch. it only needed a small (say 3mm) movement to operate.All back in place and will work again.
Feb 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Base unit displaying E4 after we experienced a power black out
e4 error code that means it ihas defective base unit. it happened due to a spike in the power lines that may cause this error
Feb 09, 2009 | Uniden 5.8GHz Cordless Phone
E 4 ERROR CODE?
Customer support 1 800 297-1023 told me that this means the base unit is defective and can't be repaired. I also was told that none of my remote units are compatable with other models.
Sep 26, 2008 | Uniden TRU9480 Cordless Telephone
E4 error code
Exact same problem. E4, sent uniden an email thru their website though I doubt Ill hear any response. Very disappointed as the 9485 was working great until all of a sudden E4 showed up.
Nov 29, 2007 | Uniden TRU9485 Cordless Phone
E4 error code
I called Uniden about the same problem.  They say it is a code that means it is defective base unit.  I had purchased it within one year and they will gladly send me a new one.  I don't know if they will offer anything beyond the one year mark.
They say it was a spike in the power lines that causes this error.
Oct 09, 2007 | Uniden TRU9488 Phone
Dishwashers Logo
303 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
