Question about Tissot T-Touch T33759851
Altimeter calibration,meteo colibration - Tissot T-Touch T33759851
  • 10 Answers
SOURCE: Thermo shows 91.7c, Meteo shows just hpa and
T Touch only gets problems, when it gets contact with water. so whatever tissot says..guys dont use it with water. so keep yourself always happy
Posted on Feb 23, 2010
SOURCE: tissot t-touch t0015204406100
Go to the offical Tissot site www.tissot.ch and download the pdf file "user manual" and there you'll have everything u need to know about operating this great watch...
Posted on Jan 21, 2008
HW_Dude
  • 87 Answers
SOURCE: T touch Meteo out by 20 Milibars
Certain functions need to be calibrated. The altimeter and the Meteo are tied together. When a customer gets the watch, they should calibrate to either the Meteo or Altimeter. The easiest way to find out the altitude of the nearest airport (you can usually get this on line) and then go to the airport and adjust the
watch. This will also calibrate the Meteo.
To calibrate the Altimeter:
1. Activate Crystal
2. Press Altimeter
3. Press and hold top + button until the watch beeps and display flashes.
4. Use + and – buttons to adjust altitude
5. Press center of dial to lock in.
Posted on Jan 10, 2009
escapement
  • 2334 Answers
SOURCE: t-touch altimeter stopped working, I suspect it
You may need a new battery, but first check out this site:
www.tissot.ch
Rate me, please.
Posted on Jul 31, 2009
SOURCE: when I push one of the 6
push t button and push mıddle until it shows 24h or 12h then push t putton 5 sec it changes into sync mode.Now you can adjust two needeles at 12 both hand pozition.When finish touch t button again
Posted on Oct 15, 2009
When I push one of the 6 indicators(meteo,ALTIMETER ETC) the two needles are no longer paralell with each other. I was told in Geneva there is an easy way to fix it.but forgot.
Sep 29, 2009 | Tissot T-Touch T33159851 Wrist Watch
1. Activate Crystal
2. Press Altimeter
Oct 14, 2008 | Tissot T-Touch T33159851 Wrist Watch
Tissot T-Touch Baro way too high
Try to recalibrate the Baro/Altimeter as below:
Certain functions need to be calibrated. The altimeter and the Meteo are tied together. When a customer gets the watch, they should calibrate to either the Meteo or Altimeter. The easiest way to find out the altitude of the nearest airport (you can usually get this on line) and then go to the airport and adjust the watch. This will also calibrate the Meteo.
1. Activate Crystal
2. Press Altimeter
Aug 05, 2008 | Tissot T-Touch T33159851 Wrist Watch
Tissot t-touch t0015204406100
Jan 12, 2008 | Tissot T-Touch T33759851
Tissot T-Touch : Faulty reading on Thermo, no reading on Altimeter and meteo not working either
If it's under warranty by all means pursue a fix. You might have to send it to a warranty center instead of working with your local dealer.
"Water proof" and "water resistant" are very different. About 20 years ago all watch companies stopped promising waterproof and started using the term water resistant. It gives them wiggle room in the guarantee, unfortunately. I believe T-Touch is supposed to be water resistant to only a few meters.
Nov 21, 2007 | Tissot T-Touch T33159851 Wrist Watch
Meteo
1. How do you know the meteo is wrong? Are you comparing against a known good measurement device?
2. The altimeter requires adjustment every few days or whenever there's a weather change. Select the altimeter, hold the upper or lower button until you have the correct altimeter reading for where you are and it will hold for a few days.
For example, I know my home is at 100m elevation (I checked on a topo map) so I reset it to 100m when I leave the house in the morning. It varies (in my case) by over 100m in either direction, depending on the weather.
Nov 03, 2007 | Tissot T-Touch T33159851 Wrist Watch
The 'meteo' function doesn't work when I press the watch face.
This seems to ba a common problem. On mine both the Meteo and Altimeter stoped working. Apparently these watches have a fault with the water proofing and should not be worn in water!
Oct 23, 2007 | Tissot T-Touch T33759851
Tissot T-Touch T33759851 Logo
243 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Mohamed Ismail
Mohamed Ismail
Are you a Tissot Watch Expert? Answer questions, earn points and help others
