Question about Hannspree 19" Widescreen LCD Flat Panel Monitor
Wont keep resolution
Each time I start computer I have to reset resolution to 1440by 900 which is recommended. The screen flickers, sometimes more than others also makes a big noise when screen goes to rest mode this also happens frequently. The screen will go to black with a big noise, be off for a while go to blue with a big noise and repeat this over and over during the day and night which is very disturbing. Please help if you can
5 Suggested Answers
SOURCE: TCO03 display with screen resolution problem,
Click Apply to 1440 900 resolution at the [s-a-m-e t-i-m-e] you push the AUTO button on the LCD. Will reset something somewhere.... yet, worked every time.
Posted on Jan 28, 2010
  • 3 Answers
SOURCE: I have a samsung 2033SW
- You can test the monitor by using another CPU, if still the same then the problem is monitor, but if it's working well then the problem is your CPU, to make it sure then you can try another monitor on your CPU. - check if the hardware connection is well attach, you can pull & re- plug the hardware just to make sure. - the monitor is need a DVI connection (white or gray) to run properly, if you use AGP connection ( blue ) on your VGA card that might the problem, so you can also try upgrade your VGA card. - other ways is to install the latest driver for your VGA card.
Posted on Jan 14, 2011
  • 121 Answers
SOURCE: after 3 to 4 hours the picture goes bad on screen.
How old is the tv
Posted on Sep 26, 2011
  • 27 Answers
SOURCE: my computer is not showing the resolution of
i just had the same issue .. try dropping it way down ... set it like just to test it and see if it accepts it and dont holler ... if so now work your way back up to something around 1280x1024 thats what mine is set to and its working fine ... i started out at 1024x768 when i first started the pc up with the new monitor ... it didnt like that so i went up n it still didnt like that so done the oppisite and dropped it way down . like 600 area may not have to go that low .. but thats up to you .. hope this helps ...
Posted on Oct 24, 2011
Resolution notice
Your monitor is not running in its native resolution, so there is notification to change your display resolution, then you have to check driver for your video card. Upgrade the driver fot your video card. Where will be the setting to change to 1440 x 900.
Nov 08, 2013 | Envision G19LWK Monitor
Samsung screen flicker
Have you recently changed the resolution/refresh rate? This is usually set automaticallly by windows by check anyway.
Right click the desktop and select Screen Resolution
Change the slider/dropdown to the (recommended) selection and click apply. Click keep changes if it appears.
Still having issues then go back into Screen Resolution and click the "advanced settings" blue link on the bottom right.
Click on the "Monitor" tab and select the highest refresh rate you can and click ok. again click "keep settings" if it appears.
Dec 23, 2012 | Samsung X Computers & Internet
My lenovo LCD screen is flickering black and striped lines, how to get it fixed in Richmond Hill Ontario
Laptop computers have LCD displays that are sensitive to many things. LCD displays have faults that sometimes produce a flickering screen, lines, dots or a faint display. These screens are sensitive to magnetic fields or electronic items near the computer. Speakers, cell phones, lights and other electrical items are examples. Your display also could be flickering due to software issues such as the video drivers or hardware issues relating to the inverter going bad or the LCD screen itself needing to be replaced. Trace the cause of your problem to come to a resolution.
1.Turn off the computer. Disconnect all external devices. Turn the computer over (bottom facing up). Take out the battery and reseat it. Turn the computer on.
2.Reset your resolution and refresh rate.
Windows XP:
Right click an open area on your desktop. Click "Properties" in the drop-down menu.
Click the "Advanced" button at the bottom of settings tab. Another dialog box appears. Click the "Monitor" tab. Change the Refresh rate to your default, or 60 hertz. Click "OK."
Windows Vista:
Click "Start, Control Panel." Find and click "Appearance and Personalization." Click "Adjust Screen Resolution." Change resolution to the default, or 800 x 600. Click "Advanced Settings." Click the "Monitor" tab. Change the refresh rate to the default, or 60 hertz. Click "OK."
Windows 7:
Click "Start, Control Panel." Find and click "Display" Click "Change display settings" on the left side. Change screen resolution to 800 x 600. Click "Advanced Settings" in the lower right. Click the "Monitor" tab. Change the refresh rate to 60 hertz. Click "OK."
3.Check the computer's surroundings. Move away any speakers, fluorescent lights, fans, cell phones, radios and any other electrical device that can cause flickering. Temporarily move electrical items away from the computer to see if they are producing this issue.
If the flicker stops, put back one item at a time to determine what is causing the problem.
4.Connect an external monitor to your laptop computer to see if that screen is also flickering. If there is no flicker, then the problem is strictly with the laptop, indicating a possible hardware failure. Contact the manufacturer for a replacement LCD.
If the flicker continues, go to next step.
5.Reset/Update your video driver. Click "Start" and right-click "My Computer." Click "Properties." The "System Properties" dialog box will appear.
6.Click "Device Manager." A list of items will appear. Click the (+) sign next to "Display Adapters."
7.Right-click the video adapter and click "Uninstall." Confirm removal. Restart the computer. The video driver will automatically reinstall itself.
8.Check to see if the flicker still exists. If so, go to the manufacturer's website. Download and install the newest video driver and BIOS for the computer.
9.Restart computer once drivers are installed. Continue to the next step if there is still flickering.
10.Open up your display screen all the way. If the flicker stops by opening it a certain distance, it is the display inverter. If the flicker still exists, the LCD screen should be replaced.
11.Contact the manufacturer of the computer for more information and a possible replacement inverter and LCD display. This will depend on the manufacturer and the computer itself.
I hope you find it very helpful. Thanks
Sep 05, 2011 | Lenovo 3000 N200 Notebook
My laptop emachine g720 screen flickering
Windows XP:
Windows Vista:
Windows 7:
I hope you find it very helpful. Thank you for using fixya.com
Aug 19, 2011 | Computers & Internet
Computer monitor out of range is being flashed on screen
Monitor is not recognizing the resolution settings that are currently set on the computer.
It is probably sett too high.
You will have to lower the computer resolution.
If it is a laptop, you should be able to do this using the laptops screen.
If it is a desktop computer, you either have to use a different screen to reset the resolution.
or
Sometimes restarting the computer while the screen is on will reset the video.
If that doesn't work, try starting the computer in safe mode by tapping the F8 key while it is being started. This will keep the resolution low enough to see it on the monitor and you can adjust the resolution there in the display properties
Oct 19, 2010 | E-Machines eMachines Monitor E15T4
TCO03 display with screen resolution problem, unable to have full screen in recommended 1440/900, swapped screen with another one same model and problem disappears.. Missing about 1 inch right side. ...
Jan 27, 2010 | HP Computers & Internet
Flickering Screen on Model P105 Toshiba Satellite
on the back of the LCD is a cable that goes from there to the Motherboard. Try reseating that cable on both ends. If that doesn't fix it then it has to be a problem with either the screen or the cable behind the screen.
Aug 11, 2009 | Toshiba Satellite A105 Notebook
Chimei CMV 938D 'Out of range' error message only when using DVI Connector on specific resolution and color depth
I know this sounds obvious but- I had the same problem, and turns out the cord want plugged in quite properly at the back of the monitor. This may not fix every problem, but, I suggest you check the cord pligged in at the back of the monitor is firmly in there and restart, then if you still get the problem, contact the company.
Jul 21, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Screen Flickers
MONITOR ABCs
The monitor is a hardware device which physically connects to your video card. The monitor allows information and current status be be visually outputted similar to a TV.
monitor.gif Like most TVs, the computer monitor has a CRT, or Cathode Ray Tube, which is found inside the computer monitor as illustrated in the above picture. The CRT is the main component and most expensive part within your computer monitor. Within the CRT are three electron guns, Red, Green and Blue. Each of these guns streams a steady flow of electrons, left to right, for each line of your monitor. As the electrons hit the phosphors on the CRT, the phosphor will glow certain intensities. As a new line begins, the guns will then begin at the left and continue right; these guns will repeat this process sometimes thousands of times until the screen has been completely drawn line by line. Once the phosphors on the CRT have been hit with an electron they will only glow for a short period of time; because of this, the CRT must be refreshed, which means the process will be repeated as explained above. If the video card's refresh rate is not set high enough, you may encounter a flicker or a noticeable steady line scrolling from the top to the bottom of your screen. If you are encountering this issue, resolutions have been described on our video card page.
MINIMUM RESOLUTION The size is an important factor of the computer's running resolution. When picking the resolution, try basing it off the monitor's size for best use. 13-inch 640 x 480 15-inch 800 x 600 17-inch 1,024 x 768 21-inch 1,280 x 1,024
Hope this works for ya/Please dont for get to vote.
Jul 17, 2008 | Sony VAIO PCV-V200G PC Desktop
Back light keeps flickering and sometimes wont work
back light wont need to be replaced most likely, tighten the connections. yes the manufacturer can replace them you could too if u had the skill, money, and time,
Jun 13, 2008 | NEC MobilePro P300 Pocket PC
Hannspree 19" Widescreen LCD Flat Panel Monitor Logo
Top Hannspree Computers & Internet Experts
justwinwin
Computer Links
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
