Question about Goodman Heating & Cooling
How to lubricate a goodman GMP furnace motor
When the motor turns on it makes this loud sound the entire time it is running as if it needs lubricated. Is this possible, and if so how do you do it?
  • Goodman Master
  • 3,250 Answers
On the end of the motor is a small cap may be red open this you oil it from there .
Posted on Feb 11, 2012
hotuna
  • 288 Answers
SOURCE: Goodman furnace motor is dirty
The blower motor, squirrel cage (fan) and its housing can be removed as a whole part. Disconnect the wiring harness to the motor, remove the ground wire. Look for a couple of screws that mount the blower housing to the furnace. they will 5/16 head size and usually be at the top. The bottom slides into a metal notch on the frame. With a little work and maybe a few cuss words, pull the whole thing out. A shop vac or air compressor will remove the dirt. Some dirt may be determined to stay, so a stiff bristle brush may be needed. Replace in opposite way you removed it. If the whistle remains, check the duct work and metal panels, and anywhere there is a gap or tape. This may be the cause of the whistling noise, but cleaning the vent holes in the motor and the fan blades cant hurt and will help the efficiency of the system and increase the life of the equipment. If the whining is the little vent motor up top, then try oiling with a thin turbine type oil, or just replace it, as they are relatively cheap. If you are asking about cleaning the internal parts of the motor, I wouldn't recommend doing that. If there is an oil port on the motor housing, use the oil I recommended earlier. Most likely it has a sleeve bearing not a roller type, so that's about it.
Posted on Jan 12, 2008
  • 108 Answers
SOURCE: goodman gas furnace power vent motor and housing replacement
You need to type GOODMAN GAS APPLIANCES into you browser to find you local servicecenter. I must tell you that Goodman only sells to authorized service companies in my experience. So you become EgKraft Company.
Posted on Nov 07, 2008
  • 3600 Answers
SOURCE: How to fix twinning problem for a goodman GMP 100-4
Call AAA back it should be warrented if they worked on it frst don't touch it or you lose your warrent, it does sound like the thermal bulb is not in the flame so call them back fist then let me know post here and I will try to help you if they do not sove the problem, you should have a work order they gave you when they did the repair. Hold on to it.
Posted on Oct 09, 2009
Testimonial: "The thermal bulb would cause the twinning light to come on."
  • 232 Answers
SOURCE: I have a goodman GMP 125-5 furnace. I have
sounds like the primary limit typically behind the gas valve its larger then the others, rectangle in shape with 2 wires going to it. be careful if your bypassing limit this can create a very hazardous condition
Posted on Nov 06, 2009
SOURCE: how to change fan speed on a goodman gmp 100-3
Usually you can find the control board on the lower part of the furnace. Turn the power off and remove the
doors. This board is usually located directly in front of the blower motor.
On the control board locate the terminals marked heat/cool/park and Park Lets say the Heat Terminal
has a red wire attached to it and you want a higher
speed.
Red is uasually low speed, remover the red wire from
heat terminal and exchange it with a wire attached to
a terminal lab eled park. Black is usually high spped
Posted on Jan 02, 2010
Blower motor makes noise, but does not work goodman
its either a bad motor or bad capacitor if you try to spin the wheel by hand and it starts then its the capacitor
Dec 26, 2012 | Goodman Heating & Cooling
Have a gmp125-4 furance blower runs all the time checked themostat wires error code 1 blink then 2 then 3 then 5 furance works if you turn power off turn back on when heat kickes off blower comes on gives...
Sounds like limit switch issue. Furnace heats up, high temp limit switch opens, fan will stay on. GMP model is older and do not have the codes.
May be over fired, have airflow problem, to cause the limit to open.
Next time before shutting off power, try to find the limit, it has two wires that connect to a 1.5 x 2 inch card mount to the furnace fire wall. tap on it and see if the blower stops. If so replace the limit.
Sep 06, 2011 | Goodman Heating & Cooling
I Have a beige goodman furnace (old ones) gmp... i replaced the circuit board..it worked fine..then once it reached its desire temprature from thermostat.. fire goes out then 2 min following is the...
Check the pleum high limit switch. Jump this control out and see if the furance runs until the call for heat is satified. Do mot leave the high limit jumperd.
Jan 26, 2011 | Goodman CACF048B2A Air Conditioner
Goodman GMP Furnace problem. Original problem is
Good one! Is the flame getting to the flame sensor within the few seconds? Maybe a good cleaning of the burners or flame tray would help. 1.3 ma is enough for the flame rod to tell the board to stay on. Re-do all the ground connections both at the board and furnace cabinet to be safe. Check the polarity of the power going to the furnace. What are the chances the second board is bad?
Jan 15, 2010 | Goodman Heating & Cooling
Nov 06, 2009 | Goodman GDS80904BNA Open Flame Heater
Fan on the outside unit is not running
Fan motor is dry or going bad try to lubricate it and see if that frees it up. If not you will need to get a new fan motor.
Oct 09, 2009 | Goodman CKL36AR36 Air Conditioner
Goodman furnace\ blower comes on,unasked
Sounds like the fan switch on the furnace is set to low. Turn power off to furnace, take door off of furnace look for a fan switch, it may be a fan - limit together. The limit settings should be approximately 160° to 200°, and the fan settings should be about 100° to 140° set it to 120° it it's already set there then you probably need to replace it.
Aug 03, 2009 | Heating & Cooling
Twinning problem
Switch the leads and also make sure that you have a good ground.
Mar 30, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
108 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
