Question about PfaFF Creative 7570
When i turned on my phaff 7570 machine, the needle went to the left side and started quivering. I can't sew, it is stuck in that position. I
When i turned on my phaff 7570 machine, the needle went to the left side and just quivers. I can't sew on it.
  • PfaFF Master
  • 7,365 Answers
It sound like it jamed up,, it needs to be serviced
Posted on Feb 11, 2012
3 Suggested Answers
  • 4 Answers
SOURCE: 7570 sewing machine
contact a pfaff dealer in your area., and they will order what you want
Posted on Jan 12, 2008
SOURCE: I have a 7570 phaff
Hi franlove
I had the same problem when I upgraded to a laptop with Windows XP. I needed to buy a Keyspan, which connects via the USB on the computer to the machine via the pc connector that comes with the Pfaff 7570. However I had many problems after that, and found that the Keyspan transfer rate had to be slowed down to 2400. Of course 3D is the most recent Pfaff software that the Pfaff 7570 will work with. Anything older is OK.
Hope this helps. I will look up the steps that I went through to slow the transfer speed from the Keyspan if you need me too.
Good Luck
margielydia
Posted on Jan 01, 2011
Needle position won't hange
When you turn the machine on does the needle bar initialize? I.e. Move to the left, then to center.
Nov 03, 2013 | Brother SE400 Computerized Sewing Machine
Needle stuck in side position
it's possible it could be out of time or something in the computer part or mechanical part with out
only a sewing machine repair shop can tell you which one
Feb 10, 2012 | PfaFF Creative 7570
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
My phaff wheel seems to be locked up -- what can i do to fix it the needle will not go down to pull the bobbin thread thru ,and it "sticks " when i try to turn the wheel
There may be a piece of thread logded between the hook and the bobbin case holder. Try turning the handwheel very firmly backward (opposite the sewing direction).
Jun 16, 2011 | PfaFF Creative 7570
I have a 7570 phaff sewing machine and a new windows 7 PC What will I use to transfer my patterns to the machine
Hi franlove
Good Luck
margielydia
Dec 29, 2010 | PfaFF Creative 7570
I can only sew straight or very little width stuff. The needle hits on something when it moves to the left.
I suppose you already have the needle position in the middle. Try selecting the widest stitch set on the right side, See if it hits anything and if it's the same distance as the left. If it's not then you'd need a service person do a complete alignment, timing and other related service to zero your machine.
Oct 04, 2009 | PfaFF Creative 7570
I have a similar problem with my 7510.
As a rule of thumb, the flat side of the needle always goes towards the opposite side of the last thread guide. So on your machine, since the last thread guide is in the front of the needle bar, the flat side of your needle goes toward the rear. The needle threads front to back.and needle clamp is tight position is must
Aug 03, 2009 | PfaFF Creative 7570
Threading a pfaff creative 7570
Always thread the machine with the presser foot up. This keeps the tension disks open while you are threading. Open the lid on top. Put thread on spool holder. Go directly to your left and down the path on the farthest left. Go all the way to the bottom and bring the thread up on the path closer to the spool. Hook the thread through the metal piece that moves up and down while sewing. It should be in the highest position when threading. Run the thread down and clip into the small metal holder above the needle. Pull down needle threader, draw thread across front of it from left to right and pull through needle.
Jan 30, 2008 | PfaFF Creative 7570
Pfaff 7570
check your needle position, in the machine settings before you shut off your sewing machine.
Dec 29, 2007 | PfaFF Creative 7570
7570 sewing machine
Dec 11, 2007 | PfaFF Creative 7570
Sewing Machines Logo
102 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
