Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA HD52W27D Our rear projection TV is 4 years old and it has started to turn itself off. It use to turn itself right back on in 15 seconds but it does not any longer. Is it worth having it looked at?
  • 1 more comment
  • glrawe Oct 25, 2008
    My RCA wide screen HDTV projection tv is doing the same thing. I really would love to hear thoughts on this, should I get it looked at or is it shot?
  • freyjadawn Nov 13, 2008
    Ours did the same.Only happens when we are using a component such as DVD player or Xbox.  repair guy said it needs a baord replaced, did that 18 months ago. Started happening again, repair guy said they don't make the boards anymore. told me to slap the side of it. Yikes.
    I am, searching for a better solution now.
  • Anonymous Feb 27, 2009
    My rear projection TV would turn its self off when you would first start it on then after a couple of times it would stay on. The TV was built in 2004 and I bought it off of QVC. Now the TV wont turn on and it made a funny nosie before it died. I took the back off and look to see if there was anything burnt, no evidence and the fuse is still good, what do I start to replace now?
  • 3 Answers
I just fixed my D52W20 by replacing three CAPS. Two of them were vented(bulging at the top). I replaced CP150 2200uf 16v with a 2200uf 50V, CP110 220uf 200v and CP114 220uf 35v. It was also recommended to replace CP120 but I did not have one. Check the green CAPS and replace any that are vented.
Posted on Oct 26, 2008
Samsung rear projection tv
I think it could be a faulty diode on the power supply board. If you can check this for yourself otherwise call out a competant technician. Good luck.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Tv turning off by itself occasionally
Just had mine repaired yesterday.
They relaced a TD4611 voltage regulator and a C2200uf 50v part.
Total including service call $188.00 in Western Canada.
Jul 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv turns off
Its the lamp that needs replacing. It will run for a couple of seconds and then it would dim or turn off.
May 27, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
52 inch rear projection kept shutting off
bad flyback you can get a new one at the following link for about 50.00 they include free instructions and free tech support with every purchase so you can do the repair yourself. You need Flyback 259296 RCA Heres the link
May 02, 2008 | RCA D52W19 52" Rear Projection Television
52" RCA d52w19
About middle of the board you removed the flyback,there is a u shaped heat sink this is in the middle of the board,behind the heat sink is a blue cap 2200 uf ,if the top is pushed up the cap is bad.
Mar 11, 2008 | RCA D52W19 52" Rear Projection Television
ProScan rear projection
Proscans are manufactured in conjunction with RCA what is the chassis number of your set? I can help you out if you can provide the chassis number. Should be located on the back cover of your set.
Mar 02, 2008 | RCA P61960 61" Rear Projection Television
60in. rca rear projection tv
1) Reset will not help
2) Older RCA projection tv's usually produce a good pix,
so you could fix it....
3) light box chassis pulls out to go to shop for repair...
4) For more info = provide service # and chassis # off back..
Please rate this solution...............
Nov 13, 2007 | RCA P46924 46" Rear Projection Television
RCA 52" HD Widescreen
Only thing can suggest is try the bulb itself to see if it got damaged in transit.
May 22, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
249 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
