Question about Swintec 7040 Typewriter
How to use the memory function on Swintec 7040 typewriter
Don't have the manual & would like to know how to use the memory function
  • Swintec Master
  • 3,594 Answers
Go to NADIST.COM click on current models I believe the AE 714 is the same as your T/W.
DickyO
Posted on Mar 12, 2012
  • 3594 Answers
SOURCE: Swintec 7040 Typewriter
First check check the pitch selector switch to be sure it is not in proportional spacing. if it isn't push down on it and see if it goes away, if is goes away the keyboard needs repaired.
DickyO
Posted on Feb 22, 2008
  • 3594 Answers
SOURCE: swintec 7040 typewriter ribbon feed.
Try code . or , or / one of these should reset the ribbon feed to full spacing
DickyO
Posted on Mar 10, 2008
  • 19 Answers
SOURCE: Purchased used Swintec 7040 typewriter. Looking
You can buy the manual at www.granadahillsbusinessmachines.com or at www.swintec.com.
Posted on Feb 19, 2010
  • 19 Answers
SOURCE: when turned on - a beep is all i get-keys won,t
Sounds like a broken wire attached to the carrier motor. If you remove the shell from the typewriter you can see the wiring inside. I suspect one of the wires has come disconnected or broken. Replace the wiring assembly or you can try to strip the two ends of the broken wire and twist them together, then use some electrical tape to secure.
  • 3594 Answers
SOURCE: Swintec 7040 typewriter - what is the code key and mode key for
The code key works with all the keys in the top row to set up those functions, bold, underlind, KDII, etc. The function allows you to type on the display befor printing.
DickyO
Posted on Apr 26, 2010
Need user manual for swintec 7040 typewriter
Go to NADIST.COM one of the Nakajima models will be the same. down load the manual.
DickyO
Jan 15, 2013 | Swintec 7040 Typewriter
Memory on Swintec 7040 is irratic. Copy is correct but tabs move around.
Spray a little WD40 on the silver shaft that the carrier slides on.
DickyO
Sep 17, 2012 | Swintec 7040 Typewriter
What do I press to set my left and right margin on the swintec typewriter 7040
Go to the margin you wish to change, PRESS BUT DON'T HOLD the MAR REL key space or backspace to the desired location press L. or R. mar key.
DickyO
Feb 18, 2012 | Swintec 7040 Typewriter
The Swintec 7040 typewriter goes a few inches to the right and stops. How do I unlock?
My best guess is that you have the R. margin set there. Go to the stopping point, press but don't hold the MAR REL key, spce to desired location, press R. mar key.
DickyO
Nov 03, 2011 | Swintec 7040 Typewriter
How do I reset the right side Margin on a swintec 4040 electronic typewriter?
Go to the margin, press but don't hold the mar rel key, space or backspace to the desired position, press R. margin key.
DickyO
Oct 27, 2011 | Swintec 7040 Typewriter
DickyO
Apr 23, 2010 | Swintec 7040 Typewriter
Purchased used Swintec 7040 typewriter. Looking for a user manual for same.
Swintec was made by Nakajima, If you call Nakajima @
800-809-7138 they may be able to help you.
DickyO
Feb 03, 2010 | Swintec 7040 Typewriter
Swintec 7040
If what you are saying is that you get 2 vertical lines instead of a letter start with a new printwheel, what you are seeing is the hammer face when it misses the printwheel.
DicktO
Aug 30, 2008 | Swintec 7040 Typewriter
Swintec 7040 & Spellcheck
If it has spellcheck hold the code key down while pressing the (spell) button
Feb 19, 2008 | Swintec 7040 Typewriter
Swintec 7040 Typewriter Logo
127 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
