Hotpoint Aquarius WMA34 not progressing through wash cycle
Starts normal wash programme and when it gets to rinse and spin it stops, pre wash light comes on, if I press the start button it will then progress to rinse and spin, but once it has done this it stops again and I have to turn the dial to fast spin and press start again to get it to do a final spin.
  • Anonymous Apr 10, 2009
    I also have the same problem only when I turn it to the spin manuelly it still will not spin. I was going to but a new timer switvh unit but at between £70 and £90 want to be fairly sure that will solve the problem. If it worked when I manually turned it to each position I would be sure it was that but as it still does not spin I wondered what people thought
  • 46 Answers
iwould think it is the programer may have failed mechanically not moving on
Posted on Oct 23, 2008
WF740 Aquarius washing machine keeps going through a Test cycle. Cannot get it to wash?
Turn off the appliance at the mains, hold on & start buttons down then turn back on at mains and hold until dOFF appears should now be back the normal.
Oct 20, 2014 | Hotpoint Washing Machines
I have a hotpoint aquarius WF32O and when i put
is it spinning and craccleking,,carbons faulty in motor ;;will work on spin but not lower voltage wash?
change carbons,, use genuines,only
Jun 21, 2010 | Washing Machines
Hotpoint aquarius wma34 washing machine - flooding and clicking
Sounds like it could be relatively expensive to put right.
Personally, I think you would be better in investing in a new washer, more so in view of the fact that is 7 years old.
There are numerous possibilities for the symptoms you describe.
Hope this helps you to come to a decision.
Dec 29, 2009 | Washing Machines
When i put it on a wash cycle it starts then all of a sudden the power light flashes rapidly and the rinse hold light flashes steady
Fault code F02 meaning Motor jammed / tacho detached: check motor
& module connections.. on the motor plug check that a wire hasn't become dislodged or broken...
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf000 not completing final spin
u should check the drain filter and try to listen to the pump if its working
or the outlet hose might b stuck
May 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Does not heat water
the heater element has probably gone faulty or the thermostst is faulty, they sould come as one replacement.
Apr 05, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Wash machine stays on wash cycle and doesnt go to rinse or spin
If the water is not getting hot, this will probably stop the programme advancing .Check heater.
Plz rate solution to prob.
Dec 10, 2008 | Hotpoint Aquarius WF000 Front Load Washer
there is a small access panel in all front loaders.  there is probably a coin stuck in the compartment.  this will stop the water pump operation correctly
Oct 27, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
378 people viewed this question
Top Washing Machines Experts
