How do I fix a compaq if it crashes and says something about hive it's in a little paragraph
  • 27,725 Answers
Make sure you have enough RAM your computer might be running over its limits putting to much strain on the cpu causing memory dump
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box
then select check now start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
also download a computer opimiser
http://download.cnet.com/toolwiz-care/3000-2086_4-75610754.html
Freeware utility
Speed up slow PC with system checkup, system cleanup, system speedup, and other optimization suites.
hope this helps
Posted on Feb 11, 2012
How can i write a excellent paragraph ?
so you want to write a excellent paragraph . if you want to write a good paragraph you need to know some rules about making paragraph . then you have to follow some excellent method . if you need more you visit this site
Talented Essay Writers Only
Mar 18, 2014 | Computers & Internet
My pc compaq nc6220 cannot boot,some time it show disk controller failure,some time no disk system or disk error and som time a blue screen appear on my screen.please help me.
Your hard drive may have crashed.This is so proven by the 'blue screen' technically referred to as 'the screen death'.
  • First,you may try removing the hard disk,leave it for a while and re-fix it again.Start the PC.What happens?
  • If still wont start, you may have to try and re-install the operating system again.
  • If the operating system wont install on the drive,replace it.
Hope this helps.Thanks!
Please rate this answer.
Oct 22, 2011 | HP Compaq nc6220 Notebook
I cant log in
there is a virus in your system which corrupts a registry of the files userinit.exe and explorer.exe.
Its better to format or to repair:
So the problems is After you clean the viruses you won't be able to log on to your windows desktop. I think here is the best ways to fix it:
Step 1: Create a BartPe Bootable CD
" BartPE" (Bart Preinstalled Environment) is the bootable Windows CD-Rom or DVD from the original Windows XP that we can say Live CD that, very suitable for PC maintenance tasks.
To built it by ur selves please go to : http://www.nu2.nu/pebuilder/ to download the PeBuilder latest version and read the instruction to built your own bootable CD.
Step 2: Verifying and fixing the Userinit.ext
1. Insert the BartPE CD into the drive, and boot the system from the CD. Once the file loading phase is over, the Bart PE desktop will be visible.
2. Type Regedit.exe in the prompt, and press Enter. Select the HKEY_USERS hive
3. From the File menu, choose the Load Hive option. Browse to your Windows installation drive C:\Windows\System32\Config\
4. Select the file named SOFTWARE (the file without any extensions), and click Open
5. Type a name for the hive that you've loaded now. (Example: MYHOUSE)
6. Now the SOFTWARE hive is loaded, and present under the HKEY_USERS base hive.
7. In order to fix the Userinit value in the loaded hive, navigate to the following location:
HKEY_USERS \ MYHOUSE\ Microsoft \ Windows NT \ CurrentVersion \ Winlogon
8. Double-click Userinit and set it's value correctly. Example: Set it's data as follows:
C:\Windows\System32\Userinit.exe,
PCCLINIC KANPUR
Sep 12, 2011 | Computers & Internet
Hey guys any windows experts out there? how do I search the registry on a corrupted hard drive? my computer crashed and right now i just have the old hard drive mounted on another machine. there is a...
To access the registry of a corrupted hard drive:
1. Attach the drive to another computer 2. Boot into a working version of windows 3. Start -> Run -> regedt32.exe 4. Click on the left panel and minimize all the folder branches so you only see HKEY_CLASSES_ROOT HKEY_CURRENT HKEY_LOCAL_MACHINE HKEY_USERS HKEY_CURRENT_CONFIG
5. Click on the root key HKEY_USERS or HKEY_LOCAL_MACHINE 6. File -> Load Hive 7. See http://en.wikipedia.org/wiki/Windows_registry#Locations for default locations 8. When you are done, UNLOAD HIVE!!!!
Mar 09, 2011 | Computers & Internet
Blue crash screen
http://support.microsoft.com/kb/830084
This page is Microsoft's answer to your question.I sure hope this helps?
Mar 10, 2010 | HP Compaq Presario SR1538X (PX799AA) PC...
C0000218 Registry file failure. Registry cannot
The hive file is the problem, it is low on honey. Put it back to where the bees can produce enough honey for your PC to recognize it. Compaq's are notorious for their love of honey, that is why it is showing it is missing. DO NOT simply put honey on a CD and insert. Will not work.
Feb 01, 2010 | Compaq Presario 5000 PC Desktop
My laptop came up with a message that says files missing or corrupt. Use start up disk. I need to get a copy of the start up disk. Can you help.
I'm thinking that the message is that the "system" file is missing.
Go to this link and you'll be able to fix it if the problem is a corrupt registry hive.
http://support.microsoft.com/kb/307545
Oct 30, 2009 | HP Compaq nc6220 Notebook
ACER 5720 (XP sp3) not shutting down
Hello Satishrk.
There are several potential causes of this. However, based on your description, it's most likely user hive registry hang. It's a fairly common problem. It occurs when certain application(s) won't readily let go of the user's portion of the Windows registry. If this is the case, you will see entries in your Windows (Application) Event Log [Start > Run… > type "eventvwr.msc" (without quotes), then "OK"]. Its entries will have a "Source" of "Userenv", and an "Event" ID of "1517" and/or "1524".
THE FIX:
Fortunately, there’s a very easy fix. It’s a handy little tool called "User Profile Hive Cleanup Service", and is published by Microsoft. Once installed, it will monitor for all such events and safely release the registry logjam. It's a tool EVERY (repeat EVERY) Windows_NT operating system (i.e., 2000/XP/2003) should have installed.
REFERER: http://www.microsoft.com/downloads/details.aspx?FamilyID=1b286e6d-8912-4e18-b570-42470e2f3582&DisplayLang=en
DOWNLOAD: http://download.microsoft.com/download/a/8/7/a87b3d05-cd04-4743-a23b-b16645e075ac/UPHClean-Setup.msi OR http://www.snapfiles.com/get/uphcservice.html.
Please post back with a status report and/or with any further questions.
"Today's the best day of my life...and NOW you're part of it!"
Dec 24, 2008 | Acer Aspire 5720-4230 Notebook
Computers & Internet Logo
David Payne
David Payne
