Got a few error messages on my canon IR c5185. E20- 03BC help
  • 121 Answers
SOURCE: Canon IR 1600 Error message E000
You'll need to replace the fuser unit. Not exactly the cheapest part of the machine...
Unless, that it, you were taking things apart and happened to unplug something accidentally. If you take the cover off where the paper comes out, look at the connectors directly inside there under the black piece of paper that you'll see. If one of those are pulled out, it could cause the problem.
Otherwise you need to replace the fuser unit.
Erice
Posted on Nov 23, 2007
Cogz
  • 1326 Answers
SOURCE: Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Posted on Mar 16, 2008
SOURCE: Canon ir 3100 cn error code e000020-0081
I just had mine serviced for the same code if you take the drum out and wipe the sensor inside the unit that should do it
Posted on Aug 14, 2008
SOURCE: Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
Posted on Jan 12, 2009
  • 20 Answers
SOURCE: imageRUNNER 400S Copier: Canon IR 330-400 Ps Ver 1.0 i keep getting the ...
E-100 is an error of the Laser Beam detect PCB. Either the laser unit is not working or the beam detect PCB is not detecting the beam. You can't see the beam so don't try. Since you are also getting a E-220 which is a Scan Lamp error. Most likely cause is a ribbon cable between the CCD unit and Image Processor PCB. You may need a tech to trouble shoot this problem
Posted on May 20, 2010
I can E000400-0100
Power on error code E400.
E400-0100
can occur if the Communication Cables on the rear of the scanner are loose or improperly connected. Re-seat all the cables on the rear of the scanner.The problem is with the adf. You can try to reseat the connectors on the adf controler PCB. Only do this with the copier turned OFF. If that does not work you will most likely need to replace the adf PCB.
to see the location of PCB click the link below:
http://fexya.blogspot.com/2016/06/canon-ir-c5185-error-code-ir5075n-e400.html
this will help.hanks
May 16, 2015 | Canon Office Equipment & Supplies
Please, my canon imagerunner ir c5185 printer/copier has the error message E000350-0000. How do I solve the problem? Thank you in advance.
Main controller PCB error.Check the connectoon between the main controller PCB and subcontroller.If not good replace one or another
Apr 03, 2015 | Canon Office Equipment & Supplies
How to clean error code E000732-8888 for canon IR C5185
E732 Reader communication error.
Check the connections between the reader controller PCB and main
controller PCB. Check the power supply of the reader.
Mar 11, 2015 | Canon irc5185i
How do I fix my Canon IR c5185 printing double image
Check the fusing unit if the heat roller engaged? The unfixed image at the roller causing Double image too in Canon IRc5185.
Nov 27, 2014 | Canon irc5185i
E000808 0000
Please What can the solve of Problem Restart the machine if problem persists call service rep. error message : E000808-0000 model canon ir 2420L
Nov 30, 2013 | Computers & Internet
Canon IR C-4580 with Fiery controller
No, but the fiery will just speed up your prints etc.. I have the c3380 and c5185, they are stand alone with no fiery. If you are buying this machine for office coping it will be fine. But remember! this is a Buisness Color machine. In my customer base the 80's have done well as long as you run them as an color machine and not the office black and white work hourse. The color prints are great without any help from fiery. Sales people will try to sell you all!!!!
Jan 06, 2010 | Canon ImageRUNNER 1670F Copier
Canon IR C5185 printing black copies, would replacing black drum fix the problem?
replace the black charger... if the copies are coming out strongly black with no white lines then your drum is good... the charger died...
Dec 08, 2009 | Office Equipment & Supplies
Error code e000747-c51b Canon irc5185 system keeps shutting down displaying the above error message
E0747 is usually the cable between the scanner and the machine. (on most canons)
Make sure that the cable is not plugged into the wrong port, also make sure it's not loose.
Dec 07, 2009 | Office Equipment & Supplies
Canon ir 2016 copier on display says ( Download Standby) thanks
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Apr 18, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
32 people viewed this question
jasbo
jasbo
