Question about Leviton MFG L00-IPI06-1LM DIMMER SLIDE CONTROL
How to connect a Leviton Slide Dimmer with Preset to a double switch box where one switch controls a chandelier(the switch I want to connect the dimmer to) and the other switch is part of a 3-way swi
The two switches in the question work independently of each other but share the source of power coming into the box.
  • 744 Answers
SOURCE: I have a leviton 057 with 2 black wires and 1
See this link:
http://www.easy2diy.com/cm/easy/diy_ht_index.asp?page_id=35720237
Be careful
Posted on May 10, 2009
bschilz
  • 2049 Answers
SOURCE: Have a Leviton dimmer with red, black and green
You are correct in assuming green is the ground and connects to bare copper wire. Black is always the HOT wire and should be attached to the black wire. Red wire connects to white wire.
Posted on Sep 13, 2009
  • 66 Answers
SOURCE: I have a leviton trimatron 6683 3-way switch with
There are a possible two problems you might have. First a quick explanation of 3-way systems. If you have a common 3-way system, one switch box will have the "Power End" and the other switch box will have a "Switch Leg" end (the wire that goes to the actual light fixture. Then inbetween the two boxes there will be two (usually red / black ) "travelers" that connect to the switch. http://www.electrical-res.com/EX/10-19-02/3-way-switch-wiring-diagram.jpg Here is a link to a standard 3-way system. In the picture, the switch on the left is the "power end" and the switch on the right is the "switch leg" end. the first thing to do is establish whether you are in the "power" or "switchleg" box. You can do this by completely disconnecting the dimmer, then test which wire has power using a voltage meter. (do not use a "hot stick"! the tester that beeps or lights up when it senses voltage. These can give you a false reading) Once you know which wire has power, go to the other switch and flip it. If the same wire still has power, then you are in the "Power" side of the 3-way, IF A DIFFERENT WIRE HAS POWER NOW, YOU ARE AT THE "SWITCH LEG" side of the 3-way. The most frequent mistake made while installing a 3-way switch is getting the common and travelers mixed up. If you are in the "Power end", the "common" (or connection to your dimmers black wire) should be the wire that had power no matter which position the other switch is in. If you are in the "switchleg" box, the "common" or black wire from the dimmer should connect to the third wire that DID NOT HAVE POWER no matter which position the other switch was in.
The second (and less common) mistake with 3-way systems and dimmers is that certain dimmers are REQUIRED to be on either the power or switchleg side to work properly. If this is required it should be stated in the instructions!. Good luck and feel free to reply if you're still having trouble getting it going.
Posted on Feb 04, 2010
SOURCE: leviton 057 dimmer 2 black and 1 green wire in a
i want two dimmer switch parrel they both fhave two black and one green how fo you wire it up
Posted on Jun 15, 2010
  • 760 Answers
SOURCE: I hooked up the leviton IP106 dimmer switch for a
I'm assuming you've connected the line (hot) on the black and the load (out to fixture) to the red? So does the light stay on or your tester is measuring voltage. Some electronic controls will test voltage on a tester. if there is no load connected
Posted on Aug 03, 2010
How to you install a Leviton Slide Dimmer with Preset No. IPI06 to a double switch box where one switch controls the ligth fixture over the table(the one I want to connect the dimmer to) and the secon
Hi Velie,
I am an electrician and can help you wire this switch. If I understand correctly, you have a two-gang switch box in the wall. In it, you have two switches installed. One switch is a 3-way type, and is one of two (or more) switches used to control preparation area lighting. The other switch is a single pole type and controls a light over your kitchen table. Right?
If this is correct, remove the double switch wall plate. Let's set aside concerns with the 3-way switch. We have nothing to do to this switch so we will not need to remove it from the box, nor will we need to disconnect it. It works independently of the switch that controls the light over the table.
Remove the switch that operates the light over the table. If it is indeed a single pole switch, it will have just two terminals for wires to connect. It will probably also have indications for ON and OFF on the handle. If installed correctly, flipping the toggle up or pressing the top of the switch will turn the light on. If is a 3-way switch, it will have terminals for 3 wires to connect. One of the terminals will be a dark color from the other two. Additionally, no ON and OFF markings are on the switch handle and the light may turn on in either handle position (depending on the position of other switches controlling the light). With this information, I assume that you have now verified that it is in fact, a single pole switch. Right?
If all is going as expected, then we can continue. Shut off the power. Since a single pole switch has only two wires to connect, this should be fairly easy to do. One terminal should have a single wire that goes to the light over the table. The other terminal should have a wire that is powered all the time. It is very possible that the wire that connects to this terminal is ALSO is connected to the the 3-way switch either directly, or by a short length of wire that has a wirenut to connect several wires together. If you need to verify a connection to the 3-way switch, remove the switch from the box if needed (do NOT disconnect any wires). The wire should be connected to the dark colored terminal screw of the 3-way switch. This would indicate that this wire - and those connected by wire nut to it - is the source of constant power. Carefully fold the wires into the box and re-secure the 3-way switch if you pulled it from the box.
You new switch has a single RED wire and TWO black wires. Twist a wirenut cap on ONE of the black wires (it does not matter which). Remove the wire that was determined to be powered all the time (was also connected to the 3-way's dark colored terminal) from the old switch, and twist it around the dimmer switch's remaining BLACK wire with a wirenut. Disconnect the remaining wire from the old switch and twist it around the dimmer switch's RED wire with a wirenut. Add the dimmer switch's GREEN wire in to the bundle of uninsulated ground wires in the wirenut inside the box. Fold all the wires gently into the box and secure the dimmer to the box. Install the wall plate and turn on the power.
I hope this helped & good luck!
Feb 10, 2012 | Leviton MFG L00-IPI06-1LM DIMMER SLIDE...
I can't get the yellow wire of the dimmer slider to work properly using a conventional 3way switch on the other side. I do have the slider on the load box. Could it be that i need a Lightolier ZPR-3 on the...
Most of this style lightolier product requires the proper remote such as the zpr3. Leviton illumitech is a similar design, but uses regular 3 way wiring.
There are others out there as well, that do not require the remote.
Mar 05, 2011 | Lightolier 600Watt Preset Slide Dimmer
I believe my power source is in the ceiling. I just want to wire a light but use a leviton switch and dimmer at the wall. Can't figure this one out. Can you help. There are two red wires, one black and...
Question needs more details. Let me answer as if you have one light and one switch, and one cable coming into switch box from ceiling.
Usually a switch-dimmer combo operates 2 different Loads (lights).
One light is controlled by switch, other by dimmer.
If power source is in ceiling, then one cable enters switch box.
Cable has black, white and ground wires
Old switch had 2 brass screws where black and white wires connect
Black wire brings Hot down from ceiling, and white wire connects back to Load (fan).
Neutral wires are in ceiling box, and not inside switch box, and are discussed.
With new dimmer: Black Hot wire from ceiling connects to dimmer black wire.
White Load wire connects to one of the red wires.
The other red wire goes to another Load, which is unknown at this point.
Add a comment for more free help. Say what cables and wires enter box, and what Loads you are controlling. Also add exact model number so expert can reference manual. Levition instruction sheets and manuals usually have toll free number.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 22, 2011 | Leviton MFG L00-IPI06-1LM DIMMER SLIDE...
Changed out 3-way switch with 6633-p and it will not operate light. this is a 2 location 3-way being used on a dining room chandelier.
Look at 3-way drawing in 6633 manual.
Notice that device has to be installed to Hot wire.
Only one of your 3-way switches will have the Hot wire.
Change device with other 3-way switch.
Make careful note of which wire connects to dark-colored screw. This is the common screw.
Dec 29, 2010 | Leviton 604-6633PW Decora Slide Dimmer...
The dimmer switch will turn on and off but wont dim the lights on a chandelier. model 6681-w. tried 2 different ones with the same results.
The Leviton 6681 is a push-button rotary-type incandescent dimmer with 600Watt capacity
If you have incandescent bulbs, the dimmer should work.
If the dimmer has different color wires, try reversing the wires.
If the dimmer replaced a 3-way switch, then this is not the right dimmer.
If you have compact florescent bulbs, you need a dimmer that also dims florescent.
http://www.google.com/products/catalog
Link shows the Leviton 6673 incandescent and florescent dimmer
But you also need dimmable compact florescent bulbs.
http://www.amazon.com/DIMMABLE-COMPACT-FLUORESCENT-LIGHT-SPIRAL/dp/B0014B84ZM
Oct 31, 2010 | Leviton #L11-06681-00I Ivory 600 Watt Push...
I just installed a chandelier. This is a new connection. So I ran a 3 wire from the chanderlier to a new lutron slide dimmer. I then ran a 2 wire from this dimmer to the switch. When I turned the...
Lutron Dimmer manuals
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
Lutron manuals show a couple things that might be affecting you lights.
1) Wattage: If you have wrong wattage dimmer
2) Type of light bulb: Dimmers work on different types of bulbs
3) Wiring: You say you got 3 wires going to the chandelier? Why you got 3 wires? Is this a 3 way switch? Are the chandelier bulbs wired separately so you can control groups of bulbs with different switches?
Does the dimmer have 3 screws? A dark-colored screw and 2 brass screws? If so, then that sounds like a 3-way dimmer. A 3-way, is where more than one switch controls the same light.
Does the dimmer have 2 screws? Then that dimmer controls a single circuit. Your black Hot wire from breaker box connects to one screw and the black wire to Load connects to other screw.
A quick glance at Lutron wiring manual shows that Hot and Load wires connect to either screw.
The question is your 3-wires from the chandelier ... does the black Hot wire from breaker arrive in the ceiling box first? Or does it arrive in the wall box first? If your Hot arrives in ceiling box, then the Hot must come down to the switch box and connect to a screw on the dimmer >>> a second wire connects to other screw on dimmer and travels up to the ceiling box where it connects to black wire on chandelier. The white wire on chandelier connects to white Neutral.
4) Dimmer might be bad
Oct 16, 2010 | Lutron #DVW-603PGH-WH 600W White Single...
My girlfriend has a leviton illumatech IP106 that keeps "not working". after a number of months. It is operarting a standard dining room 6 light chandelier. A couple of her friends have replaced this in...
As a general rule for timers and dimmers:
The Black dimmer wire connects to black hot wire coming from breaker (122V line)
The red dimmer wire connects to Load (wire going to chandelier)
The wall red wire that is capped could be a couple different things. a) It could go to a second switch that was used to control the chandelier. b) it could be another wire that goes to same ceiling box as chandelier to be used to control a fan, except you don't have a fan. In the second case, if you install a fan with a light, you could control fan and light separately.
The green is a ground wire that connects to bare copper wire in box. The bare copper connect back to main breaker box on the Neutral busbar.
White wires that are twisted together inside your light switch box also connect back to to main breaker box on the Neutral busbar.
The ground wire and neutral are a redundant safety system to protect you from electrical devices and appliances that have 'shorted'
The black hot wire connects back to the circuit breaker.
For example, each circuit breaker controls one area of household lighting. The black white and copper wires leave breaker box in a single romex cable. The romex travels to a junction box in the area where the lights are located. The junction box is usually a switch box or a ceiling box. From the junction box, the romex travels to each other switch, light and receptacle box in the area. So each box has 1 hot and 1 neutral and 1 ground that is connected in a line that leads back to breaker box.
Here's a couple pages that make home wiring easier to understand:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/240-v-water-heater-circuit.html
http://waterheatertimer.org/Install-owb.html
Oct 15, 2010 | Leviton Decora Light Dimmer Switch
I hooked up the leviton IP106 dimmer switch for a single pole and when I test the it, switching it off and on it stays hot.
Aug 03, 2010 | Leviton MFG L00-IPI06-1LM DIMMER SLIDE...
Newly installed Leviton dimmer switch humming at the switch
Unfortunately, the hum is normal for operation of that type of dimmer at low levels.  Sometimes the lamp filaments will also "sing" a high pitched sound.
Mar 17, 2009 | Lutron #D-600PH-DK 600W SP Push Rotating...
Leviton slide dimmer switch w/locator light light comes on but doesnt dim
What sort of light is it , dimmer switches normally only work on Incandescent type lights not flourescent type.
Otherwise it sounds as if the dimmer function is faulty.
Nov 02, 2008 | Leviton Decora Light Dimmer Switch
Leviton  MFG L00-IPI06-1LM DIMMER SLIDE CONTROL Logo
70 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
