Question about Mitsubishi WS-55511 55" Rear Projection Television
Does it have HDMI
I do not know if I can connect a HDMI required equipment
Only if it has hdmi input.
Posted on Feb 10, 2012
How to connect to tv
There are several ways to connect a game console to a TV. The question is, what system are you trying to connect? Some features may be available for the newer generations, that are not on older models. I'm assuming, since you have posted with a picture of a Sony Playstation 3, (PS3) that is the system you are trying to connect. The easiest way to install is to use the supplied (RCA) connection cords that comes with every PS3 system. One side connects to the corresponding port in the back of the system, and the other end has (3) multicolor plugs. They will match the colors on most TV's. Some of the older TV's do not have the RCA ports and will require an adapter to connect this way. These colors are; YELLOW (video out) RED (audio out right channel) and WHITE (audio out left channel or MONO) The PS3 also has and HDMI port, and is much simpler to connect the TV and game console together. As I stated before, not all TV's are equipped with HDMI. HDMI cables carry both the video and the sound through 1 cable. To install this way, simply turn on your TV to the correct aux port, in this case HDMI, then connect the the HDMI cable from the PS3 to an available port on the TV. After you have connected the cords, turn the system on and it will tell you that it has "Detected an HDMI connection. Would you like to use this connection?" Select yes. The rest is automatic.
Also, if you didn't know and are needing a new rca cord to connect to the TV, search for a cord from one of the older systems in the SONY family and they will save you some cash, as they are all exactly the same. PS1, PS2, and PS3 all use the same connection. I hope this helps. Good luck!
Aug 25, 2015 | Video Game Consoles & Games
How do i connect my samsung n10 to hmdi on my television
All HDMI connections require a HDMI cable with one end inserted into the source devices HDMI output and the other end inserted in the TV HDMI port. If you lack that cable TigerDirect has them. They come with different size ends, so make certain you know what connectors you require.
Jan 05, 2014 | Computers & Internet
Is there any alternative to using hdmi input to the tv
Yes, there are several ways to connect to the tv. HDMI is the (NEWER) way to connect the console. The reason being, is because HDMI carries both video and audio. The standard way to connect is by using the provided (RCA) cords that came with the system. They connect by splitting the video(yellow) and audio(white=left red=right) Almost all tv's out now have either HDMI or the audio/video inputs, and are typically cable ready.(little threaded plug in the back that your cable box hooks into) You can purchase a cable ready adapter from game stop or even use the one from an existing PS2 or PS1. They all use the same adapter from the system. The only difference is, if you don't connect with HDMI then you are NOT going to have high def available. It will be in standard def all the time. The final way to connect is a bit difficult. It requires a bit of knowledge in what your doing. HDMI to a HDMI adapter to DVI-I or DVI-D monitor. Some tv's come equiped with a DVI-D input so it can double as a monitor for a computer. This way WILL give you HIGH DEF and arguably the best picture you will ever get because you can set the frame rate (frpm) your self. Hope this info is useful. Good luck. ^^
Nov 29, 2013 | Sony Video Game Consoles & Games
How do I connect my internet equipped PC laptop to my LG HDTV?
The easiest way would be with an HDMI cable. Check if your tv and computer have HDMI ports.
Jun 30, 2012 | LG Computers & Internet
Can I use a Samsung 3D blu ray player with a 3D Sharp TV
In theory it should work but there are some know compatibility problems with HDMI connections mainly on older equipment so it is usualy better to use equipment from the same manufacturer. Key points are to make sure you have the latest firmware update installed in your blu-ray player (& TV if you have the option to do it.). Second issue is to make sure you use a suitable HDMI cable. It must be at least a "High Speed" HDMI cable. Sometimes labeled HDMI 1.3 or 1.4. I use 1.4 version cables purchased online from Cables UK . Dont spend a fortune on expensive cables from currys/comet etc. they are a massive con.(digital signals dont need expensive cables).
Nov 27, 2011 | Televison & Video
I connected my receiver to my hdmi dvd player and ps3. I am able to get a video connection however there is no audio. I have connected evrything via HDMI. Also, I ran all the troubleshoots mentioned in the...
You are not alone...Sometimes HDMI connections fail to provide Audio on some equipment ...
You should carry Audio separately with a RCA cable..
OR without HDMI ,you can make the following connections:
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your DVD
** to "AUX input " or "DVD " OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
RECEIVER corresponding your RCA or Optic connection...
There you go..Both DVD sound and Video are on the
Receiver..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 29, 2011 | Onkyo TX-SR505 Receiver
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
Tv wont display hdmi connection when pressing input on remote or changing channels on the tv itself
Try a hot swap. Turn off the television and the connected equipment. Remove the hdmi cable for a minute or two. Plug the cable back in in another hdmi input if possible. Turn the television on. Turn the connected equipment on. You may need another hdmi cable. At most you will need to replace the hdmi board in the television.
Oct 28, 2010 | Sanyo DP32746 32 in. LCD Television
Digital boxes
This model only has an analog tuner, so you will require either a converter box or hi-def tuner after the transition.
Dec 07, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Mitsubishi WS-55511 55" Rear Projection Television Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
