Question about Watches
I cannot set my digtal watch 1-ld2900 - Watches
  • samuel jones Feb 10, 2012
    i have tryed the mode but it will not let me into the set time
How to set digital part of the watch
[PDF]4 Button Digital Watch - Dakota Watch
https://www.dakotawatch.com/PDF_FILES/Digital.pdf
In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.
how to set time in digital watch - YouTube
? 1:13
https://www.youtube.com/watch?v=4FmHYMeXbDA
Oct 26, 2011 - Uploaded by Vedant Sen
https://www.youtube.com/watch?v=u_H5I3H15R8 ... how to setyour digital watch {UPDATED} - Duration: 1:20. by Vedant Sen 3,424 views ... The 10 Greatest Wrist Watches of all Time REVISED FOR 2014 - Part 1 - Duration: ...
How To Change The Time On Most Digital Watches - YouTube
? 8:40
https://www.youtube.com/watch?v=kBvaePDtEUU
Jun 27, 2012 - Uploaded by Pitskate
How To Change The Time On Most Digital Watches. Pitskate ...How to change / set time on Armitron watch, 45/7004. - Duration: 2:02. by ...
Jan 05, 2016 | Watches
Can someone tell me how to set date month and day on an attention manual watch
A manual watch is set by pulling out the winder.
Those with a date have three positions:-
1 normal operation
3 fully out - used to set the time
2 half way between 1 & 3 which is used to set the date and day. In this position turn it one way to set the day and the other way to set the date.
Return the winder to position 1 after setting.
Jun 04, 2011 | Watches
Can you set the time going counter clockwise on a watch
yes, you can set the time counter-clockwise on a watch. The only difficulty that may arise from this is making sure the date window (if you have one) syncs up; but a 1 hr change for time change will not make a difference. For best results start setting with your day window reading 1 day before the current day and begin turning clockwise. Right when the day/date changes the watch is reading 12am(midnight); set accordingly.
Nov 03, 2009 | Bulova Watch
How do I set the date on an old bulova caravelle men's watch
Pull the stem out 2 clicks the in 1 click turn stem clockwise for day and counter-clockwise for month. to set time pull stem out again 1 click, when finish push in 2 clicks
Jul 09, 2009 | Bulova Watch
Can't set day of the week for armitron MD06117 mens watch
Purchased my Armitron men's digtal watch in 2009. Here's the twist on setting the name of the Day of the Week on my watch. When you get to the name of the Day of the Week flashing.. you don't get Su...Mo...Tu... You get 01..02..03... up through 99. (You think.. what the hell is this??) DON'T TRY TO SET Sun.. Mon.. etc here.. you won't find it. The puzzle solver..and it is.. IS TO SET THE LAST TWO DIGITS OF THE YEAR HERE.. Example... it is now 2010.. so scroll thru the numbers and set it to "10"!! Now.. when you go and set the numerical day date e.g. 3 for March, and set the numerical day - e.g. 15, the on-board computer?? in the watch will AUTOMATICALLY SET THE NAME OF THE WEEK!! It will look-up For Example.. in the year 2010.. 3-14 is SUN.. and will set it as that!! Hope this saves you some frustration. Regards... klsdad@mindspring.com (Mar 14, 2010)
Mar 06, 2009 | JCPenney Armitron Sport Link Bracelet...
I just bought a Mondaine travel alarm pocket watch. Instructions say the crown has 3 positions. 1> Home normal for a quartz watch. 2> Pull out 1/2 way to set alarm. 3> Pull out all way to set time. My...
It seems like your watch has a little short stem and that's why it has only 2 positions. This does not affect battery in any way, nor the timekeeping.
The only downside of this is that you can accidentaly reset alarm time without knowing it as your watch crown is in permanent 1/2 way position.
If you are happy with that - keep your watch.
Dec 12, 2008 | Watches
Watch has correct day and date only 1/2 each day
The watch thinks at Noon it is really midnite, so you must scroll 12 hours ahead to repair this. There are usually 2 "clicks" on the stem of the watch when you pull it out, 1 will set time, 1 will set the day/date, be careful to pay close attention to which is happening when you pull out the stem, and setting should go well after that.
Dec 01, 2007 | Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
