Beco washing machine wm61335 keeps flashing lights
4 Suggested Answers
mumma_1
  • 903 Answers
SOURCE: wash enhance & on/off flashing
The only time the lights kept flashing on my Hotpoint machine was when the outflow pipe going into the ubend was blocked,
Check for blockages, but make sure that you have a bucket or pan ready to collect the water flow.
I hope this helps
Posted on Nov 24, 2008
barkencoa
  • 3463 Answers
SOURCE: Pre-wash light keeps flashing
The pre wash light flashing is usually an indication that the washer has failed to take in cold water, possibly due to low pressure, or restricted inlet hose.
If it does it when it is the rinse mode, then I would suggest you check the filter is not blocked.
Remove lower rear panel, remove large black hose to bottom of tub
Remove filter inside and clean., check inlet to pump as well.
Plz rate my solution.
Thanks.
Posted on Jan 28, 2009
  • 417 Answers
SOURCE: washing machine is not draining and lights keep
It is likely that the pump/filter has blocked thus preventing the water pumping out.
You would need to check and if so unblock it. The location of the pump/filter varies with the brand but sometimes it is behind a flap at the lower front of the machine whilst on others you have to get the back off to locate it.
Posted on Jan 23, 2010
Testimonial: "that worked a treat thanks"
Hi just bought a washing machine it is all working but lights keep flashing
new or used
search online for the maker and model users manual
the newer washing machines these days
with the computerized control boards
like to flash light up till something is selected
Jan 22, 2017 | Washing Machines
WF-F7061DN washing machine water level lights flashes
Are you overloading the machine? If you run the machine without anything inside and this happens, check the motor or belt.
Jan 14, 2014 | LG Washing Machines
My indesit washing machine 12 hundred keeps flashing blue and red lights and won't do anything
Possible that the suspect could be the controller board, you can switch the machine off power for sometime, check the power outlet for the correct voltage. If not the front panel must be removed to check on the board and a possible fault of the processor or memory.
Feb 03, 2013 | Washing Machines
Beco washing machine wmb 91242 LC XL 9 what does error code c on mean?
This code refers to Child Lock On. On the buttons you will see a lock symbol linked between Quicker Wash and Anti Crease. Press and hold these to set lock on and off
Jan 14, 2013 | Washing Machines
Hotpoint wma32pr door light keep flashing and no wash
1) test the lid switch for open
2) test the door switch for open too
3) see the diagram attached, any switch faulty can not START the motor.
God bless you
Jun 19, 2012 | Washing Machines
Simpson encore 605 fault code are as follows during wash process stop suddenly, strat to beep and all lights are gone except the Maxi light . It flashs while beeps
Hi, my Simpson encore 605 wash machine wash on the half way keeps beeping, and the maxi is keep flashing. What kind problem it is?
Cheers!
Feb 12, 2012 | Washing Machines
"Clean" light keeps flashing. Machine doesn't
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Kenmore Dishwashers
Agitator starts while filling, all cycles seem to work fine 11029822801
the machine seems to be in a good condition ,becos it will start agitating when it has received the acquired amount of water it needs to wash.
Jun 24, 2011 | Kenmore Washing Machines
Washing machine is not draining and lights keep
Jan 23, 2010 | Indesit Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
