Question about Seiko Smart Label Printer 200 Thermal
Smart label printer will not print - Seiko Smart Label Printer 200 Thermal
SOURCE: Smart Label Printer 240
Check your labels. Are there black "sensor marks" on the back of each label? That's apparently how the printer lines itself up.
Posted on Apr 02, 2009
SOURCE: I have a Smart Label 100 printer that won't print.
WHEN THIS HAPPENED TO ME, I DELETED THE PRINTED AND REINSTALLED IT...
Posted on Aug 20, 2009
  • 232 Answers
SOURCE: how do I export from outlook to my seiko 440 smart printer
I'm not familiar with this printer but usually you export details as a .csv file which you can import in to most other software packages. If you need more help, please can give more detail. Thanks :)
Posted on Dec 12, 2009
nicarta
  • 506 Answers
SOURCE: How do I set the printing preference for my smart
I guess you want to make this printer your default printer.
These are the steps
1 Click start then Printer and Fax
2 Locate the Printer you want set as the default Printer
3 Right click the computer and choice Set as Default Printer
this will set the printer to the preference printer.
Posted on Dec 30, 2009
SOURCE: Smart LabelPrinter Seiko 440
These printers are designed to use only the labels with the ink bar on the back. the ink bar is the guide that tells how much to print.
Posted on Oct 24, 2011
What in the world!! I have the Smart Label Printer 450, it is not advancing the label, and the power button is flashing. It will not print a label at all at this point, and when it will end up printing a...
Unfortunately, this is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. This means your Smart Label doesn't think its wasting labels, it's just trying to run through what it considers to be unsuitable labels as fast as it can. If you're only printing one label at a time you can recover some labels by correctly the label's line up after each label you print but there's nothing you can do so that your printer will properly advance its current labels.
Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
May 08, 2014 | Seiko Smart Label 240 Thermal Printer
Smart Label Printer
If the answers above don't work check your AC adapter with a multimeter to confirm its output voltage. If the voltage is off by more than 1 volt you will need to replace your network driver
Apr 21, 2014 | Seiko Smart Label 240 Thermal Printer
Seiko smart label printer 100 not printing
A censor within the printer probably needs cleaning.
Apr 08, 2014 | Seiko Smart Label Printer 100 Thermal
Can Cymo lables be used in the Smart Label Printer 100
If you mean Dymo labels and if the Dymo labels have a black rectangle on the reverse and if the labels aren't to wide, then the labels should work. You may run into problems with the Label printer advancing too far after printing; unfortunately, you will have to manually re-align the label after printing
Feb 13, 2014 | Seiko Smart Label Printer 100 Thermal
After printing a label it advances too far wasting the next label
This is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
Jan 03, 2014 | Seiko Instruments Smart Label 450 Thermal...
Hi there I just got a new computer and try to copy the old smart label printer over, but when I try to print the label out, I got a message says.." SLP print manager can not start" What I...
when you say uyou copied the old printer over I assume you actually reinstalled the Printing Application from scratch?
You cannot just copy the seiko directry over, t doesnt load the .dll files
reinstall the application
biffo
Sep 08, 2011 | Seiko Smart 440 Thermal Label Printer
The code between the labels indicates either you are using labels designed for another model or that it is thinking it has a shippinhg label opr some lareger type installed. IT is more likely to be the first option, you are usinjg the wrong coded labels
Please rate my help++++Thanks for using FIXYA
Dec 06, 2009 | Seiko Smart Label Printer Pro Thermal
Jan 16, 2009 | Seiko Smart Label Printer 100 Thermal
Printer working fine - when it stopped printing in mid of alabel♠
If reinstalling the drivers doesn't work... sadly I think it's time for a new one..!
Mar 30, 2017 | Seiko Instruments Smart Label Printer 430...
Hi, My Smart Label Printer 430 was working fine until I unplugged the back 2 cords to change the tape in it. How do I get it to print again?
unplug your Smart Label Printer (slp430) from your pc,
go into your control panel, then to add/remove programs.
remove the slp430 software then reboot your pc.
DONT PLUG IN YOUR SLP430 yet...
reinstall the software that came with the label printer.
follow on screen instructions.
plug power in for the printer
then attatch to your pc.
if this doesnt work let me know ; )
Jan 05, 2009 | Seiko Instruments Smart Label Printer 430...
Seiko Smart Label Printer 200 Thermal Logo
23 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Scott Kalvinek
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
