Question about Dell 3000cn Laser Printer
Removing toner cartridge
How do I remove the toner cartridge for Dell 3000cn color printer? I have pulled out the blue bar from the side & front then try to pull out the yellow cartridge, to no avail
  • Jenn M Dec 11, 2008
    I even talked to Dell tech support and I followed the manual exactly. The cartridge just won't pull out!
  • 73 Answers
When the toners go in, they are locked down using the colored part of the cartridge. This holds them in place for printing. However, sometimes even when unlocked they can be very difficult to remove.
After you are sure it is unlocked, do your best to wiggle the cartridge until it start to feel like it is coming loose, and you should be able to pull it out. Do not under any circumstances force it out, just take some time to loosten it up.
Posted on Feb 08, 2009
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
Dell 3000cn Printer
I think the following instructions are quite clear. In any case, before giving an inappropriate rating pleas contact us. Thanks for trying rating should be used only for unhelpful solutions and I do not think these here are the cases. Please follow the instructions from point six:
6 - Connect the printer to power and turn it on
7 - The toner cartridge carrier rotates and then stops. After confirming
the Insert Black Toner (K) message, open the front door.
8 - Hold the tape on the protective cover and gently pull it forward to
remove the cover from each cartridge slot. You only have to remove the
cover from each toner cartridge slot the first time you use your printer.
Toner will be present on the roller.
9 -
10 - Lift the tab up 90 degrees and pull the toner seal straight off, keeping it
parallel with the toner cartridge.
cf252ec.jpg 11-
To insert the toner cartridge, face the label on the cartridge to the front
and align it with the arrows on the printer. Guide the cartridge until it
snaps into place and then push down the handhold to lock the cartridge
in place.
12 - Close the front door. The toner cartridge carrier rotates to the next
empty slot. When the color of the newly inserted cartridge appears on
the display, followed by the Insert message, insert the next toner
cartridge. Repeat steps 6-11 until all cartridges are installed.
Here is the link to download tha manual:
http://support.dell.com/support/edocs/systems/3100cn/he/placemat/3100cn_setup_diagram.pdf
Hope it had been helpful, let me know if you need further support
Feb 15, 2008 | Dell 3000cn Laser Printer
What to do when toner is low
Remove the toner cartridge.
Gently "roll" it from side-to-side, to evenly distribute the toner. Do not "shake" it.
Eventually, you'll either need to buy a new toner-cartridge (either from Dell or via eBay) or find a store that refills ink-jet and ink-toner cartridges.
Apr 16, 2010 | Dell 3000cn Laser Printer
Get code 004 332 restart printer. have removed the four toner cartridges and replaced the drum cartridge and the same code appears
Hello,reseat and clean the four toner cartridges, verify the orange plastic covers have been removed, and verify the cartridges are fully locked into place, .This is the procedure:
1. Press the Menu button and press the down arrow until Replace Toner appears, and then press the "ENTER" button.
2. Press the down arrow to choose the appropriate color toner cartridge and press the "ENTER" button.
Note:If the Menu button is inaccessible, begin replacing the toner cartridges with step number 3.
3. Open the front cover.
4. Lift the handle of the appropriate colored toner cartridge and remove the toner cartridge.
5. Gently rock the toner cartridge from side to side.
Note:Rock the toner cartridge over newspaper as there may be some toner leakage.
6. Gently wipe the exterior of the toner cartridge with a dry cloth.
7. Verify the mag roller has been removed.
Note:Grasp the orange strap, peel the tape away from you, and then, with the tape free, pull the blue strap toward you.
8. To reinstall the toner cartridge, align the arrows on the cartridge with the corresponding arrows on the printer, guide the cartridge in until it snaps into place, and then push down the right lever to lock the cartridge in place.
Note:Ensure each cartridge lever is fully pressed down into the locked postion.
9. Close the front cover.
10. Repeat steps 1 through 8 until all toner cartridges have been reseated.
Good luck
Feb 05, 2010 | Dell 3100cn Laser Printer
My 3000cn ran out of black and cyan toner, so I
I have fixed this now using advice that I found from other users on this site who had posted similar questions. In case it's useful to any of you, pull open the front cover and operate the small blue lever that you'll find behind it on the right. This opens a secret compartment on the outside of the printer and there you will find the cleaning rod. Pull and push this in and out about 15 times and it should fix any problems like the one I had.
Jan 28, 2010 | Dell 3000cn Laser Printer
Unable to remove black cartridge, it is really stuck. Help
I just changed my black toner this past week, and finally figured out why the cartridges get stuck like this.
First, you must eject the toner cartridge on the front-panel menu:
Menu->Replace Toner->Eject Toner->Black(K)
It will say "Rotating to Black Toner(K)" and then say "Black Toner(K) Ready to Eject"
Now, open the front panel and you'll see the black toner cartridge in front. You can also open the top panel if you want more light on your work area.
Lift the lock handle on the old toner cartridge to the "unlock" position, and here's the part that the Dell instructions don't have:
There are two channels for the toner cartridges -- one on each side. Run your finger down the channel on the right, and you'll feel a small, spring-loaded catch. This catch often gets sticky and won't release the cartridge without some help. Don't force it, but gently move it towards the back of the printer and it should release.
Now the old cartrdige should slide right out, and you can finish per the instructions that came with the new cartridge.
Jan 27, 2010 | Dell 3100cn Laser Printer
How do you remove toner cartridge from a Dell 3010cn color laser printer correctly.appears to be stuck trying to remove
This is how to Install or replace the Toner Cartridge.
Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
Cheers!!
Apr 21, 2009 | Dell 3010cn Laser Printer
Changing Dell 3000cn printer cartridge
The instructions always come with the new cartridges and also are printed on the new cartridges. You move the right hand (colored) side up to unlock. Carefully pull the cartridge up and out (you can screw up the gears if you don't put the cartridges in and out straight. Make sure you've followed the instructions that come with the new toner cartridge (removing tape, shaking), put it in the same way and move the right hand side down to lock.
Apr 07, 2009 | Dell 3000cn Color Laser Printer
Dell 3010cn
open the front cover, on the left side there is an you will see a small opening in line with the toner. I used a folded peice of paper to press the small lever inside the opening. This will allow the toner carousel to turn. There is a groove that aligns with a notch on the toner cartridge. Line this up and you should be able to remove the cartridge.
May 30, 2008 | Dell 3000cn Laser Printer
Dell 3000cn Laser Printer Logo
177 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
