Question about Dishwashers
EIDW6305GS electrolux dishwasher, drying damper location
Got 04 err code drying damper not working. Can't find a diagram of what it is or how it works or where it is located. Is it eletrical vent or fan? Does the dishwasher need to come out of the cabinet to get to it?
SOURCE: Miele dishwasher - Turbothermic drying
I found this elsewhere on the net. Seemed to work for me. You need 2 pairs of hands though 1 to hold things together the other to work the screw driver. Thanks to Peter.
I had the same problem on my Miele Dishwasher. Basically the outlet built into the door gets gummed up. You can access it by undoing the screws around the edge of the inside of the door. This will allow you to release the front door cover from the inner stainless steel cover and there will be the tubes etc. for the front vent. Take them off and you will find them blocked with gunge. Give them a jolly good clean so it allows the condensation to drain back into the machine . You will also find the fan in there as well. Clean all around that as well if it's dirty. Put it all back together and no more gurgling or water on the floor when the doors opened. Hope this helps.
Pete
Peter Jeffries Isle of Wight
Posted on Dec 20, 2008
  • 14 Answers
SOURCE: Miele dishwasher drying problem
you need to remove the front of the door.there is a small pipe from the dryer fan to the top of the detergent dispenser. tis usualy gets blocked at the fan end. also the spout from the fan. this happens if you dont rinse loose food of the items you put in the dishwasher.
Posted on Aug 26, 2009
EllaWatson25
  • 725 Answers
SOURCE: how do I improve the drying in my electrolux
The energy efficiency that has so much attention by the EPA has made it so that they probably will not dry completely any longer. Has the unit ever dried completely before? If it hasn't, then the only thing you can do is adjust your dishes so the water will not stand in the bottoms of cups, etc.
You might also check your heated dry "feature" on your dishwasher to assure that it has been selected to dry at optimum heat temperature. Also, do not open the dishwasher before the drying cycle has been completed.
Bosch has the best drying dishwasher model made so when it's time to replace this unit, choose a higher end Bosch for the best drying and the quietest models available.
We hope this answers your questions and should you need to contact us, you may do so at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service.
We hope to be able to assist you again. Thanks, Ella
Posted on Nov 11, 2009
mc1bean
  • 3053 Answers
SOURCE: error 4 displayed in my
Hello, bss
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
nabbot
SOURCE: Drying cycle vent fan is noisy. How can I fix it
I had the same issue but mine is an inbuilt unit. I removed the 4 screws for the front main facia panel which was then removed. Following this I removed the 6 screws that hold the plastic control cover in place and then the three screws (1 top centre and 1 on left and right) that holds the control plate which I then gentrly lowered.
I then used a flat blade screw driver to turn the inside fan cover anti clockwise about 45 degrees which allows the fan module to be removed. Then disconnected the drain pipe at the fan module only and power and control cables.
I then blew the gunk out of the fan module and gave this a good wash through with hot water to ensure it was clean and then dryed with paper towel. I then also blew out the drain pipe. The remaining gunk was blown into the interior of the dish washer out a vent just below the rinse aid unit.
If I need to do this again then I would have removed both ends of the pipe and washed this through with hot soapy water to make sure it was clean.
To reassemble do the reverse process. Assistance will probably be required to reassemble the front main facia panel as one person would need two hands to hold in place and another to locate and start the screws. A couple of clamps could over come this.
Posted on Jan 05, 2012
Just bought a 04 renault megane coupe and entered the radio code which worked however havent been able to play a cd it keeps sayin err cd also elec windows on drivers side wont work
error code on the cd means that cd is damaged, try another cd
if all your other three windows work - replace the fuse - it is situated by the glove box... to the left of it is a thin strip cover .. will be the fourth fuse .. diagram is also on the fuse cover ..... good luck ...Vinny Singh
Sep 04, 2015 | Renault Megane Cars & Trucks
Low airflow out of vents
Posted by Gary Brizendine on Jan 11, 2014
me thinks he fixed it by now.
and is not even a question.,
why?
what can i do
who can fix it.
what parts are bad.
what tests can I do.
it lacks even a question.
does it fail on high does blower work on high well?
are fuses good
did you scan it first?
oops.
Jan 11, 2014 | 2004 Jeep Grand Cherokee
Damper vents
Hello.
I own the Electrolux EWDW6505GS--0 {24'' Built-In Dishwasher with Wave-Touch® Controls}
On two occasions I have had the "Error 04
Drying Damper - Drying damper not operating"
In each case, I found the plastic 'ring nut' RETAINER in the upper right top of the machine had come loose. I simply unscrewed the retainer, wiped the area down, and re-screwed the ring on hand tight.
Sincerely,
Patrolcats
Here is a picture of the retainer;
A new retainer part (if it is broken) may be ordered here at the RepairClinic;
Electrolux Dishwasher Retainer 154622601
Use & Care Guide
http://manuals.electroluxusa.com/prodinfo_pdf/Kinston/154671101en.pdf
Service Data Sheet
http://manuals.electroluxusa.com/prodinfo_pdf/Kinston/154676601.pdf
[img alt="repairclinic.com" src="http://i.fixya.net/uploads/images/embeddedlinks/1590384-repairclinic.jpg?2.0" >
Electrolux Dishwasher Retainer 154622601repairclinic.com
Retainer 154622601 Order now for...
Oct 16, 2013 | Electrolux Dishwashers
Amana BR22VL refrigerator section stopped cooling.
is there any frost on your food packages or on the ceiling where the light is?if so the door was left open and the air vents are froze up or you have a bad damper or evaporator fan motor,open the freezer door,do you hear the fan blowing?if so the fan motor is good,check for ice on the ceiling and packages,if that checks good look at the back inside wall of the freezer,if that's covered with like snow or frost you have a defrost problem or also you have a damper in your model,it's closed and won't open to let the cold air in from the freezer.
http://www.repairclinic.com/PartDetail/Damper/R0161050/223353
go here,this is the part,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer up into the fridge section,in your model the damper door opens to let the cold air in,when it gets cold enough the damper closes and that's it,so if the door wasn't left open and the fan is blowing in the freezer you have a bad damper.
Aug 10, 2012 | Refrigerators
Air is on but not coming out of the front vent in my gmc 04 envoy
Check the main air duct from the fan. It's located behind the glove compartment. It may have fallen off. Also check the fan itself or it's fuse.
Sep 28, 2011 | 2004 GMC Envoy
My air vents are not working properly. my fan works in all speeds but the air mostly only comes thru the defrost vent. I started to take the dash apart on the passenger side but I am not sure what to do...
Many auto vent dampers use engine vaccum to actuate the dampers so if there is leak in a hose it would cause the damper to default to defrost mode. reccomend checking for hoes through fire wall under dash for breaks or disconnected.
Aug 24, 2011 | Heating & Cooling
I have an error 04 showing on my dishwasher, and the cycle will not run. Please help!
dryer damper problem. there is another post that will help from electrolux personnel.
Thank you in advance for allowing Electrolux to assist you in
this matter.
I apologize for the inconvenience and concerns this dishwasher unit has been causing you. Unfortunately the error "E04" code does indicate an issue with the drying damper. Now this is something that a technician would have to assess because wiring is needed to be checked.
Check wiring between Main Control Board and upper fan. If correct, replace upper fan.
If your unit is brand new it is covered under warranty and you can choose to contact your dealer for a repair technician, or visit www.electroluxappliances.com/servicelocator to find a listing in your area.
Kindest Regards,
Chris Polk
Online Outreach Representative
Electrolux Major Appliances
Er 01
Leak Detector - When water is detected under
the tub.
Er 02
Thermistor - When thermistor/turbidity module
fails
Er 03
Wash Pump - Wash pump not operating
Er 04
Er 05
Upper Fan - When in the dry cycle, the control
board does not receive proper speed feedback
from the upper fan
Er 06
Lower Fan - When in the dry cycle, the control
from the lower fan
Er 07
Drain Valve - When in the drain mode, the control
board does not receive proper position feedback
from the drain valve
Er 08
Tactile or touch switch - Control board has
verified a switch on the user interface is bad or
shorted
Er 09
Communications - Communication failure between
main user board and power supply
Er 10
Mains Relay - Failure in the mains power relay
Er 11
Drain Valve - Time out before finding a state for
the drain valve
Er 12
Drain Valve - The drain valve is running when it
should be off
Er 13
System wide - Lost control of the State Machine
Jun 23, 2011 | Electrolux Dishwashers
Venting hood not working on microwave mdel# JVM1630BJ03
Start the fan and check the outside vent first.I have found the weatherstrip on the exterior damper can get coated with grease and will become stuck and not allow the damper to open.
Apr 08, 2009 | GE JVM1630 Microwave Oven
Dishwashers Logo
186 people viewed this question
Top Dishwashers Experts
