Question about Olympus Cameras
My camera just stopped functioning
Bought an Olympus digital camera (FE 330;8 megapixel) this summer. I used it two days ago and after completing my session pressed the power button to end. The lenses retracted then protruded a couple of times followed by three distinct beeps. There is nothing on the screen - it is blank. At first I thought the battery had died, but I recharged it (red light on charger went off in less than an hour) with the same results when I tried again. I attached it to my laptop and was able to get the pictures taken off, but I cannot use my camera to take any pictures.
HELP!!!!!
  • Jessica Caruso Mar 15, 2009
    Mine did the same thing. I used it one day and the next went to use it again and the screen was black but it had a white streak across it as well as little spots. It was blinking and acted as if i t worked but no picture showed up no matter how many times i turned it on and off!! so basically it just BROKE!
SOURCE: Camera malfunction
when the lens are protracting i held them  and they didnt go back in. then i turned it on and it worked! but the lens dont go back in when the camera turns off and the zooming is messed up because of it, but it works!
Posted on Feb 08, 2009
  • 3 Answers
I had a Nikon Coolpix L1 with a very similar fault- the lens would whirr in and out as if seeking then lock either in or out with a 'lens error' message.
Not sure you're going to like the solution: place a paperback book on a strong table, grasp your precious camera firmly in one hand and slam its flat base down as hard as you dare onto the book. Hold it hard to the book as it touches, don't hit and lift up again; more slam effect.
I tried this and it worked beautifully; for a few months. I had to do it once or twice a year.
I got the suggestion from a site similar to this with 10 or so astonished owners who had tried it and couldn't believe it had worked so well!
Aren't digital cameras ****, though? I may go back to 2nd hand 35mm SLR for something that actually works!
Posted on Mar 02, 2009
  • 34 Answers
SOURCE: can i use a sd memory card with my olympus fe 330
No this is not possible. Olympus is using the xD-Picture Card.
If you get an microSD to xD adapter (Olympus MASD-1 adapter) it is possible to use Micro SD Cards.
Posted on Jun 09, 2009
BillB-SA
  • 2761 Answers
SOURCE: My Olmpus fe-360 wont turn on. The lens won't
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helped, please take a moment to post a rating for me. A "Very Helpful" would be greatly appreciated.
Posted on Nov 23, 2009
  • 11967 Answers
SOURCE: Olympus FE-280 8 megapixel Lens won't open.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 18, 2010
How do I stop my Olympus FE-330 displaying the photo I have just taken for a few seconds?
1) you must take out the batteries
2) however this is NOT normal condition.
3) this is a indication a faulty Syscom and circuit associates , see the diagram.
Go to the repair shop for fix it.
God bless you
Sep 22, 2012 | Olympus FE-330 Digital Camera
Hos can i use OLYMPUS fe-330 as a video camera?
Just set the switch to "video icon" to left and start taking videos by pressing the shutter button then press the shutter button again to stop recording the video.
Please rate 4 if this answered your question.
Aug 03, 2011 | Olympus FE-330 Digital Camera
I have an Olympus FE-330 camera. When I try to transfer using the Olympus Master 2 (recently installed) it says 'software unable to locate an Olympus Digital Camera connected to a USB port' I...
Check the LCD screen of the camera. You should get a message when you first plug it in to select the usb type. highlight PC and press ok. The screen should display one moment please then go off. Then the camera should be recognized by the computer.
Jun 15, 2011 | Olympus FE-330 Digital Camera
My Olympus FE-330 camera will not turn on.
Is it still under warranty? If yes, then avail the warranty. If not, go to the nearest service center. I would not recommend a DIY. Fixing it after an accident may cause even more problems.
May 02, 2010 | Olympus FE-330 Digital Camera
My olympus fe-330 has a cracked screen. What is my best and cheapest route for getting it fixed?
http://shop.ebay.com/i.html?_nkw=Olympus+FE-330+screen+&_sacat=0&_dmpt=Batteries_Chargers&_odkw=Olympus+FE-330&_osacat=0&bkBtn=&_trksid=p3286.m270.l1313
Ok this is probably the cheapest way to buy one suitable display ...and if you do it yourself ..it will be the cheapest way to fix it ...It is actually not that hard to change cause it is just a ribbon with a plug in the end ..The issue is to open it right ..and have patience and not to panic ...Just study it ..to see all snap clicks amd screws that may be hidden ...open it ..and replace ..
have a great day and do not forget to rate me ...!
HELP ! XMAS PRESENT 569/1366 NO AC MAINS CONNECTOR PLUG
Went to my local Argos store [not where it was bought], and they replaced the complete [or rather INcomplete] box. Thanks.
Jan 07, 2010 | Olympus FE-330 Digital Camera
Can i use a sd memory card with my olympus fe 330
Jun 07, 2009 | Olympus FE-330 Digital Camera
Olympus FE-330 Blank Viewfinder
BAD CCD problem if u take pics and those are blank and u have bought camera recently kindly run for warranty it is a bad ccd imager problem it will be replaced dont worry
pls rate me FIXYA for help
Apr 03, 2009 | Olympus FE-330 Digital Camera
I purchased an olympus fe-330 8.0 megapixel camera about a month ago and worked ok until about a week ago when it just wont turn on. i have tried to charge the battery but the red light only comes on for...
when the red light is off, it means it is fully charged.
May be you are puting it wrong side in the camera. check the arrow to put in the camera
check with the service centre.
Jul 10, 2008 | Olympus Cameras
Olympus FE 330 not getting ON by the ON button
Email... Olympus-global.com
Good luck, Paul
May 27, 2008 | Olympus FE-230 Digital Camera
Cameras Logo
56 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
