Question about Frigidaire ATF6000ES Front Load Washer
Rubber Gasket I have a new Frigidaire Front Load Washer and there is a build up of mold in the creases. After being on line for approx 20 min I gave up. We purchased the washer 4/07 and had it delivered 7/07 to our new home. I did not extend the warrantee because I was very satisfied with everything. No one told me anything problem that might occure with the rubber gasket. I tried running bleach through the wash cycle, but there is already a hole eaten through the gasket. I just wish someone had told me the problem with this machine and I might have made a different choice. GLTF2950ES.
In the future, leave the door open to dry the washer out between uses
Posted on Oct 28, 2008
I have been struggling with the same issue for a long time. Regular bleach and mold-killing products did not work. But I just tried Clorox "Washing Machine Cleaner" and was amazed. I scraped off the loose mold from the rubber gasket and then painted on the product, which is thicker than bleach. After about 20 min. I scrubbed it down with water and painted a second coat on the tough areas. No more mold. I also ran some through the machine per the instructions for good measure and ran another rinse cycle. I am in no way connected to Clorox, but I am so happy to be rid of this problem. Good luck. <!-- from fixya rte -->
Jul 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Mold around the front gasket
u can use vinegar .. it will help to remove mold easily. u can use for clothes as well and even washer.
Jun 19, 2017 | Frigidaire GLTF2940ES Front Load Washer
I have the same problem, mold and nasty odor. I just spoke with a very nice young lady at Frigidaire. I was patient but forceful. I requested a new gasket and she agreed to send it directly to me so...
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Oct 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
Mold in rubber door gasket
there is a product u can buy to put through a cycle to remove all build up mold etc. go to a parts distributor they carry it
Jun 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Mold build up around ribber gasket . Heavy, black and hard
Front load washers are notorious for developing mold/mildew to build up because they retain a lot of moisture in the round gasket the door closes into. Wash it down with a 50:50 soulution of bleach and water. You may have to use a brush on the "hard" stuff. Occasionally, run a quick load with no clothes and just bleach through a complete cycle in the washer. After a heavy day's washinh, leave the door open a little to help dry it ou.
May 28, 2009 | Washing Machines
Black mold growing on gray rubber boot inside door.
Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
Mold build up around rubber in washer drum. Can
Buy affresh washer cleaner. You can order it over the internet and this should take the mold off and then if you use this regularly like the package explains it will keep the washer from molding. I use this stuff on all the front loaders that come into my shop. This stuff works great.
Feb 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Inside door gasket
Im no expert but i does your manual way to wipe it down? With bleach? I bet removing it could cause a problem since those gaskets are very important and you wouldnt want to put it back in wrong.
Oct 15, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
94 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
