Question about Thexton 383 Power Steering Belt Tightener
Polo power steering
Hi i have a polo 02, and the power steering has disapeared and a light has come on on the display. any ideas?
  • milki Jan 26, 2009
    VW polo 1.4Tdi 2007 model ... power steering stops and light comes on at random times.. the steering is heavy and unusuable... fuse blows in main circuit board... 2007 model..... fully electric powersteering any solutions?
    Champion:
  • 242 Answers
Check your fluid level, could be a bad pump, make sure a belt is connected to it also.
Posted on Oct 24, 2008
How do I stop my car showing ABS, POWER STEERING and BREAKING SYSTEM lights and beeping.?
-First able check all the belts. If any loose. (I mean not tight or good tension).
-If all tensions are good then turn on the car, let it run for 10-15 minutes and check the voltage at the battery. If it's below 13 volts
then the problem is the alternator.
Good Luck
Mai
Apr 24, 2014 | 2006 Volkswagen Polo 1.9
1993 nissan nx coupepower steering
In relation to these problem there are few solved help links,i suggest you to go through the list and click the required link:-----
Power Steering going out? http://schematicsdiagram.blogspot.in/2012/04/power-steering-going-out.html
How to Replace power steering pump on Chevy silverado 2500 HD? http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-pump-on.html
--------------- How to replace Power steering rack and pinion gear on Chevy Silverado 2500 HD? http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-rack-and.html
------------- Power Recirculating Ball Steering Gear removal on Chevy silverado 2500 HD? http://technoanswers.blogspot.in/2012/02/power-recirculating-ball-steering-gear.html
----------- Chevy Silverado 2500 HD steering wheel replacing Procedure? http://technoanswers.blogspot.in/2012/02/chevy-silverado-2500-hd-steering-wheel.html
----------- Steering Wheel Locked? http://schematicsdiagram.blogspot.com/2011/12/steering-wheel-locked.html
How to Remove Power steering Pressure Hose on Dodge Stratus http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-power-steering-pressure.html
How to replace power steering pump on Mitsubishi Diamante?
http://howtobyme.blogspot.com/2012/01/how-to-replace-power-steering-pump-on.html
How to bleed power steering pump on Toyota? http://repairhelpcenter.blogspot.in/2012/02/how-to-bleed-power-steering-pump-on.html
----------How to replace power steering pump on Toyota Land cruiser?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-power-steering-pump-on.html
Steering service light ON GMC Sierra Denali?
http://technoanswers.blogspot.in/2012/02/steering-service-light-on-gmc-sierra.html
Steering service light came on 2004 Pontiac Grand Prix
http://technoanswers.blogspot.in/2012/02/on-one-my-pontiac-grand-prix-relatred.html
Check power steering message on Toyota?
http://schematicsdiagram.blogspot.in/2012/02/check-power-steering-message-on-toyota.html
How to remove power steering pulley on 2002 Ford Taurus? http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-power-steering-pulley-on.html
---------1992 Ford Aerostar Power steering and Alternator belt routing diagram? http://carbeltrouting.blogspot.com/2011/12/1992-ford-aerostar-power-steering-and.html
How to replace Power Steering Pump on Acura Car Models?
Also bleeding:
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-steering-pump-on.html
How to replace Steering Linkage on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-steering-linkage-on.html
How to replace power steering pressure hose on mustang? http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-pressure.html
STEERING SQUEAKS http://alltypesofpartsreplacing.blogspot.com/2012/10/steering-squeaks.html
----------- Steering Column Diagram For 1990 Jeep Wrangler http://schematicsdiagram.blogspot.in/2012/07/steering-column-diagram-for-1990-jeep.html
------------- How to replace Steering Wheel on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-steering-wheel-on-acura.html
How to replace Power Steering Pump on 1999 Acura TL?
http://howtobyme.blogspot.com/2011/11/how-to-replace-power-steering-pump-on.html
These details will help.
Thanks.
Nov 23, 2012 | Cars & Trucks
Hi I would like to know how would I go about adjusting my 1999 polo playa 1.6i clutch cause it is to high can any1 help thanks 4 your advise
'Volkswagen Polo 1.9TDi 74KW, 2006 model sedan. Instrument cluster will reset, all lights come on sometimes with a loud beep sometimes with the horn also. It started first when I turn steering wheel to max either side then the airbag light will come on and I will loose power steering, then when switch off and restart all is fine but all counters are reset on the instrument cluster. Most recent incident when I was driving on highway and slacking off to take an exit then all the lights on dash was lit, lost power steering and loud beeping and I switched off engine and restarted (while freeing at high speed) then all OK again. Seems to happen more frequently but intermittent.' - has been answered - "'I had the same problem after I had my car serviced, the problem with the power steering was that the signal to the power steering pump was set to high and the pump cut out because it was receiving an incorrect signal, the instruments reseting was found that alot of the ground wires was loose, for some reason the abs sensor was also not adjusted correctly which made the abs light come on as well. I took the car to another service centre and they adjusted the abs sensor and the signal to the pump and checked all my wirring - had no problems since - Christiaan from South Africa'"
BMW ACCESSORIES.
May 31, 2012 | 1995 Volkswagen Polo 1.4
Warning licht comes on and steering is stiff vw polo 2005
Hi if the warning light is coming on and steering is stiff, then the car has logged a fault in its ECU either in the steering control ECU or the ABS ECU, these can be read with a diag machine, from there this will give you a better idea of what is causing this problem
hope this helps Chris
Jul 27, 2011 | Volkswagen Polo Cars & Trucks
02 VW Polo 1.2 steering wheel warning lights on
Red this article:
Eventhough the level is right, the fluid might need replacing (every 3~5 years and 50.000-100.000 miles).
You can read how to recognize bad/old fluid here: http://www.hondaclub.com/forum/articles/1492-power-steering-fluid-lifeline-your-steering-system.html
Aug 25, 2009 | 2002 Volkswagen Golf
02 VW Polo 1.2 seat belt warning light stays on .
you may have 2 problems 1 ightion switch and a seat belt pretensioner both faly common problems
Mar 23, 2009 | 2002 Volkswagen Golf
Thexton 383 Power Steering Belt Tightener Logo
2,179 people viewed this question
Top Thexton Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Thexton Hammering Expert? Answer questions, earn points and help others
