Question about Welding Tools
Circuit board burnt up in millermatic 210
How much will it cost to replace main circuit board?
abhishek33
  • 1239 Answers
SOURCE: Dryer won't turn off
hi please rate the last solution atleast as thanks for trying.
Posted on Dec 31, 2008
SOURCE: Amana D530M Dehumidifier won't run
We all appear to be in the same mess --Thanx Haier
This product says its Amana, but rest assured it is an Haier
The problem is most likely with the engineering design of the board. Im not an electrical engineer so be careful litning to me to closely :) There is only a half bridge rectifier on this board and 2 zener diodes that clamp down on the voltage. My guess on yours is the Zeners have been shorted and no longer clamping voltage down to aroun 24 volts for the low side of the board. I spoke with Haier and they have no schematics that state the zener specifications. They also said there was a 6 month backorder on ordering a new board. Oh and by the way if you want to order a new board and wait 6 months for the backorder it would cost you 75.00. All this jsut to repeat the problem again, because of bad design. O well ----- I wish products were not made better, so I wouldnt have to fill guilty about putting this in the landfills.
Posted on Feb 27, 2009
SOURCE: The hand controller circuit board burnt out on my Orion telescope
Call Orion customer service.
http://www.telescope.com/control/main/
Posted on Jul 16, 2009
SOURCE: how hard is it to change out the main circuit
The replacement of a board is no TOO hard, just DRAW a Diagram of ALL connections when you take the "Old" one out. NEVER work on the machine live Duh, also always wait a bit to allow capacitors to discharge, or use a shorting stick, if in a hurry. Anyhow, make sure you keep all fixtures together note down all connections and label them with little stickers, With any other information on the stickers as need be. I always do this as one never remembers whats what after a bit, anyway. Just be methodical, and you will prevail.
Posted on Feb 25, 2010
  • 4 Answers
SOURCE: schumacher 75/12/2 model 1275 ineed a circuit board
http://www.centurytool.net/SE_1275A_Schumacher_Battery_Charger_Parts_List_s/30818.htm
Posted on Mar 08, 2010
My Vizio 47inch TV made a loud pop and shut off. Pulled back off and inspected for anything bad. Located a tiny resistor looked like it was burnt or something can it be fixed?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 01, 2018 | Vizio Televison & Video
Vizio tv XVT3D554SV made a pop noise then went dead. Wouldn't turn back on. We took back off but didn't see any part that was burnt or black. Any suggestions would be appreciated
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. ..
Nov 20, 2016 | Vizio Televison & Video
My emerson lcd tv won't turn on but the red display light stays on. There is a burnt spot on the power supply board. The # beside it is R645
Oct 17, 2016 | Emerson Televison & Video
Replaced board that has hdmi ports and the tv still has high power coming out of cable in put port and has burned out hdmi inport
Fault to the main power supply regulator section. {AC leak} Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 15, 2015 | Televison & Video
Why are picture and sound gone?
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 04, 2015 | Samsung PN59D8000FFXZA - PN59D8000 59 3D...
No red light no power had bad storm fuse is good nothing looks burnt which board should I replace first ?
Sounds like fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jul 03, 2015 | Televison & Video
Where can i buy a circuit board for my lg refrigerator model lfc23760st
No need to buy a new main control board !
The problem is mainly from the fuse that soldered in the main control board, go to buy a "125V 15A or 250V 15A" fuse ($5.00 a pack of 5 pcs), cut the burnt fuse from the board, re-soldered the new fuse into the board, the refrigerator work again. you save $80 for the labour cost of the technician and $180 for the cost of a new main board.
Jul 18, 2012 | LG LFC23760ST Side by Side Bottom Freezer...
Does it have a fuse we got hit by lighting and now the Pc wont power up
To fix the problem, you need to disassemble the power supply, replace the burnt out fuse, & also check the bridge rectifier section for burnt out rectifying diodes (these usually get burnt out if the high current gets the chance to leak past the fuse, which could sometimes happen). If you find burnt out rectifying diodes, you will need to replace them as well, as they could burn out the fuse again when you try to use the power supply while they are still there.
Dec 20, 2009 | Codegen : 350W ATX Power Supply With 12cm...
Open circuit??
try blowing out the welder
Mar 19, 2009 | Miller Welding Tools
Brother mfc 210 c
defective main circuit board. Must be replaced! (Cost more than a new mfc at sale!)
Jan 07, 2008 | Brother MFC 210C All-In-One InkJet Printer
Welding Tools Logo
272 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
