Question about Panasonic CQ-DP202
UNIT WILL NOT PLAY/NO SOUND
I bought a boat w/player already installed. The piece worked great before I paid for boat. Trailered the boat home, wanted to show my father how the
radio sounded/cd sounded and nothing could be heard. Screen comes on
sometime it has "adj" on other times it shows the local radio station....no
sound? What to do now? Checked connections on back...everything is
attached.
julie@yankeeford.com
4 Suggested Answers
SOURCE: Panasonic CQ-DP383U CD Player
buy a new one
Posted on May 28, 2007
SOURCE: NO Sound At All
Checa con una bocina externa las salidas de audio del aparato,si funciona las bocinas del carro son amplificadas.Y si no funciona el amplificador de audio del estereo esta quemado.
Posted on Mar 29, 2008
Murphybanton
  • 2004 Answers
SOURCE: panasonic CQ-C7301U reads cds but no sound
Ensure that the rf cables are well fitted. You may swap if you are not sure.
rate this
Posted on Apr 05, 2009
Unit will not read the correct depth. Have used it a hand full of times and worked perfectly at first.
Hi Jeremy
Is the boat in the water all the time or trailered each time you use it?
If the latter is the case, try a little vegetable oil on the transducer wiped on with a piece of paper towel or a rag. Sometimes the transducer needs to be "wetted" to ensure a good contact with the water.
Give that a shot and I hope it helps you out.
(EDIT)
If the transducer is an in-hull installation as opposed to a thru-hull, there may not be enough light mineral oil in the dam box to ensure good conductivity.
-Steve
Jun 02, 2015 | Boating
Model-m 255 clarion installed in a pontoon boat. RADIO WAS WORKING JUST FINE, THEN I INSTALLED A (NEW) BATTERY FOR MY BOAT, HOOKED EVERTHING BACK THE SAME WAY. NOW, I HAVE POWER BUT (NO) SOUND...
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
MS Office Home/Student 2007 Product Key
Check if you have paid for a full version or trial version of the software. Sometimes, with a new laptop, you only get the trial version, which means you have to buy the software if you want to continue using the product.
Check with the company that sold you the laptop.
Oct 14, 2009 | Computers & Internet
Transducer on LCX 18C works intermittently
Is your boat trailered or docked? I would try cleaning off the transducer and readjusting it.
Jan 04, 2018 | Boating
6 disc cd player
try calling bose tech support for this..
Aug 06, 2009 | Bose 3 2 1 GSX System
Why are Aluminum Fishing Boats the Best Fishing Boats?
A timber boat is high maintenance. Trust me, I've had quite a few. You're always sanding timber, varnishing timber, repairing timber and lots more. Now if you're happy to be doing that then that's great, but recognize that's the price you pay for a great looking timber fishing boat. And a timber boat is often heavy, and will not last well, particularly if you aren't as diligent with your maintenance as you could be. And they puncture easily when you hit something, as I did last week. But if you're not an enthusiast for working on boats then timber isn't your best choice. What you want in a fishing boat is this. It needs to be tough. It needs to be low maintenance. It needs to be puncture resistant. It needs to last forever without spending hours working on it. It needs to be easily repairable. And it needs to be cost effective. For me the best choice fishing boat is an aluminum fishing boat. Aluminum has properties which make it the perfect material for building fishing boats. It is very light and strong for it's weight, and can be easily welded, so is ideal for both building and repairing. It is extremely long lasting, and is very resistant to puncture. Now of course that doesn't mean it can't be damaged, as it can. But you need to hit it pretty hard to do some serious damage. And if you did that to a timber or fiberglass boat it will be very seriously damaged. And an aluminum boat may just dent, rather than fracture, so you can head right back home with nothing more to show than a dent, instead of possibly be the subject of a rescue from a sinking boat. And it lasts forever if treated right. If you get a great aluminum fishing boat and treat it well you may well find yourself leaving it to your kids. Because aluminum boats are light for their strength they often need a smaller engine, and the engine is probably the highest cost item. A smaller engine costs less, and uses less fuel. And with a smaller engine they are also lighter and easier to handle. And they require little maintenance. Make sure you hose your boat down after a day out, especially in saltwater, and if you drop a lead sinker make sure you pick it up, as it's not great to leave any other metal in contact with aluminum, otherwise you don't need to do too much maintenance at all. More fishing time. And because aluminum boats last so well they also retain their resale value well. I bought a used aluminum fishing boat 2 years ago and it is currently worth a little more than I paid for it. So there's plenty of good reasons to buy an aluminum fishing boat. Unfortunately they aren't cheap if you want to buy a new boat, but for the same reasons I've mentioned above, it's way better to buy a used aluminum boat, as a used boat is usually much cheaper than a new one, and retains it value well. I would never buy a new aluminum boat. So grab yourself a great used aluminum fishing boat and get fishing this summer, it's the best way to get on the water.
Dec 01, 2008 | Sea and Sea Sea Eagle Inflatable Fishing...
Dvds wont play
Check out the link I have posted below.
http://www.homemovie.com/compatibility.htm
according to the list, your in the 5% area of dvd players that won't read burned home made disks-DVD's
Sorry Pal your in the same boat as myself.
I have a Toshiba SD-2107 --- We're both aout of Luck :(
Looks like it's time to invest in a new DVD player.
Aug 05, 2008 | Toshiba SD-2109 DVD Player
DEH-P3500
pioneer keys. Long thin with a tiny barb at the end. You need keys, and remove the radio trim piece. Take to local shop and they can do it in 2 seconds.
Feb 17, 2008 | Pioneer DEH-P3500 CD Player
Quickbooks 2005 Error 1603
Explore the QuickBooks 2005 CD, go into the QuickBooks folder and double click quickbooks.msi - this will install QuickBooks without checking for the old/outdated Flash Player 7.
Sep 30, 2007 | Intuit QuickBooks: Pro 2005 for PC
Panasonic CQ-DP202 Logo
46 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
