Question about Canon Legria FS306 PAL Flash Memory Camcorder
My camcorder won't charge or turn on
94 softail custom won't start.
you probably smoked something boosting it with 200 amps. start looking for burnt wiring
Feb 03, 2018 | Motorcycles
Blackberry playbook red light flashes but it won 't turn on
this happened to me, it needs charging make sure the lead has the blackberry symbol facing up....
May 12, 2012 | RIM Blackberry Playbook 7Inch Tablet...
How to fix a Canovision 8 VM-E1 camcorder?
replace the battery by the new one.
Mar 11, 2012 | Video Cameras
Canon Elura 90 camcorder
If the battery do not have any current after removing it from the charger, you can use 6 volt adaptor bust the battery before charging
Nov 03, 2011 | Video Cameras
My Sony DCR-TRV240 camcorder won't eject the tape. The power and all camera features work, but it won't eject a tape.
I'm sorry that the Camcorder is not ejecting tape. Please follow the troubleshooting steps provided below and check the operation:
1. Please make sure that the battery is fully charged. 2. Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder. 2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds. 3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder. 2. Disconnect AC power adapter. 3. Remove the battery pack. 4. Move the POWER switch to the CAMERA position for 15 seconds. 5. Move the POWER switch to the OFF position. 6. Reconnect the AC power adapter or reinsert the battery pack. 7. Turn on the camcorder.
If the issue persists after following all the steps service will be required. You can find repair information and initiate service at:
http://fixya.com/repair
Thank you for using Fixya. Please let me know if you require any clarifications.
Sep 01, 2011 | Cameras
It will no longer charge or turn on
You might want to check the battery,if the battery is completely dead it won't charge or turn on
Jul 04, 2011 | Canon DC20 DVD Camcorder
Reset button ?
Sometimes there is a reset button and sometimes you have to reset it through a menu. Of course, if it won't turn on, then you can't get to the menus.
May I ask, what is you Toshiba camcorder's model #?
Jul 31, 2010 | Toshiba Video Cameras
Canon Legria FS306 PAL Flash Memory Camcorder Logo
105 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
