Question about Conair HC500 Hair Trimmer
Conair HC500S, reassembly instructions
I removed the blade to clean the hair behind the blades, and the upper blade popped out, and now I am unable to reinstall the upper blade so that it does not move side to side and it is no longer able to be adjusted once the unit is reassembled. it is much noisier as well. The instructions that came with the unit are only to replace the blade, not reassemble the top blade that pops out during the process
3 Suggested Answers
SOURCE: conair hc318d reassembly
you can buy another blade set for that model. Call 1-800-3-CONAIR
Posted on May 26, 2008
i have hc318d clipper it been use two time and havent use it in a year so was going to use it last nite and the small blade fell out. i try to put it back in and it want hold keep falling out
Posted on Aug 02, 2009
Replacement blades for conair hair clippers hc114wv
I have a Conair HC114WVR and I took the blades off to clean the hair out. It's not that old, but when I put the blades back on they vibrate to a point of grinding. I can't figure out what I need to do to get them back on straight.
Jan 25, 2014 | Health & Beauty
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Mar 11, 2011 | Andis AGC2 Hair Trimmer
The trimmer is not cutting the way it should, the bottom blade seems out of place and I cannot put it back in place
Conair trimmers are only good for about a year and they are hard to put back once you have messed with them. does your blade pop off or does it have two phillips screws holding it in? If you take the blade off completely you should see two arms that are in there, you have to place the blades back on correctly and hold them together while putting the screws back in. be very careful not to tighten the screws too much. Oil your blades with 3-1 oil and then turn them on. adjust the trimmer and see if everything is level, if it is try cutting withem and see what happens. If the motor sounds good but the blades are pulling your hair rather then cutting it then you need to replace your trimmers because your blades are daul.
Oct 05, 2010 | Conair HC100RCS Hair Trimmer
Need replacement blades for hair trimmer
Hi. Order them from Conair: customer service representatives will be happy to help you. Please call 1-800-326-6247 for a Conair appliance.
Mar 23, 2010 | Conair HC117 Hair Trimmer
Conair GMT200 Assembly
Hey dude i had the same problem n_n. Attach the screws in place and try to screw one by one gently. Soon this pressure will keep the spring tighten (instead your finger's pressure) then it will be easier to reassemble the component. I know you'll fix it n_n.
May 20, 2009 | Conair GMT200TD
digram on how to replace my blade in my hair trimmer conair hc3180v
Feb 01, 2009 | Conair HCT-426 Hair Trimmer
Cleaning Conair Simple Cut haircutter
Go to a Sally Beauty supply and purchase a can of the blade wash. It is relativly inexpensive. You dip your blades into ths special wash and it cleans the blades and keep them sharp and is safe. DO NOT take the heads apart, Let the pros do that but blade cleaner you immerse them in and trust me it is what we pros use.
Jan 20, 2009 | Conair HC91CS 10 Pc. Haircut Kit Hair...
Conair hc318d reassembly
Dec 17, 2007 | Conair HC100RCS Hair Trimmer
Health & Beauty Logo
215 people viewed this question
Top Conair Health & Beauty Experts
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
