Question about HP Pavilion a6660t Desktop PC
HP Pavilion a6660t won't boot. Inital HP bios screen displayed. No response to keyboard, harddrive or bootable CD.
HP has replaced this system board 4 times in the past 2 years. Now it's out of warranty, and it's a little different scenario. Upon power on, the initial HP bios screen is displayed. There is no response to the keyboard even thought Num Lock led is illuminated. The hard drive is initially accessed during power on, as is the CD/DVD and the fan is running, Nothing more occurs.
  • Gary Boyer Feb 19, 2012
    Given this is the 4th bad system board in a little over 2 years, I think it's time to upgrade to something else.
    How much do I need to worry about the physical locations of items on a new system board, e.g. not the same exact replacement model.
    Thanks!
    Thanks!
  • 131 Answers
Check your hardwares.either memory has mulfunctioned
Posted on Feb 12, 2012
  • Gary Boyer Feb 17, 2012
    I've removed all the memory sims. Post has one short beep, followed by one long beep. Added each memory sim individually, received the same result. only the bios screen is displayed.
    Added all 4 and still the same.
    Disconnected both hard drives (1 for OS, 1 for data), same.
    Booted with the system recovery disk, and was presented a message that no hard dis was found. Reconnected primary hard disk and booted from the system recovery disk, same - only bios screen. reconnected second hard disk with primary hard disk disconnected and booted from the system recovery disk - same, the bios screen is only displayed.
    Bad system board?
  • robert Feb 18, 2012
    afraid so.thought about changing the mainboard?
How do I get past the blue screen? Computer has been stuck on this for weeks. It has been rebooted, restarted, unplugged, still doesn't get past blue screen.
First unplug your machine and plug it back in and turn it on while its booting up you should see a message to press the F2 key to enter the BIOS. press that key, you will only have a couple of seconds to press it. Look for an option called First Boot Device, Boot Sequence, or something similar; press the arrow keys on your keyboard to select this field and then press Enter (You may have to select Advanced Options or another submenu to find it.) In the resulting screen, select CDROM/DVD and then press the Esc key until you return to the main BIOS screen. Follow the onscreen instructions to save your new settings and exit BIOS setup. Insert the installation disc (you need an installation disc of the operating system, if you dont have one you can find one on amazon, but if you needed to buy one you should consider upgrading to windows 7(more like vista) or Windows 8 (not really like vista)) once the disc is inserted restart the computer and follow the on-screen instructions
Nov 07, 2014 | HP Pavilion Computers & Internet
Hp pavilion dv9000 takes a long time to get past the bios screen. It won't boot of dvd either??
Check BIOS boot options and assign local hard drive as first for faster boot. This is also where you set CD\DVD as first to boot from disc. Look for F Key press on start up. It will be shown on screen. These can vary.
Many HP machines also have a boot menu option during boot. Again an F key and may vary.
Sep 22, 2012 | HP Pavilion dv9000z Notebook
I have a acer (aspire) notebook. And a couple of months ago i was playing on it and it had a blue screen. I got scared and didn't go on it for like a week. A week later i went back on it said acer on...
No bootable device means your computer is trying to boot from a storage device and it's unable to find the operating system. Check the your system BIOS to see if your computer is still detecting your harddrive. To do this:
1. Reboot your comp. While it's coming up, keep hitting "Delete". This will bring up the Set Up.
2. Using the navigation keys of your keyboard, navigate to the tab that says "Boot Preferences" and hit enter.
3. Switch the boot device to your harddrive and save your settings then reboot.
4. If your harddrive is not being detected, it's either loose or has gone bad. In which case it would be best to have a tech take a look at your notebook.
May 22, 2011 | Computers & Internet
None of the keys work on hp logo screen F10, f11. f9. esc system won't boot from hard drive or cd
are you using a usb keyboard? A lot of systems require a ps/2 (purple round connector) keyboard to access the bios settings and anything on the startup screen unless you have set usb on boot in the bios settings. I would try connecting a ps/2 keyboard and see if it helps.
May 06, 2011 | HEWLETT-PACKARD Pavilion Desktop with AMD...
My hp zd8000 is not rebooting and been told i need a new motherboard
Before you start thinking about your motherboard, let's rule out your harddrive.
Go online and Google "emergency boot cd" and choose a product that works for you. Many have "demos" you can use with limited capability, but that's fine. You will need to take the .iso file and burn a CD with it. This will create a bootable CD.
You will need to setup the computer to boot from a CD by going into BIOS and setting the boot sequence to CD first. If you don't know how to do that, here's a good article...
http://www.cites.illinois.edu/security/antivirus/bios.html
Using your newly created CD, put it into CD drive and start boot up. If your computer boots normally, you have a harddrive tht has failed. If not, you may have a motherboard issue, or possibly a different hardware issue that may require professional assistance.
Oct 22, 2009 | HP Pavilion zd8000 Notebook
Blank Screen - hard drives work and keyboard lights up
Try holding F11 while booting, sometimes this triggers the recovery partition.
Sep 21, 2009 | Compaq Laptop Keyboard for HP Pavilion...
HP pavilion dv2025nr do not boot
Hi
please press DEL to set the bios settings then choose the Bios set up! then click the bootable device SCSI.
Thanks!
Jun 07, 2009 | HP Pavilion dv2000t Notebook
What cable?
This message is displayed the motherboard attempts to preform a PXE boot. In otherwords, it is attempting to boot from the network.
This message is displayed under the following conditions:
1) No boot device (i.e. harddrive, cdrom) was detected. (Remember, even with a fresh harddrive you will get this message because the harddrive does not have an operating system tellling the BIOS it is bootable.)
2) The BIOS is configured to boot from LAN (PXE) before the hard disk drives.
To fix:
1) Power down your computer and check all power and data cables (ALSO JUMPER SETTINGS!) leading to the HDD, CD-ROMS, and other drives.
2) Hold down the key to access your BIOS while turning the computer on from a powerless state.
3) Change the boot order putting LAN (PXE) boot last: I would do CD, HDD, LAN.
4) Exit and save the changes.
TIP: HOLDING F12 WHILE WHILE TURING YOUR COMPUTER ON FROM A POWERLESS STATE WILL BRING UP A BOOT MENU AND YOU CAN CHOOSE TO BOOT FROM CD, HDD, ETC.
Sep 19, 2008 | Intel Computers & Internet
HP Pavilion a6660t Desktop PC   Logo
200 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
