Question about Sewing Machines
Singer sewing machine 1802 dog feeding does'nt work, material doesn't move; dog feeding not raising
  • 192 Answers
SOURCE: feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
Posted on Nov 01, 2008
bargainbox
  • 1388 Answers
SOURCE: feed dogs not feeding the material
Is this a second hand machine ?
Is the stitch length selector set to > 1
Remove the needleplate and clean between teeth of feeddogs if it has been a while since this has been done, old lint will impede feeding.
Presser foot tension for general work needs to be set at 3, or the chromed button pushed down to the grooved line, depending on machine.
If new, call the dealer where you bought it and speak to them.
Posted on Nov 24, 2008
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
Posted on Mar 28, 2009
SOURCE: feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Posted on May 01, 2009
Zenqi
  • 208 Answers
SOURCE: started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Posted on Nov 14, 2009
My Singer Quantum 9960 doesn't seem to be moving the material when I am sewing. It sews in the same spot and then the material gets stuck.
Am guessing you've already verified the feed dogs are in the raised position. The other thing to check is the presser foot pressure. If you are sewing lighter weight fabric, you may need to increase the pressure to make more contact with the feed dogs, or lighten the pressure when sewing thick fabric. Something else that may help is using a roller, teflon, or walking foot.
On the other hand, if the feed dogs are not moving like they should even if you have the stitch length higher, your machine may need service. Be sure you've cleaned the feed dogs of any accumulation of lint, dirt, debris. Of course, if you have used the machine a lot, the feed dog points do wear so they may not be gripping like new.
Jan 16, 2017 | Singer Sewing Machines
Feed dog on singer m756 won't pop up
If this is a combo embroidery and sewing machine, the feed dogs have a switch to raise or lower them. If this is just a sewing machine, your feed dog linkage may be broken.
Jul 15, 2014 | Singer Sewing Machines
Singer 758 model and the material is not feeding through the machine. Needle is only going up and down in one spot.
here is a link for a free manual, check to see if the feed dog lever is up in the sewing position, if the feed dog lever is down then try to raise it up. if it will not raise then the machine needs to be check to see what's wrong with the feed dog.
http://www.singerco.com/uploads/download/6dc4cd61b0c61a5fc13e60785f01d29199328059.pdf
Nov 18, 2013 | Singer Sewing Machines
Singer sewing machine 6233
have you checked your feed dogs are moving? have you dropped the feed dogs by accident? the feed dogs might need a drop of oil on the moving parts inside your machine.
Apr 23, 2013 | Singer Sewing Machines
I have a singer 543 the feed dogs won't move.
I suggest getting out your manual and looking up lower and raising the feed dogs. When the feed dogs are lowered they don't move. You could have lowered them without realising it.
Mar 18, 2013 | Sewing Machines
Can't raise the feed dog on Quantum XL 1000
If I remember correctly you have to raise the feed dog then turn the fly wheel 1 revolution to lock them in place
Feb 07, 2013 | Singer Quantum XL-1000 Computerized Sewing...
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
MATERIAL WONT FEED THROUGH
check in the needle plate area to see if the feed dogs are up,,you be able to see them & touch them with your fingers.
if you can see & feel them, then check the manual for where the feed dog lever is & move it to the opposite position, & then if that doesn't make the machine sew better then it will have to be fixed at a repair shop
Sep 23, 2011 | Singer 3116 Simple
I have a Singer Stylist 513 & I cannot get the feed dogs raised.
The model 513 Singer has two gears which operate the feeding mechanism. If one of these gears is broken, the machine will run except the feed dogs will not move. This is a very common problem with this model.
Aug 03, 2010 | Singer Sewing Machines
Sewing Machines Logo
60 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
