Question about Zebra Stripe S600 Thermal Label Printer
Zebra S600 - Printer pauses after each printed numbered label, if I don't number them it works fine?
    Problem Solver:
  • 15 Answers
It sounds like your labelling software is re-sending the entire print job each time. Do some research with your software and see if you can change the defaults so that everything BUT the serial number is stored inside the printer, and only the new serial number is sent.
It's difficult to be more specific because every software package is different...
Posted on Feb 13, 2012
SOURCE: Pausing between labels
I have found that using the designer driver causes this problem. You may need to go back to the originma driver for that printer if this is the case for you.
Posted on Jun 05, 2008
JackHeath
  • 1049 Answers
SOURCE: Zebra S600 printer
  1. Try just storing your labels in a cool dry place before using them. Peeling labels are usually a sign the glue is poor or weak.
  2. When tearing you labels off, feed them out before tearing them off, then hit the auto-align. See if that helps it.
  3. Try pushing a normal playing card under the metal cutter that tears the labels and pull it up and through the front to bend the blade slightly outward. This will hopefully allow the labels to pass underneath.
Posted on Jul 30, 2008
SOURCE: Zebra Strip prints blank labels
Please download a new driver from www.zebra.com (don't use your old windows driver) and then this will fix the problem.
Posted on Sep 17, 2008
  • 10 Answers
SOURCE: Zebra S600, Recieves data, but does not print
Go into the printer driver and select print a test page, does it print out?
If so then try printing from your label software, it should work, if not then it is your software that is at fault.
If the test page does not print out then check all the settings in the print driver, so they are the same as the physical label.
If non of this helps then go to www.lancerlabels.co.uk and do a live chat to Michael.
Posted on Feb 17, 2009
bartech9
  • 155 Answers
SOURCE: Zebra Z4m+ won't print from Bartender 9.01
BarTender uses its own drivers for each model of printer you must install the correct driver, because there are differences in some commands a printer to another.
Posted on Mar 10, 2009
Hey Jack, we currently have 3 Zebra s600's, 2 in use and 1 spare. I've recently added some zp550 printers on the 2 computers that have the s600's and screwed up the drivers for the s600s. I...
1. Reset the printer - to return the printer configuration to factory default values,pressFEED and PAUSE at the same time while turning the power On (l).
2. Download this Maintenance Manual for Zebra S600 and follow the troubleshooting steps from page # 66.(table 3-2) Printer stops, pause and paper/ribbon LEDs both on / Printer stops, pause LED on and paper/ribbon LED flashing.
3.Uninstall / Re-install the zebra printer driver .Use this revouninstaller to remove the driverClick here to download the driver for Zebra S600 .
Oct 14, 2011 | Zebra Stripe S600 Thermal Label Printer
Dear Sir, Madam, We recently installed our Zebra S600 labelprinter together with the Zebra Designer software. But the labelprinter doesn't print out our labels. We've searched the internet and...
It sounds as though it is printing test labels. Switch of and on again to reset.
If no change then try factory reset.
If it is ever necessary to return the printer configuration to factory default values, press the FEED
key and PAUSE Key at the same time while turning the power on. The default values will remain
active until the printer power is turned off. To save the default values in memory, press the MODE
key four times. The Darken, Position, and Calibrate LEDs will cycle on and then off indicating the
values have been saved.
If this does not work then you have a fualty logic board which write off the printer
Jul 06, 2011 | Zebra Stripe S600 Thermal Label Printer
My Zebra s600 - the ink takeup reel is not working.. works a little when first powering on, but the ink roll then stops moving.. When I print a label, the label comes out, but the ink roll does not...
turn the printer off, press FEED, PAUSE and CANCEL at the same time, still pressing, turn the printer on, wait untill the ligths coming on, and then relese the bottuns, it gona print the sensor profile, then press the last button 4 times untill the 3 ligtns flases, it mins that the printer save the data, then turn off and on again.
Oct 13, 2010 | Zebra Stripe S600 Thermal Label Printer
Stripe S600 Thermal Label Printer: how to load zebra stripe printer labels...
CLICK HERE to download the full user manual from Zebra. If the link doesn't work, go to Zebra.com, click Resource Library at the top of the screen, then click MANUAL. Choose your model number then follow the prompts.
May 18, 2010 | Zebra Stripe S600 Thermal Label Printer
What is the maximum number of labels that a zebra S600 can print in one Job
Best I could find in the manual was a maximum print length of 38 inches. It doesn't stipulate how many per job.
Mar 08, 2010 | Zebra Stripe S600 Thermal Label Printer
Zebra S500 no print
You can find the manual in www.zebra.com, and try reset, pressing FEED and PAUSE keys and turn on printer, release keys until move labels.
Mar 12, 2009 | Zebra Stripe S600 Thermal Label Printer
Speed of printing barcodes
Generally the ZM 400 can cope with printing at the lower speeds when printing barcoedes that are the same. You may get pauses if the barcodes are sequential numbers or are all different, then the data to be transfered to the printer cannot cannot keep up with the printer and pauses while it gets more data. We have found that if you can select in your labelling software to print the barcode as a graphic, then it speed up quite a lot. It is a matter of matching your print speed and quality to match your expectations, sometimes you will just have to put up with the pauses.
Feb 02, 2009 | Zebra Stripe S600 Thermal Label Printer
Not printing
this problem will address on label and ribbon issue. you must establish your printer set-up first, meaning see to it that the label and ribbon was correctly loaded, if still problem occur try using manual calibration you can see how to do at the manuals you have..
Jul 29, 2008 | Zebra Stripe S600 Thermal Label Printer
try to reset the printer to factory defult, chek if the driver is the correct driver frome the printer, if not go to the zebra website and download.
Mar 26, 2008 | Zebra Stripe S600 Thermal Label Printer
Reg. zebra S600 lable
I had this happen when I changed from one label to a different size label. It needs to be calibrated. There are several types of calibration to do to the S600. Here is the solution that worked for me.
  1. Check the position of the laser Media Sensor (figure 13). It may need to be moved to match the type of label that will be printed.
For CARD labels, the media sensor needs to be set at the edge of the card so it can “see through” the notch that is cut on the edge where the perforation is.
    1. For STICKY labels, it can “see through” the backing which shows between each sticky label, so the Media Sensor could be set anywhere for it to work, but will probably be set towards the middle.
Set to Factory Defaults. This is so that all of the following steps will work. I do not need to change the steps based on the type of mode that printer is set up in because it will erase all that by setting it to the factory default. (See figure 14 for buttons)
    1. Turn off the printer.
    2. Hold the FEED and PAUSE buttons down as the printer power is turned on.
    3. Press MODE button four times.
    4. When the defaults are saved to the printer, the CALIBRATE, DARKER, and POSITION lights will all flash.
Test to see if the calibration is set correctly for the label. If not, proceed to the following steps.
  1. Do a Manual Calibration.
    1. Hold the PAUSE, FEED, and CANCEL buttons down as the printer power is turned on, keeping the buttons depressed.
    2. This will run through several labels and do some printing.
    3. Release all three buttons after the CALIBRATION light comes on and then goes back off.
Put the printer into Auto-Calibration Mode.
    2. Hold PAUSE, CANCEL, and MODE down as the printer power is turned on.
    3. Release the buttons after printer is powered on.
Dec 14, 2007 | Zebra Stripe S600 Thermal Label Printer
Zebra Stripe S600 Thermal Label Printer Logo
380 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
