HP Designjet T1200 Large Format  Color Inkjet  44  549 ft h Color  2400 x 1200  USB   Plotter Printer Logo
A
Anonymous Posted on Feb 10, 2012
Hp t1200 problem printing colour cyan is purple
5 Related Answers
Anonymous
  • 54 Answers
  • Posted on Mar 30, 2009
SOURCE: HP c3180 color printing problems
I would definitely start by printing a self-test page. With your model press and hold the Cancel button and then press the Start Color Copy button and then release both buttons. When this page comes out you should be able to identify the 4 different color sections...black, cyan, magenta and yellow. If any of these seperate areas are choppy or non-existant, you need to replace your cartridge. Here is a link that will show you examples of what you should/shouldn't see on the self-test report.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00661556&lc=en&dlc=en&cc=us&product=1146331&rule=25470&lang=en
Anonymous
  • Posted on May 03, 2009
SOURCE: hp pro b8350 will not print colours seen in pictures
discovered print cartridge was faulty. no yellow was coming through.New cartridge solved problem
Alun Cox
  • 2679 Answers
  • Posted on Sep 07, 2009
SOURCE: Just refilled the ink cartridges on my HP
If you do a lot of printing you may wish to look at an option such as this
http://cgi.ebay.com/Continuous-Ink-supply-system-Hp-74-75-CB335WN-CB337WN_W0QQitemZ370247388012QQcmdZViewItemQQimsxZ20090819?IMSfp=TL090819164007r16027
You can't get the in in the wrong section of the cart (which I suspect has happened).
Please note the link is for information only and I neither know nor have used the seller listed. A google search may well provided a list of sellers for you to choose from.
I have used a continuous ink supply on my Epson (have you noticed they appear less on here for problems?) for 3 1/2 years now and my printing costs are minimal compred to useing either after market refills or refilling myself.
Anonymous
  • 166 Answers
  • Posted on Sep 16, 2009
SOURCE: hp 110 ( cb304A )
if you have refilled the cartridge, then it shows that cartridges are not refilled in correct order.
change the cartridge
Anonymous
  • Posted on Jan 04, 2010
SOURCE: my hp deskjet 1280 will not print yellow
Hello, this is Harry from www.BusinessSpread.co.uk.
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
Regards,
Businessspread.co.uk
Printer wont print the color brown
Try cleaning nozzle with dry paper towel, cartridge should leave 3 streaks: Yellow, Cyan, Magenta.
If colours on paper seams to be tinted or mixed the cartridge needs to be reclamated, there is no other solution.
If there is an lack of one or more colours try to wipe nozzle with wetted paper towel in window cleaner. After few wipes, 3 colours sholud apper
Horizontal lines. Xerox 6505DN
clean the print heads and align them
My out of warranty l7680 will not print or photocopy in colour. Printhead status says Refilled supply Detected in printhead Black No/Yellow Yes Magenta Yes/Cyan Yes Detected in Printer Black No/Yellow Yes...
The error states that you are using non-HP cartridges for all colours. If black prints fine then you should replace the colour cartridges with genuine HP colour carts. You should be able to get a refund on the refills since they clearly do not work as intended.
Hi there, need your kind help. My Hp laserjet 5550 has a missing colour problem. Cyan is missing in the print out, giving rise to to blue and green colours being absent in print-outs. Scanner is confirmed...
Cyan cartridge is OK, means that the display shows the level of toner in the cartridge, right? Then chip it is ok.
Try another cyan toner, the printer may be that it has broken the opening flap of the laser. Or check if the laser's flap cyan is blocked.
2helpful
Print colour is off
Sounds like you have cyan and magenta ink but no yellow. (You need yellow to get yellows, greens, reds and orange shades.) First try running the printer utility to clean your ink jets, then run a test print. If this does not work then simply replace the yellow ink cartridge.
Not printing cyan
cyan colour in Cartridge may be thick/ ctrdg faulty
7helpful
2answers
My hp deskjet 1280 will not print yellow
Regards,
Printing issue
The Text print and photographs that are printed are missing are coming with green colour.
2helpful
My printer will only print in blues pinks and purple and black and white
ur printer prints in blues pinks n purple: its very simple :there r three prime colours in ur colour cartridge that forms all the other colour variation they are cyan, magenta n yellow. ur yellow colour in ur cartridge is either dried or empty thats the reason its not printing the colour variations which requires yellow. the solution is to either get ur colour cartridge refilled or replace ur colour cartridge. rate this solution as fixya n encourage us to help u solve ur problems in future too.thanks 4 using fixya.
k24674
Grand Canyon Tech
Grand Canyon Tech
