.......ringer doesn't work only the vibrator......also it needs to be on high and vibe so the vibrator work..if i put it on vibrator it don't even work.......thanks...
-   Iv got a Samsung E330, have had it about 4yrs. A few days ago it went silent - it wont make any noise when a call or text comes in, it wont make noise when im in the ringtone settings menu. It will make keytone noises, & it will play 'voice' files (but sadly the voice files are in wrong format for me to use as tones..).-   Hobb23
Sep 09, 2008
-   The phone would ring as it should up until a week ago. It no longer rings when a call comes in; I click on to "settings," try all the choices available including increasing and lowering the volume, but there is no change. As a last resort I selected "vibrate" so as to have at least some reminder when a call comes in. That works when a call comes, but please tell me how to get it off mute. The phone is a Samsung from AT&T-   1700wash
Jan 14, 2008
-   my motorola pebl doesnt ring when i receve calls or text messages and it doesnt sound when i turn to speaker mode. it doesnt play ringtones when i choose ring styles in the settings menu and it only vibrates to calls and text messages. i already tried turning off the phone, removing the battery... but there's still no sound even if settings are in loud and volume is at max. please help...-   cay78
Dec 13, 2007
-   Siemens S55 - Audio works, I can hear phone sounds and songs etc. Key tones work as well - But phone does not ring when there is an incoming call? I have reset all settings changed melodies, changed volume?-   Guest
Dec 06, 2007
-   Hi all, I have the same problem with my Nokia 7610, bought only months back, no sound at all. Even mobile tones does not sound, only vibration works. This has anything to do with the software? Is there a soution? Can anyone help? Please......-   Venu1234
first check the ring tones in the celu, sound? if not, you got a "piezo" problem thats the speaker that sound in your celu and nothing you can do, if yes, then you got a seting problem, refer to the manual of the celu or go to the celu store, they will help you for free, in case of a damage one in the store haves jonks to repair it for cheaps....good luck
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Oct 12, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Had the same problem with my Orange EnV - I could only hear through headphones. I had recently used my headphones so I worked the headphone plug in and out a few times while playing an MP3 and the sound returned. I believe the contacts in the headphone jack were stuck in headhpone mode.
mi w380i an the load speaker doesnt work at all onley the ear speaker works so i carnt hear it wen...
(More)
mi w380i an the load speaker doesnt work at all onley the ear speaker works so i carnt hear it wen it rings
