Question about RTO Spur Sprocket For Stihl 017, 021 Chainsaws
Trigger does not work on my stihl chainsaw
Linkage is loose
Stihl 180c runs wide open all the time.it has a new carb on it, linkage is fine
Stihl MS 180C Wont Run ' Arboristsite.com
www.arboristsite.com > Forums > Equipment Forums > Chainsaw
Aug 14, 2011 - 10 posts - ‎7 authors
I have a Stihl MS 180C that i cannot get to run. I used it all last year and went to use it a few months ago and it didnt seem ... it is not under warranty and i have pulled and pulled with choke on and throttle wide open and still wont start. ... Depending on the carb, some times you can just go for broke and get a ... Stihl ms 180 running rich
Jun 5, 2015
Echo cs-370, they actually work
Oct 12, 2010
More results from www.arboristsite.com
Stihl Chainsaw Troubleshooting Guide · TEK Indoor · Disqus
https://disqus.com/home/discussion/tekindoor/stihl_chainsaw.../newest/
Stihl
Dec 15, 2015 | Stihl Garden
I can't get my stihl chainsaw trigger throttle and trigger interlock to catch so I can start it. I pressed them both at same time but does not catch.
Release the interlock button first, then the trigger throttle. If this does not work, replace the interlock button.
Oct 23, 2013 | Stihl 009l
Stihl 026 choke switch not working off trigger handle
Will have to take apart chainsaw handle, and look for the parts that is out of whack/not lined up or not working. May have to replace a couple parts. Look for diagram of exploded trigger handle for all the parts.
Sep 09, 2013 | Stihl Garden
Throttle down linkage
Open up handle and check for alignment on trigger and parts. You can look at an exploded view to see all the handle and trigger parts.
Sep 06, 2013 | Stihl MS181 14" Chainsaw
Stihl ms660 ilde chain speed to fast
Somewhere on the carb linkage you will see a set screw touching it. Turn the screw so it does not push the linkage so far.
Apr 14, 2013 | RTO Spur Sprocket For Stihl 017, 021...
Stihl brake assembly diagram
Oh man, you shouldn't be monkeying around in there. Bring it to a STIHL dealer and make him let you watch, but don't screw with that again, that's a big safety no-no and another reason why STIHL doesn't sell out to lowes or the home cheapo.
May 15, 2012 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
I took apart my new stihl ms 210 the throttle assembly anyway, where does the black wire connect to? there is a red wire connecting to a metal bracket that is coming from the same hole the black one is i...
On the Master Control Lever, you will notice a round reciever on the left side of the lever shaft. This holds the round terminal of the black wire in place. As the lever is rotated upward, the shaft brings the terminal of the black wire into contact with the flat brass spring (which belongs ON TOP of the lever shaft) and thereby stops the engine.
If the throttle trigger is pulled each time the lever is set to choke, this will never again be an issue. However, if the lever is pushed all the way down to choke and the throttle trigger isn't pulled, the linkage will malfunction again.
ALWAYS pull the throttle trigger before you set the choke.
Hope this helps,
Dolf-
Oct 14, 2009 | Standard Oregon Chainsaw Chain For Stihl...
RTO Spur Sprocket For Stihl 017, 021 Chainsaws Logo
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
