Question about Clarion Audio Players & Recorders
Where can I get replacement foam earpiece - Clarion Audio Players & Recorders
  • F W Marshall Feb 10, 2012
    Don't know how I can be more specific. I need replacement foam earpiece covers for Clarion headphone model WH 104 H? Where can I get them?
  • 4 Answers
Jvc headphones retractable cord
The JVC HA-NC250s are a new version of their previous model 100, and JVC claims that they will cancel up to 85% of ambient noise, coupled with better sound. In this case, JVC claims up to 16.5 db reduction at 150 kHz. These on-the-ear headphones are very lightweight at 5.3 ounces and are extremely comfortable. The head band has a reasonable amount of sliding expansion for bigger heads, and the oblong ear pieces themselves rotate and fold flat for storage. JVC uses memory foam on the earpieces, as well as double housing, for extra noise isolation. The earpieces have 40 mm neodymium drivers, which are the same size and type that the Creative Aurvanas offer.The JVC HA-NC250 noise canceling headphones. Note the ear-cushion instruction tab that explains how to replace the hidden battery.
The NC250s come in a semi-rigid black case with a dual airline-plug adapter, a mini-to-RCA phono plug adapter and a 4' detachable headphone cord. JVC includes one AAA battery, which should last approximately 50 hours. A simple sliding switch on the right side turns the noise reduction on along with a small red LED. Learning how to add the battery to the headphones required that I study JVC's user manual. The process involves having to remove the earpiece covering to get to the battery compartment, which isn't at all obvious.
Jul 22, 2012 | Audio Players & Recorders
Hi! Where I can get a foam earpiece replacement?
You could look around in your town/city in the dollar store.
they sometime sell some there OR even if you don't feel like searching to much . Buy a cheap pair of Headset at the dollar store and remove the foam piece from it and put it on you headset
Sep 02, 2011 | Genius HS-02B Headset
Is there anyway to repair the foam earpiece on denon ah-d210 over the ear headphones?
Have a look at my tip on headphone problems just click my user name to find it, you will find an answer at the bottom of it.
May 24, 2011 | Denon Audio Players & Recorders
How do you open earpiece for troubleshooting no sound from right side and something rattling around
What you do is peel back the cusion of the ear pad. You might need to tear off the foam covering. You can glue it back on when your done with Bostick white glue. With the coverings gone you should see access screws.
Jan 30, 2011 | Samson CH700 Professional Headphones
My Motorola S305 stereo bluetooth headphones' foam pads on one of the ears is falling off. I've tried using something like a credit card to pinch the foam back into the game where it seems to be held in,...
Hey, this might be too late to help you, but I figured I'd share in case anyone else came across this while looking for help (as I did).
There's a small inner ring that the edge of the foam ear pads wraps around, but you can't really fit it under there while it's attached to the earpiece. The solution? I used something thin (specifically a nail file) to remove this "ring". It actually seems designed to pop on and off. I was then able to easily wrap the foam ear pad around the ring, then re-attach the ring to the rest of the earpiece.
Hope that helps!
Sep 28, 2010 | Motorola Stereo Bluetooth Headphones
I cant hear people talking but they can hear me, and i can text
The problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Jul 25, 2010 | LG CHOCOLATE VX8500 Cellular Phone
Technics headphones RP-DJ1200
You can buy replacement plugs and solder them on. Make sure you take the old one to the store when you purchase the replacement. The next thing you need to do is figure out which wire goes to which part on the plug. You can us a volt ohm meter to test the old plug and see which color of wire or which color of wire insulation matches to which part of the plug. You can also try taking the foam pad off the left earpiece and look to see if you can get the speaker plate off the earpiece. Once off you can look to see which color goes wher. There will be another wire there that connects the right earpiece to the left one. Make sure you unscrew the shield from the plug and put it over the cord facing the correct direction before you solder the plug to the wiring. Screw it to the plug after. Hope this helps.
Jul 10, 2009 | Technics RP-DJ1200 Professional Headphones
I do not find any complete specification for this product. Not even on the Olympus web page.
Headset for transcribing through PC sound card. This headset’s long cord plugs into your computer’s sound card making it ideal for PC transcription. Supplied with two spare sets of foam earpiece covers. Headband type. Cord length: 13’ Feet
Plug: 3.5 mm
Product Number: 141567
May 19, 2009 | Olympus E102 Professional Headset
Top Clarion Audio Players & Recorders Experts
xxxxxx xxx
Robert Rankin
richie46
Are you a Clarion Audio Player and Recorder Expert? Answer questions, earn points and help others
